Oil consumption ?
I'd consider 1 litre of lube oil consumed in more than 11K miles a very reasonable usage rate. Is this a diesel hybrid? How much did you get 'stung' for the oil - consider buying the correct grade from a reputable online seller, in 5 or more litre quantities for topping-up between oil changes.
Warrior193 started following Oil consumption ?
P25AB00 Piston Cooling Oil Control Circuit High - Superb
Tested the code after letting the car sit for 6 hours (cold engine): Cold Engine (Ignition ON, Engine OFF): The code was static and refused to clear. I tried clearing it 4 times in a row, but it reappeared instantly on every rescan without even starting the engine. Warm Engine: After driving to lunch and back, I cleared the code on ignition—it wiped cleanly and stayed gone. Will check the rest of the suggestions when I come home. And retray to clear fault when the engine is cold.
2nd year service coming up, what should I look out for? Not driven it much
coming up to my 2nd year service - what should I look out for? Mrs doesn't drive it much done around 5500miles - 1.5 Petrol Sportline
The Superb III Picture thread
Karoq gearbox doesn't creep?
I would have thought the parking brake would be slower to release than the auto hold ? The parking brake is a mechanical worm drive whereas the auto-hold just maintains hydraulic pressure in the brake circuit. The parking brake release may appear smoother since there's probably sufficient power in the engine to override it as its releasing.
NottsIan started following Karoq gearbox doesn't creep?
Gandalf's Evolution
the truth about electric cars
@Evolution13 I know, I'm not posting anything outside the UK. I was just saying that it is just as hot or even hotter in the places you mentioned, so if it happens there... but there are no reports to report on, maybe for the reasons already mentioned? There is no point in posting EV fires anyway, as the same old debate about ICE cars catching fire more often will just flare up again (see what I did there, pun intended 😁). Until we actually get updated and correct facts on the numbers, there is nothing to discuss.
Enyaq clicking noise
Many issues / faults are KNOWN ISSUES to VW Group, Dealers / Technicians. Maybe even with a TSP / TPI, yet time after time, 'Never heard of that before', nerer seen that before, and sometimes 'they all do that'. The VW way. 3 monkeys or Tommy. Deaf, dumb and blind. The internet really has stuffed it up for the VW group.
Evolution13 started following Enyaq clicking noise
@Graham Butcher What interests me really is what is actually happening here . So UK Insurers are those that should know if other statistics from Fire & Emergency services include other vehicles than just BEV Cars, vans, busses, lorries. No point the figures for e-bikes, e-scooters as electric vehicles.
- From Amundsen to Columbus: mission almost accomplished!
I know what you mean; however, what happens elsewhere does not mean that the same will not or cannot happen here, even with combustion vehicles.
Many thanks for this. Once I have a definitive answer to the issue, I can use this if it is the known problem.
Many thanks for the info. Have asked for a breakdown of the parts and costs. Will have a better idea if the same issue you mention then...
This morning I brought car to Skoda Dealer to replace the factory Amundsen screen with the Columbus one (part n. 565919606D) and factory Amundsen navigation in the glove box with the Columbus one (part n. 3V0035816K); I also replaced the cable what connect the two units. Of course I brought with me the purchases invoices to witness the parts were regularly purchased from a wreckage shop in order to remove legally the component protection. One hour ago Skoda contacted me saying they gave up as the screen doesn't turn on: can anybody help me saying me what else can I do?
Many thanks for this info. I have asked for a breakdown of the parts required and costs
SOH battery certificate
There were quite a few associated with the GAP, Cosmetic damage, tyre and alloy insurance and for the lifeshine cover. I know it's a personal preference to have these, but my cars have been clipped to many times in carparks over the years.. The usual sales documents and a copy of the green registration slip and the Skoda aproved used documents and roadside cover. Then came the more interesting ones which included a Handover checklist, the Battery Health Test and a Car condition checklist, which was a bit like a normal service list with everything checked off.
Check your sills! Paint advice
I had to have a hole welded a couple of years back. Rear of sill is close to mounting of rear beam. This (actually part of front wing) has been slowly worsening for a while. Went through MOT a few weeks back without mention. 🙂
map1mh joined the community
- Is it possible to upgrade the infotainment screen?
Blitzy5 started following Is it possible to upgrade the infotainment screen?
Blitzy5 joined the community
When I did this on my old Nova I just used silver Hammerite... It lasted well
Digital Clock and Dashboard Clock
Yes you must unzip the file first, then copy it to the FAT32 formatted SD card
Meant base of actual engine bay fuse box as in picture above. Think there are connectors underneath to ecu etc. Not unknown for a pin to be coroded or socket opened up enough to make bad connection especially if moisture is present. Alasdair
Trouble Shooting Octavia Mk2 1.6 tdi 2013 CAYC - 01314 Fault Code - No Start
@Morph I dont have 458. I have 646 and 645 if I am not mistaken. (3x 646 and 1x 645) It is a Skoda octavia mk3. On the fuse box on the inside of the car there is 1 x 645 and 1 x 646.
Relay 458 in the engine bay could be the cause.
