  2. If it's the original tyre then the difference in wear will be the cause and it'll need to be replaced to resolve the TPMS logging a loss of pressure. Personally I only replace tyres in axle pairs unless absolutely necessary.
  3. The title of this topic is "Fabia 2024 SE comfort mpi fault". That UK specification Fabia model had a 80PS MPI (Multi Point Injection) motor and (as Evolution13 has observed) this was normally-aspirated (ie. NOT TURBOCHARGED). The gearbox was 5-speed manual and a DSG automatic transmission was not an option. The summary on the carchecker.pro link reads as follows Reliable supermini with well-documented, manageable issues The Skoda Fabia Mk4 with 1.0 TSI is one of the most dependable small cars on the market. The EA211 EVO engine is a proven unit used across the entire Volkswagen Group, and most reported issues are moderate in cost and severity. The key concerns are turbo actuator sticking from gentle driving, carbon buildup from direct injection, and GPF clogging on short-trip cars. Manual gearbox versions are significantly more reliable than DSG automatics. With regular longer drives and standard maintenance, most owners report uneventful ownership. But @Sklinda's car does not have a TSI motor, nor a DSG automatic transmission. My own 2024 Fabia SE L does have a 1.0litre TSI motor and DSG transmission, so the carchecker.pro comments would be relevant to it - but they are really not relevant to @Sklinda's car and just muddy the issue. Her car is as 'simple' as a Fabia Mk4 can get and (as @Evolution13 has said) should be very suited to a motoring life involving lots of short city journeys.
  4. Yes, the only remaining original tyre. As mentioned in my original post, I think it too much of a coincidence that it is just this tyre that keeps showing up on the screen as a loss of tyre pressure.
  5. I would have thought it would have been noticeable if thread size was wrong. Normally M14 x 1.5 although inner I think can vary depending on steering manufacturer. If the nut was tightened but has come loose over time the movement could have caused damage to threads on rod or in end. (unless it got hit by something on road?) You may get away with just a new end but safer to replace both and I would do both sides. You say you are going to replace shocks/springs etc. Unless there past it I wouldnt bother and just do the track rod etc. Alasdair
  6. scottydog90 joined the community
  7. I've used Ottocast with Android and it wasn't great but that seems to be because it's designed for Apple devices and only works with Android via some app trickery. I e actually gone the other way to you and switched to an AA wireless2 but still have the Ottocast cube. You're welcome to it for a few quid if you want to try it.
  8. Is the rear offside tyre the remaining original? If so it's likely to be due to the different rolling circumference of that worn tyre compared to the three other new tyres.
  9. @Sklinda What is the intermittent issue with the DSG that is not just the issue with the engine? Yours being an MPI so no turbo should be idea for short cold start trips?
  10. Today
  11. scientist need to study Francis, to help better understand pathogenic transmission, because his enthusiasm for anything mechanical is more infectious than ebola 😂 and yeah, the guy can drive a car! while understanding how everyrhing actually works. ive not watched any of any Grand Tour but i wish him every success in his endeavours, deserves every bit of it. unlike putting Ramsey into TG 🙄
  12. mihairmd joined the community
  13. Checklightchowmein joined the community
  14. 1.5 tsi act, 144k on clock 130k ish as a taxi. Gearbox leak at 100k , vibration when act kicks in from about 100k. Oil on spark plug also from 100k
  15. Checklightcaser joined the community
  16. Thanks, I'm sure that is the case but I have been unlucky to buy a car in june that does have the dsg problem, intermittently I do acknowledge that some of the problem is due to short journeys and sitting in traffic. However I live in a village close to Cambridge, a densely populated city. I do go into Cambridge when necessary and also drive to the other end of the village, to other places 3-5 miles away. It does get longer journeys regularly where I drive at 50, 60, 70 mph! Correct me if I'm wrong but I thought new cars are built for any length or type of journey......
  17. A colleague is currently working extensively with the MIB2. In this case, it’s a Seat system, but it can be upgraded to any firmware version. Tire temperature monitoring has been added for the active tire pressure control system. The MIB2 has been patched, as has the firmware for controller 65.
  18. Yesterday
  19. Your car does not have TPM sensors in the wheels, the system is part of the ABS system as far as sensors at each wheels hubs. If you are resetting the TPMS correctly then, maybe the issue is a wheel bearing overheating and heating the wheel and increasing the tyres heat and increasing the tyres pressure. Only causing a warning on longer runs. So not a tyre pressure loss, less circumference of a tyre but increased circumference. Next time there is a warning try to stop someplace soon as and see if the wheel seems too hot. Or just try resetting the TPMS again.
  20. Welcome. Fluid as in something that is not just water? Any smell to it, or dare I ask any taste?
  21. It anyone wants or needs a small capacity petrol automatic and it is going to be less than 8 years old then a 1.0 tsi with a dq200 DSG is no more likely to have issues than any other manufacturers small petrol autos including cvts with engines with a gpf. Thankfully since 2018 the DQ200 DSG issues are much reduced, especially when matted to a 1.0 TSI rather than to a 1.5 tsi act.
