  2. I can totally understand why you want to do it. I'm a bit of a sucker for all the latest bells and whistles myself, and if there's a way of making the car do something that a higher-spec model does, I'm usually the first to start wondering how it can be done! 😄 Having looked at what would potentially be involved with the Mk4 though, I'm not sure I'd actually go ahead with this one. The thing is, what you've already got isn't really a "lesser" TPMS system in terms of what it's there to do. It uses the ABS/wheel-speed sensors to monitor for a loss of pressure and, if it detects one, it tells you about it. So the important bit — knowing you've got a tyre that's losing pressure — is already covered. To get the actual numbers on the screen, you're potentially looking at four direct TPMS sensors, a receiver and possibly another module/wiring, plus fitting, coding etc. And then, at some point down the line, you've got four little batteries in the wheels that are going to run out and need dealing with. All of that just to change the information from: "There's a problem with this tyre" to: "This tyre is currently at 2.1 bar." And I completely get why you'd want the second one! 😂 It's just that I'm not sure I'd want to spend potentially quite a bit of money and introduce extra hardware into an otherwise perfectly happy car purely to get that information. A decent digital pressure gauge will give you the actual figures whenever you want them, and you can check all four tyres in a couple of minutes before a long journey. If I'd been speccing the car from new and direct TPMS was an option, I'd definitely have ticked the box. But as a retrofit, I'd probably put this one in the "nice to have" column and keep it on the bucket list for the next car. Then when the next Superb comes along, you can tick the box for direct TPMS from the factory or make sure thee used car has it and enjoy watching all four pressures appear on the screen without having to retrofit half the car to make it happen! 😁 That's just my take on it though — if seeing those four numbers on the OEM screen every time you get in the car is going to make you happy, then I completely understand why you'd want to do it. Sometimes that's reason enough!
  3. I bought a new Kodiaq SE L 7 seater in February this year. Like you, I wanted a space saver wheel. I found the 2 best sources were Skoda Parts Direct and Caffyns Parts. Decided to go with Caffyns. Bought the space saver wheel and the foam kit on their ebay site because delivery was only £12 on eBay but more than £30 if I bought direct from Caffyns!! Fitted everything myself although some parts are a bit tricky. Guess you won’t have that problem with a factory order.
  4. Thanks for reply. Yes, that does look straight forward. But video doesn’t quite show how the old key fits into the new hinge though.
  5. Does this help? - looks like you might only need the chromed hinge corner piece: Appreciate it's a different style, but if your key blade isn't broken it looks relatively straightforward to me. Gaz
  6. Is there anyone who knows the exact number of tire pressure monitor sensor that i should buy?
  7. Thanks for reply. It doesn’t seem the actual key is broken, it’s the metal casing the key goes into, where there is a crack in it, hence the key falling out. So not sure how you go replacing that, do you just get a new fob and the key slides in from the inside going outside somehow maybe?
  8. Hello Richardos Glad to hear 👍 These are important cars and deserve to be looked after 😎 Gaz
  9. I can access the user settings, though at least once it has reverted back to guest from my own profile during an application update. One way to stop the updates is to set the user profile privacy to high which stops the esim from connecting except for the sos function. On the Karoq Facebook group someone with the same problem has received an email from skoda saying that they know it is a technical problem and will be fixed by an OTA update they are working on.......
  10. Today
  11. I completely agree, we have experienced the extremely dangerous braking problem twice and now always turn it off. I raised several complaints with Skoda UK, including the above; the rest relate to the customer service at the branch I purchased from, and I have had generic responses to all. I imagine that a neutral answer avoids any potential liability, but it also avoids actually addressing the problem. At some point, some road users are going to get seriously injured (or worse) under an emergency braking scenario, and I very much doubt my "Customer Relations Manager" will be able to use generics at a formal inquest. Luckily, my local branch, Trancity, is very customer-focused and have just serviced the car and resolved a few problems. But they did say the braking scenarios are as expected from the position of the sensors. Like you, I would have hoped Skoda UK would be collating customer reports for researching and eventually releasing a software improvement or update? I would look closely at the reliability of the Honda; not so sure it is what it was in the pre-electric days? Another contender for me has been Toyota, 'dull but dependable", if they release a plug-in Corolla estate, I personally would seriously consider that instead. They also have the extended warranty periods for the car, 10 years and 15 on the hybrid system (if you service it annually with Toyota). Toyota GBToyota Warranty | Toyota Car Warranty | Toyota UKAt Toyota, we take great pride in the quality and reliability of our vehicles. Discover Toyota Relax - up to 10 years (100,000 miles) Toyota warranty.
