Past hour
What summer tyres do you drive on 19'' wheels with your Kodiaq?
Finally 4 'Michelin Pilot Sport 4 SUV' have just been mounted this morning on my summer rims, since there was a €120 bargain for 4 Michelin. It was easier with these rims off. I'll tell you how they are within ~1 year cause they won't be mounted on my Kodiaq before next spring...
interceptor joined the community
Offered an OTA update today
An OTA finally appeared this morning saying new features will be available after a restart, still showing as 332 though ☹️
AmeliaParker started following Sold my 2016 Octavia 1.8TSI L&K hatch
Today
bluebill joined the community
Fabia Spare Wheel
Sorry to revisit this post but can someone confirm that a 185x65xR15 will fit the boot well without having to pack up the boot floor, thanks.
Yeti 2.0 litre tdi temperature problems
Bopman, can you where to purchase this item (and engine thermostat) for 2.0 l 170 bhp TDI DSG please? I see them online but not sure of compatibilty.
BlueDun started following Yeti 2.0 litre tdi temperature problems
1.6tdi revs high at idle after driving car short distance/DPF???
Apart from high idle cars running great with no problems. Starts first time every time. No dim lights etc. Weird it sits at 750rpm when first started from cold but minute you drive even a couple of metres it jumps to 1000 and stays there. Will try it again today now its above freezing. Wonder if its a failing coolant sensor? Alasdair
Rear springs...replace?
Thank you very much @Carlston . I think these could be the best bet: Sachs 994 373 lowered ride height rear springs (matches 1K0511115CD) (build code 0YH) Length 342mm Wire diameter 12.25mm Would fitting these require new shock absorbers, or is the coil length similar enought to the original to not warrant a change?
I had issues with a high idle and fluctuating voltage, no DPF on my BKD so not doing a regen... Made it better by shining up all the earth points, but it started up again. In the end what fixed it was running a new earth direct from the alternator housing.
chrisund123 started following 1.6tdi revs high at idle after driving car short distance/DPF???
Octavia Mk3 (5E) KUFATEC 43340 Heated Seats Retrofit – VCDS Coding Without KUFATEC 41899
I found My comfort block not support heating seats how to do now 🤔
Fabia 2024 SE comfort mpi fault
@Sklinda I think the garage probably does not believe that - on the three occasions when your car lost power - it was because you had engaged its speed-limiter by accidentally moving the switch on the indicator-stalk. (Out of curiosity I tried moving the switch on my own Fabia's indicator-stalk to see if that theory had credibility, but it seemed very unlikely.) It's just that the garage cannot replicate what you've told them has happened and they are clutching at straws. It might be worth you asking the garage to demonstrate to you (by driving your car with you in the passenger seat) what the effect of engaging the speed-limiter is and then you will be able to confirm that it's nothing like what you've been complaining about.
1.2 TSi CZJC Lumpy, stalled, wouldn't restart
I agree dont run car at all until timing has been properly checked. Read that the HPFP is cam driven so if timing is out/slipped I would assume it would affect fuel pressure etc hence P008700 and misfire on all four. Alasdair
Alasdair1 started following 1.2 TSi CZJC Lumpy, stalled, wouldn't restart
- Activating SmartLink on Swing 3
I would not keep starting it until the valve timing has been proved with the proper locking tools. Looking under the cover for missing teeth only shows the belt has not jumped off. It does not prove the VVT pulley has not slipped on the taper, which is what you are worried about, and that would explain P0011, the misfires on all four cylinders and a new chirp from that area. A VVT solenoid can set P0011 on its own, but it is less likely to cause a no-start, all-cylinder misfire and a new noise after a belt change. P0087 can follow if the engine is running poorly, so I would treat that as secondary until timing is confirmed. Ask the original garage, or an independent, to lock the crank and cam and show you the result. If the timing is correct, then look at rail pressure and the VVT solenoid and its oil filter.
SparePartAlam started following 1.2 TSi CZJC Lumpy, stalled, wouldn't restart
nestore joined the community
Holisi joined the community
Maybe get a mobile mechanic, unrelated to the garage that did the cambelt, to have a look. Misfiring could be related to the fuel pressure, which might not be anything to do with cambelt. Don't know much about these engines yet, unfortunately.
morcatt joined the community
Thank you both for the reply! As the belt was done a couple of months ago, the only way I can see it being related to that is if the cam managed to spin due to the pulley being tightened onto what as far as I understand it, is a tapered shaft. I couldn't see the length of the belt to check for teeth but the guys who came seemed very keen to take the car away. It's never let her down before, and after my own experience with a BKD and a shoddy cambelt change that cost a fortune in replacement rockers etc, I worry for her car. It's a sweet little engine that punches way above its weight.