  22. Hello, Hoping that someone out there has either come across this issue themselves or can kindly offer some considered advice. We own a 2023 Skoda Scala 1.0 litre which has covered 13,000 miles. The car was fitted from new with 'Nexen' branded tyres which still had at least 3.5 - 4mm of good tread. Three out of the four original tyres developed cracking on the outside shoulder of the tread which was brought to our attention during the car's first MOT (October 2026) Although not a MOT fail or even advisory we were asked just to keep an eye on the situation in case the cracking went deep enough to expose the steel fibres. In the interests of safety we decided to change the three 'cracked' tyres but kept the fourth tyre as it was clear of any similar cracking. On the first long journey after changing these tyres, the TPMS light came up on the dash even though all four tyre pressures had been checked no more than two days previously. Likewise the tyre has no obvious nail or similar object causing a slow puncture. I have again checked all four tyres and re-set the dashboard computer but any reasonably long journey keeps lighting up the TPMS on the same rear offside tyre. Bizarrely short trips around town don't cause any such issues. Hard to imagine it's a faulty pressure sensor given the proximity in time of when the three other tyres were changed. Many thanks.
  23. Peet joined the community
  24. No, I tend to swerve away from Grand Tour stuff.
  25. Good series that was. Have you seen Francis Bourgeois on the new Grand Tour series. He can drive fast alright.
  26. Budget one from AliExpress. Used it for about 8 months and it’s been perfect. Once it’s set up it connects by the time the car starts. Only thing I’ve noticed is a tiny delay in audio (e.g when changing tracks or if you’re watching a video when parked up) but this is the same as the wireless CarPlay built in on my wife’s kodiaq so it’s not down to this adaptor. I just found this on AliExpress: https://a.aliexpress.com/_EydTvyw
  27. I concluded that PhonoStar don't support mib3 icons in Australia when it last came up before and I looked. The question is what icons do the units have on them in Australia. The DIY firmware update that people do will wipe the icon storage... pretty sure, so buying a secondhand car could be pproblematic. Probably something to check.
  28. Hi, 2012 Superb 2 Estate - 140cr DSG - 70,000 miles As title really - both rear wheels showed faults during a routine scan. Also ABS Control Module fault. No warning light on display. I had both rear tyres checked for air loss a little while ago and new valves were fitted - so they had the wheels off. Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb Part No: 1K0 909 144 P Component: EPS_ZFLS Kl. 000 3305 Revision: 00H22000 Shop #: WSC 18598 000 1048576 VCID: 372B28B10349808216A-8062 1 Fault Found: 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 219 Mileage: 111296 km Time Indication: 0 Date: 2021.04.18. Time: 10:56:40 Freeze Frame: Voltage: 14.00 V DU Temperature: 31.0 C RPM: 1242 /min Speed: 4.0 km/h Speed: 4.0 km/h Count: 0 Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V2.clb Part No SW: 1K0 907 379 BH HW: 1K0 907 379 BH Component: ESP MK60EC1 H31 0121 Revision: 00H31001 Coding: 863D601609260001610F06E490210082300000 Shop #: WSC 33361 790 00078 VCID: 79AFEE8979DD56F2A0E-802C 2 Faults Found: 00287 - ABS Wheel Speed Sensor; Rear Right (G44) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 1 Fault Frequency: 1 Reset counter: 219 Mileage: 111296 km Time Indication: 0 Date: 2021.04.18. Time: 10:56:40 Freeze Frame: Count: 0 Count: 0 Count: 4608 Count: 83 Count: 50689 Count: 0 Count: 0 Count: 0 00290 - ABS Wheel Speed Sensor; Rear Left (G46) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 1 Fault Frequency: 1 Reset counter: 219 Mileage: 111296 km Time Indication: 0 Date: 2021.04.18. Time: 10:56:40 Freeze Frame: Count: 0 Count: 0 Count: 4608 Count: 67 Count: 50689 Count: 0 Count: 0 Count: 0 Coincidence? What should I look for as a 1st step? Thanks, Fats
  29. Thanks all. It is just the picture. It seems to be doing that When assembled it was solid. Kwik fit last to touch it during a wheel alignment. Could the ECP outer track rod not actually be the correct fit? I suspect the threads are indeed damaged internally. I'm going to change them both. But the driver's side which was also changed at the same time, identical brands, is fine. I watched the tech tighten up the lock nut. I even wire brushed the threads and gt85 before presenting for wheel alignment. Tech wasn't struggling at all if I remember (1.5 years ago). Passed 2 MOT (1 was 2 weeks after alignment and other 1 year later). If it had play they would have noticed this. The outer, inner rods don't want to pull apart (yet) but not safe I agree. Just odd it has taken so long to manifest. Is it the lock nut tightened up on dirt (it was all clean at time). Could bad roads cause this? I've changed gearbox mount and top engine mount in this time. Gearbox mount was causing an odd noise on full lock in reverse. Could this damage the joint between the steering rods? I'm going to replace the coil spring, strut shock and drop links and inner outer track rod. Ball joints were done 1.5years ago.
  30. As title states. Trying to source a good quality adapter for only iPhone use. I have tried the AA wireless two+ to allow wireless CarPlay using an iPhone and it was a poor experience for music playback. Nothing would fix the random stutter so it’s been sent back. Looking for the best recommendation or even to start a list, from those that have one that works flawlessly. No need for android compatibility or multiple phones. Recommendations so far are for ottocast and carlinkit, but would like to hear personal experience from anyone who uses one daily without hassle please.
  31. Thanks Bazz that's very useful and very kind!
  32. I have a 2015 Scout with the same problem. I think if I took out the diff, prop and shafts, but leave the CV joints in to clamp the bearings, then it should be ok to run 2WD. My haldex controller is dead as well as the noisy bearings, so I can’t see how it would throw a load of errors that it isn’t already entitled to throw. If traction control tries to run the rear differential then it won’t get a response. If I get the traction control excited - eg if it goes a bit lighter over a hump back bridge, it cuts the power for a second then calms down and carries on.
