- Elroq: Who else has ordered?
Help needed to code out reversing camera from new head unit, NW London
Hello In need of some help please. I recently swapped out the RNS 315 nav unit in my Fabia II Combi and replaced it with a RCD 360 from China. With the maps on the 315 now getting a bit stale (VW stopped supplying updates about 4 years ago), the new unit instead offers a factory-fit-like option with Carplay and Android Auto. However, the new unit is coded, by default, to support a reversing camera. I have no plans to fit one, and it's an annoying error (no camera found) to have to clear from the 360's display the first time I try to reverse each trip. The AliExpress seller of the head unit has sent me a series of screenshots to help navigate through the VCDS steps needed to code out the reversing camera function (Warning, they are in Chinese, but they've marked everything up so hoping it's going to be more a case of following the boxes rather than having to translate stuff). However, I don't have VCDS myself. hoping someone who does in my broad radius (I'm in NW London, but happy to travel as needed to get this done) will be able to help me out. Happy to come to you and pay you for your time, though this should be a quick process, hopefully. Thanks Chris
Wrong suspension springs -help
Can someone please shine some light on this ? Time came for the Eibach springs to get fitted last week only to find out that the rear springs don't fit at all. They are hitting rear droplinks without any weight put on them. Yes i know the springs are for estate and my car is saloon but they don't fit. Unless my mechanic doesn't know how to fit them I'm really lost. Pictures attached below
mistac started following Elroq: Who else has ordered?
I don't even know what this part is called in English, all I know is I need a new one...
Right, right. Another lad replied on my YouTube channel about it, said my car is missing the missing the exhaust manifold heat shield / 'hot air collector': https://www.skoda-dily.cz/nahradni-dil/115050680-predehrivac-vzduchu-evropska-unie-1031.html . Huzzah! Another part to buy. 😑
Car will not identify a space to park in
I have a 2025 Skoda Diesel L&K and notice no matter how many times I try and engage Parking Asist to find a suitable parking space it fails to recognise any even when I am driving slowly in a supermarket carpark after pressing the 'P' icon on the infotaintment screen and indicating. What more do I need to do?
Offered an OTA update today
Whoops should have read a bit further. Wireless Android Auto is flawless for me now. It was a pain before.
I don't think you can do that on MIB3?
You can't add them manually on the MIB3. Not got my 334 update yet. I have 332 at the moment with random issues connecting to Android Auto so hopefully when it arrives it should fix those
Dave77 started following Offered an OTA update today
Air Quality Sensor testing
I would be interested to hear from anybody that has successfully fitted a 5K0907659 air quality sensor to their pre facelift Skoda Yeti. Currently I don't see how it can work without alterations to the Climatronic control panel. As previously mentioned, the news sensors appear to speak LIN whereas the old ones are PWM. Unless the sensor is multilingual, the protocol used on the sense pin (pin 3) is going to be different and not be understood by an unaltered climatronic control panel. I have attached a trace of both old sensor 1K0907659 and a new sensor from Febi part 194829 but based on the 5K0907659. I don't believe that the replacement 5K0907659 OEM sensor from Skoda will be any different to the Febi part and I'll have the same problem. Old sensor wave form: New sensor wave form:
Radio code
I had a similar problem with a locked radio a few days ago. I tried a couple of places and got nowhere, so I ended up finding RadioCodePro.co.uk and they were able to get the code for me. I honestly don't know if the “Skoda server offline” message means the radio is flagged or if their system was just unavailable, but in my case I eventually got the code sorted. Might be worth giving them a try if you're still stuck.
mariecurrie started following Radio code
mariecurrie joined the community
Advice on essential maintenance before looking at mapping
Great point I’ve not looked at fluids etc yet but will very soon. Also yes I really want to be a million percent sure the car is strong and ready for any sort of map before I commit as I want to keep the car for a long time putting my own stamp on it.
Issues with Mk 4 1.5 TSI
The car may have been registered in May, but when was it manufactured and how long did it sit unused? My Octavia had a gap of 10 months from production to initial registration. I took ownership 9 months after registration. The battery was never amazing and Start/Stop barely activated when sitting in traffic. I had a new battery fitted a few months ago and it's like a different car. Start/Stop constantly activates now even without the car being warmed up. So could be worth checking the battery health, and maybe putting a battery charger/conditioner on it? I regularly get complaints with Front Assist, and they're always temporary. It seems to not like certain sections of road. When I take my kids to school there's always one section of road, that if Front Assist will alert, it will do it there. I've never really worked out why.
I did buy a fuel filter too for when the car goes up on lifts I’ll get it changed at that point very soon as I believe it’s on the underside of the car? Good shout on the brakes suspension and mounts too I’ll get them all checked out also hopefully in good condition.
Great shout to be fair I’ll check it out I’m also in the north too.
my car had some issue, on half empty road, warn of colision popped and car itself braked to the floor, driver behind me avoid collision in inches. why is it doing? luckily it happened only 2-3 times in 2 years, no matter of weather or dirt. car decelerate and brake itself without reason, dangerous. i wanted to turn off all assistant stuff (i can do it in settings, its 2019), because i have 35 years of driving experience on motorbikes and cars, never caused a car crash, but it is helpful sometimes.. help to avoid car crash.
imart143 started following Issues with Mk 4 1.5 TSI
for best performance and security, whole car must be checked, low milege but also low year of production, shocks and rubber parts gone with time. brakes, brake fluids etc.. check everything, for your own sake and for sake of others. when ii tuned my 1.5 tsi from 150 to 180 ks, my first ride after warm up was pretty dangerous.. :-D
Carlitos295 started following East_Yorkshire_Retrofits
MOI3_EU_SKMQB update
SSalvo started following MOI3_EU_SKMQB update
well as you say youve just recently bought the car id suggest replacing the fuel filter too, you dont know what the cars been run on or how many times its been run close to empty, and also with any engine upgrades ,,,, check the brakes and suspension (and engine mounts) for wear and damage and change the brake fluid too
GREEBO_22 started following Advice on essential maintenance before looking at mapping
This new car has also got another issue that I have read on other forums for other models with the same engine. The new issue is the car cuts out when travelling at low speed especially approaching junctions / roundabouts or in heavy slow moving traffic. If you have an auto box, I believe this is normal and its part of how the start stop works, I am sure I read about this on here, as people were complaining that when they come up to a roundabout but don't stop, they put there foot down and there is nothing there, because the car thinks you are stopping so it's trying to save fuel.
MonkeyBoy2283 started following Issues with Mk 4 1.5 TSI
Maybe try Tesco Momentum 99, not just cheaper, sometimes exceeds 99 ron, especially once the Winter Spec arrives at filling stations. Starting earliest in the Northern regions, late September / October Scotland.
I have an annoying bug after updating from version from 1896 > 1941 > 1989, I notices that my roller boot cover does not automatically retract when you open the electric tailgate since the update. I did not have the car long before I did the update but I remember it having an option to turn it on and off in the infotainment screen, but currently I don’t seem to have any options for it, it used to have a section called something like “opening and closing”. Has anyone else lost this feature on the infotainment screen? if you still have this option on 1989 can you show me a photo have what that looks like please. Do I need to do something to get this to reappear as I did the factory resets after the flashing, everything else seems normal, I don’t have any errors on the OBDeleven, and I don’t think its mechanical because it was fine before the software update.
I’m on my second tank of shell v power which I believe is 99 ron? I ve put nothing but that in it thus far