  12. It's so annoying that they don't give spare wheels on cars, where possible. Those foam kits are a waste of time. I have a Sportline TDI 4x4 with the 20" wheels, and I use the 19inch spare wheel that I'd bought for my previous Octavia VRS. It'd picked it up as a kit off of eBay, including a jack and wheel brace. Only bit I had to buy then was the genuine Skoda plastic locking screw that holds the wheel in position. You can lever the rear sets up after releasing them to get to the original foam insert that has some of the tools, inflator and foam kit. I stored that in the attic and laid the spare wheel in there, and the jack/tools in the centre wrapped in bubble wrap. Works fine for me. I'm sure you can get a genuine kit it'll include the proper foam insert that surrounds the wheel and holds the tool. Some links you might find useful: https://skodapartsdirect.co.uk/product-category/spare-wheel-and-toolkit/ https://shop.wingsskoda.co.uk/products/skoda-spare-wheel-kodiaq-2024 https://shop.parks.uk.com/products/skoda-spare-wheel-kodiaq
  13. Not on my Yeti, but I have a Fiat Ducato campervan with Michelin Agilis camper rated (CP) tyres. After a holiday journey of 100 miles at up to 65 mph, I discovered that one front tyre had only 25 PSI rather than the usual 60. Tried pumping up with a brand new 12 volt powered inflator, but after 10 minutes this only got to 35 PSI before noisily failing (overheated ?). Finished off with a bicycle pump which took forever but got to 60 PSI eventually. Next morning, back down to 25 PSI so out with the bicycle pump then off to the nearest tyre dealer. They found a small nail in the tread, I guess it only leaked when the pressure was higher than 25 PSI. Tyre removed, checked, repaired and balanced then on my way for just £25. I am amazed that the tyre took this punishment, reinforced sidewalls must have helped. I will probably replace it soon as it's coming up to 10 years old.
  14. Thank you. The problem is not totally about OTA updates. The system itself is subject to non-OTA updates. These have to be carried out at the dealership. My system is still on the original update - 0278. Customers are not informed if an update is needed. It is only carried out if problems linked to it are reported. I had no problems until the car was out of warranty, therefore it is chargeable. As for the MyScala app, yes I have it but it won’t authorise me to access the user settings system. The dealer thinks this may be the problem why the OTAs aren’t updating
  15. sebc joined the community
  16. If your metal 'blade' in the key is broken, you should have it remade by any key specialist shop, is only the machining needed. The electronic part of the key is separated from it. I would advise against homemade attempts to "glue" this together, if your lucky you it will break in your pocket and you will lose the metal blade part, if you are unlucky it will snap when the key is in the door lock .. and you can guess how that saga would continue 😁
  17. leolito started following Broken Key
  18. Timcooper55 started following Broken Key
  19. On my 2016 Superb Mk 111 2.0 the key has come detached. I noticed a crack in the casing. Do I have to get a replacement from a dealer, or is it something I can fix myself. I’ve done a quick google, where it seems to can get replacement fob cases, but can’t see how you would insert your original key. Fortunately I have a spare, but for peace of mind would like to have a spare again. Thank you.
  20. Fix was to replace both lambda sensors. After replacing lambda1 (pre cat, B1S1), it started to throw active codes for lambda2 (post cat, B1S2). After replacing both sensors the fault (codes or MIL) hasn't come back. My guess is that the car had a missfire problem and lambda sensors problem - both of which are long gone now.
  21. MrAB joined the community
  22. Yes, see https://www.skoda.co.uk/owners/over-the-air-update-restrictions
  23. Did you get all the bits sorted? Hope you got on ok in France!
  24. Hello! I need to change my spark plugs, but OEM ones are $60 each.. I get that OEM is preferred, but are there any good alternatives? Stock car, thanks!
  25. Fjord1ambassador joined the community
  26. @East_Yorkshire_Retrofits have OEM folding towbars for kodiaq listed on their website. they may well do for superb too. These are priced about £1500
  27. Binx1310 started following Towbar help
  28. Yesterday
  29. Hi I got the P2196 error code today, do you have any updates, what was the issue with your Skoda and how did you mange to fix it?
  30. Hi all, Today, while driving, my octavia's check engine light came on, plugged it in to an OBD scanner and it said: P2196 -> O2 Sensor Signal Biased/Stuck Rick bank 1 Sensor 1 I must mention, that earlier in the week I happened to notice that when I start the engine on, and the AC starts running, I can feel a smell of gasoline coming in through the vents. I checked online it says that it can be a high pressure fuel pump problem, or something completely different. I am open and thankful to suggestions, since this is the first time I experiencing this type of problem. Is it safe for me to drive the car? Should I immediately leave it at the workshop? Or what more could I check? Is it a common thing with these Octavias? The car has 133 000 kms on it. Thanks in advance.
  31. I had a flickering headlight. Swapped ballasts and it stayed in same place. I found the torx screws on the ballasts quite difficult to get to. I wiser if you have an 90degree bit holder or Allen key type torx bits. I then Changed bulb and all good. I upgraded to LED bulbs. They’ve been brilliant although I did have a faulty one (I suspect I damaged it trying to install it) but the supplier replaced FOC under warranty. Been perfect ever since and a nice upgrade. A pair is significantly cheaper than one HID! https://ebay.io/m/1DxukA Just a pain in the bum to fit. Wheel off, arch liner out. Hopefully won’t have to change them again for a fair while!
  32. juff24297 joined the community
  33. In Greece, we have space saver wheel as standard, in every trim or version-including seven seaters-except the iv version
  34. MogSa joined the community
  35. It's 2012. ,1.2 TDI ,new egr fitted but still has same code and glow plugs light flashing,I was going to find out what voltage I think should be 5 v at which pin , and wanted to know iif there was a common place wiring may be damaged
  36. SarahV joined the community
  37. NickyB joined the community
  38. Maarten71 joined the community
  39. From memory, think is was a minimum of 5mm
