Past hour
Tyre Pressure Sensor fault when tyres changed
You can fit a different tyre like a spare or even have tyres at different pressures so total diameter / circumference and set the TPMS to remember that and get no TPMS warning if no change after set. Try it. It is how it is. You do not need to have a constant TPMS warning while running a little mis-sized spare wheel as Skoda sells / supplies.
ABS fault codes in VCDS but no warning light.
Ok - just finished a short test drive and checked speed of wheels - all 4 were virtually identical at different sustained slower speed. Could it be an intermittent fault arising from the pick up ring on the bearing having some rust/contamination? Just trying to get an idea before having a look or asking local garage. Fats
1.4 TDi Spluttering and Loss of Power When Up to Temp
If it takes ages to warm up it could very well be the thermostat thats past it. My old Octavia was the same. Not bad in summer but cold weather took ages and just made it to 90 after a long hard run(normally sat at 60-70 and it would noticeably drop the minute I let car idle). Changed it and it was fine after that. Reckon your right in changing temp sensor at same time to rule it out. I would do the above first and if no improvement maybe EGR valve clean and check wiring loom to injectors. If the loom is dodgy it could be affected by hot temps and cause misfire etc. Alasdair
Alasdair1 started following 1.4 TDi Spluttering and Loss of Power When Up to Temp
Boot latch
Hello got a 2013 Skoda fabia mk2 1.2 SE 532 Just got the thing boot latch died right after I got it . fitted a replacement (not OEM mind you) now I have a door open check light on no matter what I do. I have moved the thing and 8 times same with the holding pin plate on the bottom no luck same light and boot light on. The thing catches and closes but the latch will not move all over to full closed position make contact and get rid of the lights. Any mods and tips welcome
Checklightchowmein started following Boot latch
Incorrectly Identified NSL Speed Limits
@stepred My best guess is that it's something to do with Traffication. It's not the raw map data as I've verified that's correct with the online version. It's also not the camera, as it happens where no signs are present. So I can only guess that Traffication is maybe adding in what it thinks is "live" data, possibly from long since removed roadworks. But even that is questionable given that roadworks rarely have a 20 MPH limit. If by any chance your Traffication is coming up for renewal, maybe let it lapse & see if the issue goes away. Unfortunately I renewed mine in the belief that Skoda Connect knew what they were doing when they said they had a fix...
Today
Thank you for the advice.
If it's the original tyre then the difference in wear will be the cause and it'll need to be replaced to resolve the TPMS logging a loss of pressure. Personally I only replace tyres in axle pairs unless absolutely necessary.
Fabia 2024 SE comfort mpi fault
The title of this topic is "Fabia 2024 SE comfort mpi fault". That UK specification Fabia model had a 80PS MPI (Multi Point Injection) motor and (as Evolution13 has observed) this was normally-aspirated (ie. NOT TURBOCHARGED). The gearbox was 5-speed manual and a DSG automatic transmission was not an option. The summary on the carchecker.pro link reads as follows Reliable supermini with well-documented, manageable issues The Skoda Fabia Mk4 with 1.0 TSI is one of the most dependable small cars on the market. The EA211 EVO engine is a proven unit used across the entire Volkswagen Group, and most reported issues are moderate in cost and severity. The key concerns are turbo actuator sticking from gentle driving, carbon buildup from direct injection, and GPF clogging on short-trip cars. Manual gearbox versions are significantly more reliable than DSG automatics. With regular longer drives and standard maintenance, most owners report uneventful ownership. But @Sklinda's car does not have a TSI motor, nor a DSG automatic transmission. My own 2024 Fabia SE L does have a 1.0litre TSI motor and DSG transmission, so the carchecker.pro comments would be relevant to it - but they are really not relevant to @Sklinda's car and just muddy the issue. Her car is as 'simple' as a Fabia Mk4 can get and (as @Evolution13 has said) should be very suited to a motoring life involving lots of short city journeys.
Yes, the only remaining original tyre. As mentioned in my original post, I think it too much of a coincidence that it is just this tyre that keeps showing up on the screen as a loss of tyre pressure.
Play in between outer and inner track rod end
I would have thought it would have been noticeable if thread size was wrong. Normally M14 x 1.5 although inner I think can vary depending on steering manufacturer. If the nut was tightened but has come loose over time the movement could have caused damage to threads on rod or in end. (unless it got hit by something on road?) You may get away with just a new end but safer to replace both and I would do both sides. You say you are going to replace shocks/springs etc. Unless there past it I wouldnt bother and just do the track rod etc. Alasdair
scottydog90 joined the community
Apple CarPlay adapter recommendations
I've used Ottocast with Android and it wasn't great but that seems to be because it's designed for Apple devices and only works with Android via some app trickery. I e actually gone the other way to you and switched to an AA wireless2 but still have the Ottocast cube. You're welcome to it for a few quid if you want to try it.
