2012 to 2019 Superb Refresh
Found it, scroll to 4 mins 50 ish
Golf2014 joined the community
I agree on the diesel or small petrol engines.. Incidentally if you turn the heater to full hot and keep revs below 1500 they dont overheat when stuck so you can get it to a workshop. I was looking at a EA 888 Gen3 B, The pump is on the gearbox side and run from a rubber belt. The plastic housings crack (bit like something they were smoking when it was designed) causing minor leaks initially, then easily spotted pink crystal formation from the Evo coolant. You need a flexible inspection camera to see them without stripping parts off in the early stages. Look at BAZ Merideths YouTube channel where he did a pump on an L&K in the last year or so, shows the housing cracking up close.
- Octavia Mk3 (5E) Facelift Heated Seats Retrofit – What Parts Am I Missing?
Radio cutting out new starter motor
Dont suppose theres an auto power off setting or something similar in radio. The radio may have reset to default if battery was disconnected so isnt rebooting after ignition? Alasdair
Skotastic started following Repeated daily Infotainment update issues
Octavia water pump
I need this doing and have been quoted £1600 by a local indy specialist.... do you mind sharing details of your garage?
GSte started following Octavia water pump
Is DCC important?
I would not have specified DCC, but it came on the dealer's demonstrator that I ended up buying. I find it quite useful and versatile.
freelunch started following Is DCC important?
Fitting a 1.4 8V MPI (78mm) crankshaft into a Favorit 1.3 block?
It's not straightforward at all, Fabia block had been modified quite substantialy to fit the larger crankshaft. From my memory, a centimeter or so has to be taken off the counterweights to fit into 1.3 block, the axial bearing is on a different main bearing, the timing chain sprocket is different and flywheel has 6 holes instead of 4.
Jack Point
Thanks for the info, I guess I will have to 'suck it and see'. Worst case I suppose I could create an alternative fixing arrangement for the cover with clips or screws but will need to see it on the ground after the pads have gone in. I've ordered the pads although despite showing stock on ebay he has advised that none are available and they are 'In manufacture'. I'm not desperate but may have to look elsewhere at some point if there is no sign of dispatch.
3000 miles under my vRS belt, a few questions....
When we collected and drove our new Kodiaq PHEV home the other day we noted that the wife's phone case stopped her phone from sitting flush in against the surface in the wireless charger, but she could not be bothered to remove it from the case to see if the charging would improve from the apparent very slow rate. The blurb for our car says that the wireless chargers are cooled. Will probably experiment with all that when we go on a long trip in just over a week.
Amundsen MIB2 Firmware Update
I can't find any help about enabling via SD GEM mode. Any help about that?
Geoff123 joined the community
Is DCC important?
DCC is amazing if u ask me. It controls both compression and rebound of the shocks, electronically. Multiple levels of shock control - Comfort, Normal & Sport. With the DCC Slider Mod, this increases to 15 levels of shock control. In addition, DCC is also linked to Steering, Braking and Headlights. Mine is still behaving after almost 10 yrs now, despite being lowered for 7+ yrs.
Is DCC important?
Ive never had DCC, on my second superb and Quite happy with it without. A nice to have from my perspective but I dont know any different! Costs wise its much cheaper to replace struts for standard suspension if anything fails.
Binx1310 started following Is DCC important?
I wondered if maybe there was a noise (electrical) suppression component missing from this starter. Can buy clip on ferrite cable filters very cheaply, might be worth trying on radio power wiring, if there's space.
Hi everyone, Can I fit the 78 mm stroke crankshaft from a 1.4 8V MPI (Fabia/Felicia) into a Skoda Favorit 1.3 block? If it is possible, how straightforward is the swap and what are the main things I need to watch out for (block clearance, conrods/pistons, flywheel/clutch fitment, etc.)? Thanks in advance!
Mahmudd started following Fitting a 1.4 8V MPI (78mm) crankshaft into a Favorit 1.3 block?
Columbus Infotainment System
Link to download RNS510-5238A-josi-VIM-Testmode-60-35-5 sent in PM
Luckypants started following Škoda Epiq EV
Mahmudd joined the community
12v battery replacement? 2024 Coupe
Do you have 'Optimised Battery Use' enabled? This helps maintain the 12V by topping up from HV battery when required.
Luckypants started following 12v battery replacement? 2024 Coupe
Su8perb owner here but its much the same: 2- Seems to be a known bug. Watch out for it randomly changing settings. Mine occasionally turns of the autohold brakes. 3 - I suspect these are fromn the "Traffication" system. Lookm in the apps on the car to find the Trafffication app an turn off the alerts there. 5 - If I'm using navigation from Carplay for any time I always use a cable for charging. If nothing wlse the phone gets really hot when navigating and wireless charging which doesnt do the overal battery life any good.
Cedwing started following 3000 miles under my vRS belt, a few questions....
Felicia bonnet swap
FernandoPessoa replied to FernandoPessoa's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanWill follow your tip when i get the car back from the mechanic \m/. Thank you D.FYLAKTOS
Hey there Chaps, I am getting the same issue . Skoda Superb Elegance 2012 plate. "Software Download- Source Activated, Searching for SWL Image" Would it be possible to send over the software link so I can burn it onto a CD. Many thanks (sorry re posted with photo and tags for the guys). @pab567 @varooom
As the radio worked before it must be something else. Reckon it may be the starter drawing more current as its new. Do the headlights blower etc switch off when cranking. Alasdair
FastBunny joined the community
- £30 charge for Courtesy car!!!!
Just delivered my Karoq to Barlows at Crewe, and picked up a manual Fabia Monte Carlo courtesy car. No charge for this, but warned I would have to pay an excess of £250 if I crashed it! It's quite a sporty little thing, but having to change gears on roundabouts, and use a handbrake again, remind me of what I enjoy about my Karoq!!- Felicia bonnet swap
D.FYLAKTOS replied to FernandoPessoa's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanTo reduce noise from ratling, on that Striker loop (U-bar) which looks like the Greek letter Π i have added a layer of tape (Cloth of Fabric as they say it, not common electrical tape). Not too much to create problems in closing,keeps the hood more steady.D.FYLAKTOS started following Felicia bonnet swap- Upgrade oil cooler
Sent a PM- What have you done to your Superb III today?
The advice from Binx is good - easiest/cheapest! I would actually add, depending on your current/expected workload, to start something you are sure can finish in one go ... or at least with the least amount of distractions! ☠️ PS: have not forgot about the OBD11, just can't find it yet ☹️ - £30 charge for Courtesy car!!!!
