  2. I’ll check later when it’s a bit darker 👍
  3. Very odd, I'd expect an engine running as badly as you describe, possibly due to the damaged PCV, would display some visible warning indication.
  4. My car also had this problem last year, manufactured 10/2014. I fixed it with a couple of seger-rings and glued the button back on if I recall correctly. Mines a manual so when parking I always apply handbrake first after shutting engine down with the brake pedal on then put it in 1st gear so that most of the forces that try to make the car roll forwards/backwards are countered by the brakes, i like to think that saves the transmission in the long haul.
  5. Jo88Mak started following Handbrake "failure"
  6. Local garage changed my folks Fabia 1.9tdi from variable to fixed as they were only doing 4-5k a year. Mechanic used to service just before MOT and while he was at it checked car over for MOT. He reckoned that high mileage per year go variable but low mileage per year go fixed plus its getting an annual check over as well as a service. Alasdair
  7. garymosses joined the community
  8. Hi' folks i have a problem with my rear wiper motor it started off with the front wipers stopping on the front screen then when i engage the rear wiper the front wipers start working again then again stop. I replaced the relay now the front wipers stay on when i put ignition on and will only stop when i engage the rear wiper then the front wipers swipe 3 times then rest. Now i have replaced the rear wiper motor because when i take the plug out of the rear wiper motor the front wipers work fine. What's happening now is when i turn the ignition on the front wipers are now swiping 3 times then rest i have returned the rear motor which is a non branded motor from ebay has anyone had this problem. Thanks
  9. I have a 2007 BKD that has been stopping intermittently. After stalling sometimes it will start for a few seconds then stop again. I changed the 449 relay under the dash but no joy. I checked the socket of the 449 relay and identified the live pin and 'test' wired it directly to the fuel pump. The fuel pump ran ok. Interestingly as soon as I turn on the ignition the engine fan kicks in. So, does the car not start because it senses the engine is too hot? Any ideas would be greatly appreciated. Cheers guys
  10. Today
  11. I have emailed Febi to make them aware of this issue but for completeness here is the link to the Febi part that is not compatible with 5K0 907 659. https://partsfinder.bilsteingroup.com/en/article/febi/194829
  12. You might consider linking Febi to this thread as helpful feedback for them?
  13. oh sorry dumb question the check engine light. From memory it goes off after starting, & no diagnosed fault codes show
  14. I have now purchased a 5K0 part albeit second hand and it actually does output the desired PWM signal and has subsequently caused the fault to be cleared. So the issue was that Febi and the other seller were falsely advertising their part as compatible with 5K0 907659/1K0 907659. They are not. I am quite disappointed with Febi as I used to consider them a trustworth company. Thanks to @Breezy_Pete for persauding me to try the OEM part.
  15. Just found the service record. Brake fluid was marked as done as “additional work carried out” at its service a year ago just before 15k. 👍🏻
  16. Be sure the Brake Fluid was done, or shows as. & the Air Filter might never have been looked at. Having had 14 cars from Motability that used to get Annual Servicing they changed to counting on the Manufacturers Warranty and the vehicles being left on Variable / Flexible Servicing. My 2016 Seat Alhambra 2.0 TDI had Oil like Black clotted cream by the time it got an oil change at about 21,000 miles since the Dealer could not get it in. The Adblue is part of Servicing with a Motability car and no cost to the Customer but getting the Dealers Service desk to book a time is a joke.
  17. Don’t do it!! How could you swap out a Yeti for an EV? Keep it till it falls apart. SWMBO has had her Octy VRs diesel since 2012 and it’s done over 140,000 miles with nothing major having been replaced. Kind of shows how reliable the older models are. I had 3 Yetis over the years nd wish I had never got rid of the last one.
  18. Might be a failing dpf pressure sensor or the ash content is very high. Might be worth getting a quick vcds scan to see if there any stored and check ash level at same time. My octavia does the same but only getting short runs these days. When it happens I try and give it a decent long run. Alasdair
  19. Alasdair1 started following Re-gen frequency
  20. Contemplating selling this, it’s an absolute joy to drive, does have a couple of cosmetic things I’d planned to do, but think if I do sell it I’d let the potential new owner decide to do that, better to see it in its original state 😬
  21. It’s an ex-mobility on 20k miles so fully serviced. In fact it was serviced twice in the two months before I got it as the dealer wanted to make sure they weren’t relying on someone else’s previous service. I was given a printout of the previous services when I got it, but they seemed a brief overview, I shall request a detailed report of what was done. But clearly lots to think about.
  22. AFAIK, yes damaged PCV can cause engine to run badly, you didn't mention in your first post - but was the MIL fault light showing originally?
  23. A 2023 Kodiaq. What has been done up to now. Did it get Brake Fluid changed at 2025 or 26? Was the Pollen filter done 2025 and due again 2027? If Haldex was it serviced this year. If a TSI the spark plugs are due next year maybe. So what the 2 year Service Plan gives matters. Has the Air Filter even been looked at or will they say replace at 6 years / 60,000 miles so not in the Service plan. Warranty requires 'Servicing to manufacturers Guidelines, Recommendations or Advice, not even Schedule'. Yet many Full Main Dealer Service History Approved Used Cars were not Serviced to Manufacturers Guidelines. Good VW Independent Specialists might well service correctly and as per vehicles useage and location. Service Brakes etc.
  24. Makes sense, thanks. I’ve still to decide if after my 1 year used car warranty I take out the additional 2 year service plan/warranty, when I believe they’d set it to fixed anyway. Sounds expensive but takes any worry away. In the past I’ve always serviced at a local mechanic as soon as the initial warranty runs out but I worry these newer cars are less easily fixed outside the dealer network with all the fancy features.
  25. So after removing the PCV Assembly out yep the diaphram is split in 2 or 3 places. have ordered the replacement so hopefully will receive it over teh weekend & this solves the issue perhaps
  26. lior994 joined the community
  27. How often is the car doing only short trips / cold starts, & how far, or doing longer journeys & how far are those trips? ,
  28. Fixed Servicing or Fixed Oil & Filter Servicing / Oil Changes if you do less than 10,000 miles a year seems 'Simply Clever'. Maybe not for those doing 18,000 miles or more annually. But then that would still mean the oil & filter being changed sooner than every 12 months. There is more to Car Servicing and Maintenance though. So do you want the car going 2 years between visual inspections / checks? Some like the Pollen Filter might be @ 2 years, Brake Fluid replacement now as well not @ 3 years then each 2. But the Haldex is @ 3 Years / 30,000 miles. So Servicing each 2 years does not work out suiting that.
  29. Just another of Volkswagen Groups 'Lost in translation'. TDI,s oil requirement / specification is the same regardless of getting a Fixed or Variable oil & filter service regime. 'Long Life Oil'. VW504 00 / 507 00, then later for some VW508 00 / 509 00.
  30. Ok where can I find? eBay?