Is the rear offside tyre the remaining original? If so it's likely to be due to the different rolling circumference of that worn tyre compared to the three other new tyres.
- Fabia 2024 SE comfort mpi fault
Chri Harris on Cars.
scientist need to study Francis, to help better understand pathogenic transmission, because his enthusiasm for anything mechanical is more infectious than ebola 😂 and yeah, the guy can drive a car! while understanding how everyrhing actually works. ive not watched any of any Grand Tour but i wish him every success in his endeavours, deserves every bit of it. unlike putting Ramsey into TG 🙄
mihairmd joined the community
Checklightchowmein joined the community
Any high mileage TSI engines out there ??
1.5 tsi act, 144k on clock 130k ish as a taxi. Gearbox leak at 100k , vibration when act kicks in from about 100k. Oil on spark plug also from 100k
Brian15 started following Any high mileage TSI engines out there ??
Checklightcaser joined the community
Thanks, I'm sure that is the case but I have been unlucky to buy a car in june that does have the dsg problem, intermittently I do acknowledge that some of the problem is due to short journeys and sitting in traffic. However I live in a village close to Cambridge, a densely populated city. I do go into Cambridge when necessary and also drive to the other end of the village, to other places 3-5 miles away. It does get longer journeys regularly where I drive at 50, 60, 70 mph! Correct me if I'm wrong but I thought new cars are built for any length or type of journey......
Cairus's Leon FR
A colleague is currently working extensively with the MIB2. In this case, it’s a Seat system, but it can be upgraded to any firmware version. Tire temperature monitoring has been added for the active tire pressure control system. The MIB2 has been patched, as has the firmware for controller 65.
Yesterday
Your car does not have TPM sensors in the wheels, the system is part of the ABS system as far as sensors at each wheels hubs. If you are resetting the TPMS correctly then, maybe the issue is a wheel bearing overheating and heating the wheel and increasing the tyres heat and increasing the tyres pressure. Only causing a warning on longer runs. So not a tyre pressure loss, less circumference of a tyre but increased circumference. Next time there is a warning try to stop someplace soon as and see if the wheel seems too hot. Or just try resetting the TPMS again.
Evolution13 started following Fabia 2024 SE comfort mpi fault , Tyre Pressure Sensor fault when tyres changed and Bet
Bet
Welcome. Fluid as in something that is not just water? Any smell to it, or dare I ask any taste?
It anyone wants or needs a small capacity petrol automatic and it is going to be less than 8 years old then a 1.0 tsi with a dq200 DSG is no more likely to have issues than any other manufacturers small petrol autos including cvts with engines with a gpf. Thankfully since 2018 the DQ200 DSG issues are much reduced, especially when matted to a 1.0 TSI rather than to a 1.5 tsi act.
Hello, Hoping that someone out there has either come across this issue themselves or can kindly offer some considered advice. We own a 2023 Skoda Scala 1.0 litre which has covered 13,000 miles. The car was fitted from new with 'Nexen' branded tyres which still had at least 3.5 - 4mm of good tread. Three out of the four original tyres developed cracking on the outside shoulder of the tread which was brought to our attention during the car's first MOT (October 2026) Although not a MOT fail or even advisory we were asked just to keep an eye on the situation in case the cracking went deep enough to expose the steel fibres. In the interests of safety we decided to change the three 'cracked' tyres but kept the fourth tyre as it was clear of any similar cracking. On the first long journey after changing these tyres, the TPMS light came up on the dash even though all four tyre pressures had been checked no more than two days previously. Likewise the tyre has no obvious nail or similar object causing a slow puncture. I have again checked all four tyres and re-set the dashboard computer but any reasonably long journey keeps lighting up the TPMS on the same rear offside tyre. Bizarrely short trips around town don't cause any such issues. Hard to imagine it's a faulty pressure sensor given the proximity in time of when the three other tyres were changed. Many thanks.
harrisonlili454 started following Recovery services, good or bad?
Peet joined the community
No, I tend to swerve away from Grand Tour stuff.
Good series that was. Have you seen Francis Bourgeois on the new Grand Tour series. He can drive fast alright.
Budget one from AliExpress. Used it for about 8 months and it’s been perfect. Once it’s set up it connects by the time the car starts. Only thing I’ve noticed is a tiny delay in audio (e.g when changing tracks or if you’re watching a video when parked up) but this is the same as the wireless CarPlay built in on my wife’s kodiaq so it’s not down to this adaptor. I just found this on AliExpress: https://a.aliexpress.com/_EydTvyw
Binx1310 started following Apple CarPlay adapter recommendations
Radio database field BLANK on MIB3 FM radio - Australia (2021 Kodiaq, SW 0330)
I concluded that PhonoStar don't support mib3 icons in Australia when it last came up before and I looked. The question is what icons do the units have on them in Australia. The DIY firmware update that people do will wipe the icon storage... pretty sure, so buying a secondhand car could be pproblematic. Probably something to check.