Charley12199 joined the community
Yesterday
The voltage is just a crude indication. Better if you can find a place that do a capacity check.
Cabin heater easy way in with cabel from enginebay
Hi, i took the clutch cutout inside. How did u do it? Any tip on how to route and Where to ground the 230v input in the front ? Left or right side and where did u ground?
Jaaaaaa started following Cabin heater easy way in with cabel from enginebay
Jaaaaaa joined the community
The Greenline does have lowered ride height. According to the Kilen spring catalogue, the Superb MK2 1.6TDI estate Greenline has rear springs with OEM part number 1K0511115BT. 1K0511115BT has one blue paint mark, and three yellow paint marks. This is the only Superb MK2 lowered ride height rear spring that has three yellow paint marks. 1K0511115CA is one up in the hierarchy, 1K0511115DG is two up in the hierarchy. However, 1K0511115DG might be too stiff so 1K0511115CD might be a better option as it's softer but longer than 1K0511115DG. If 1K0511115CD lowered ride height rear springs don't give you enough rear end lift, then the 1K0511115DE standard ride height rear springs might be a good option. Both these springs have the same 12.25mm wire diameter, so should be about the same stiffness, ie. provide the same level of comfort. Even the 1K0511115CD lowered ride height rear springs should lift the rear end of the car up by at least 12mm (more if the original rear springs have started to sag with age) compared to what you have now, ie. the 1K0511115BT lowered ride height rear springs. Sachs 994 454 lowered ride height rear springs (matches 1K0511115BT) (build code 0YD) Length 330mm Wire diameter 11.75mm Saches 994 363 lowered ride height rear springs (matches 1K0511115CA) (build code 0YE) Length 333mm Wire diameter 12.00mm https://www.autodoc.co.uk/car-parts/oem/1k0511115ca?supplier%5B%5D=32 Sachs 994 360 lowered ride height rear springs (matches 1K0511115DG) (build code 0YF) Length 333mm Wire diameter 12.5mm 1K0511115DH lowered ride height rear springs (build code 0YG) Length unknown Wire diameter unknown Sachs 994 373 lowered ride height rear springs (matches 1K0511115CD) (build code 0YH) Length 342mm Wire diameter 12.25mm Sachs 994 361 lowered ride height rear springs (matches 1K0511115CE) (build code 0YJ) Length 342mm Wire diameter 12.75mm Sachs 994 559 lowered ride height rear springs (matches 1K0511115CF) (build code 0YK) Length 345mm Wire diameter 12.75mm Kilen 65074 lowered ride height rear springs (matches 1K0511115CD) Length 342mm Wire diameter 12.25mm https://www.ebay.co.uk/itm/318939090159 Kilen 65056 standard ride height rear springs (matches 1K0511115DE) Length 362mm Wire diameter 12.25mm https://www.ebay.co.uk/itm/336905897118
unfortunatly i dont have a steering wheel with paddles or heated wheel ( really cant justify ebay prices ) but the heated REAR seats seem warmer than the front 😇😜
Graham1959 joined the community
S3 owners - electric tailgate / hatch closing from inside
I have VCP. You can code what your controller allows. You may be able to write a new data file if it is available. I wanted to get the inside opening and closing functionality for our 2023 SIII but have not been able to do it yet. Skoda have fitted different controllers for different years and they have dropped functionality and called it safety. You might have to change your controller. But that also involves coding.
skoda_superb_2022 joined the community
When I replaced the timing chain on my own car - completely different engine, I still made timing marks in white paint. Once the chain is fitted and locking tools removed the engine should be turned over (by hand) a few times and checked against the timing marks before any covers are refitted. Having marks present does not surprise me. They are useful as checks. Getting the timing wrong usually is catastrophic. Even where parts have timing marks I highlighted these with white paint to aid visibility. Kev.
tetley started following 1.2 TSi CZJC Lumpy, stalled, wouldn't restart
Expert help required
You're welcome.
Though I have heated windscreen, I sometime use a very efficient method when I'm in a hurry to leave: a simple spray bottle that I fill with household alcohol. This prevents any risk of scratches on windscreen and any glasses. With ice scrapper, if your glasses are a bit dirty, it may cause awful scratches. 😬 BTW, it reminds me an old joke in the '80s: _ Do you know why Ladas have heated rear screen? _ To keep your hands warm, when you have to push it. 😂
Mark8206 joined the community
Gearbox Emergency Mode
the wet clutch DSG is very different from dry clutch DSG... an is much more smooth and durable. The wet clutch DSG has also emergency mode (mechanical redundancy for limp mode ) , which dry clutch DSg does not have...
- Skoda Scala 2021 1.0 TSI 95cv – Intermittent clutch problem, gears won't engage
