Past hour
- 1.4 TDi Spluttering and Loss of Power When Up to Temp
Bet
Possibly rainwater from air intake in front of windscreen - check that scuttle drains are clear.
Warrior193 started following Bet
Today
Tyre Pressure Sensor fault when tyres changed
No there is no pressure limit shown, just an orange symbol on the dash indicating that the rear offside tyre has lost some pressure.
Reset through the infotainment under the car settings, tyres menu, not the dash display. Set all four to the door placard cold pressures, store them, then drive normally so it relearns. Also measure the old tyre's tread against the new ones, a few mm difference can trigger this system.
SteadyDiesel started following Tyre Pressure Sensor fault when tyres changed
SteadyDiesel joined the community
And lunchtime task - mirror replacement as the folding mechanism had failed on my passenger side. I picked up a whole second hand unit with glass from eBay for £49. This task also took on a couple of side quests along the way. The main task is relatively simple - door card off, remove the tweeter holder (this is actually quite tricky as it has two catches and a peg) then remove the triple spline bolt. Obviously this was a size I didn’t have so had to make do with a t50 Torx (triple spline set now on the Christmas list!) While the mirror was off I took the opportunity to wrap the chrome fully beneath the mirror base as I had just cut in around it previously. Refitting the mirror is quite tricky to tuck it in beneath the window trim without catching wires etc. Once that was back in it was then over to the nerve wracking task of removing the glass to swap the mirror cap to black. Using the T10383 disassembly wedges https://amzn.eu/d/058oQqMX made it significantly easier as the width of them spreads the force out and makes it much less likely to break the glass. Then in removing the original mirror cap a couple of clips broke due to the cold weather I think. Luckily these were intact on the old mirror unit so another side quest of swapping over the front mirror frame. I warmed it slightly with a heat gun when refitting the mirror cap the second time to avoid broken clips! With the door card off I also noticed a broken plastic rivet that holds the umbrella slot in place and hopefully the source of an annoying door rattle. This was glued back in to place before the door card was refitted. Now all back together with a working folding mirror as well as the bonus of heated and dimming mirror glass. All finished in 45 minutes.
Radio stations Logos database updates
I posted this on the Troc forum may apply here: Good news. It appears that [email protected] has replaced their original "MQB3_JND_Europe_v1.31.70.zip" with a file that has a few bytes more. Anyone that has had "Software update interrupted" should now try the download again. The file is still "v1.31.70 from 24.09.2026" but new! IT WORKS!
Rocky53 started following Radio stations Logos database updates
@skomaz I have had the opposite experience when doing it to prove a point to people that did not believe you could run different t pressures or sizes on FWD VW group cars. And running different sizes myself front and rear on MK2 Fabias.
If you have a full size spare put that on and see if it makes any difference as the chances are its new if you only done 13k. Tyres dont seem to last as long these days and tend to crack with age. I always replace mine when I see any cracks. If you dont have a full size spare maybe buy a full sized rim and put the part worn tyre on it and get a new tyre. Alasdair
Alasdair1 started following Coolant level warning mystery and Tyre Pressure Sensor fault when tyres changed
- Coolant level warning mystery
ABS fault codes in VCDS but no warning light.
Cleared codes, another test drive. ABS faults did not come back. I'll just monitor things and see if they return Panic over.... Fats
Mark-d-2013-wagon joined the community
Memory seat controls not working
Weird one this, we have a 2025 2.0 tsi sportline estate, and recently the memory buttons on the driver seat have stopped working. The other seat controls (forward/back etc) all work with no issues, and the car no longer changes the seat position depending on who gets in. It maybe a coincidence, but I only noticed that it had stopped working when we had it detailed recently. Are there any plugs/cables etc under the seat I can check and see if something got pulled out while the interior was being cleaned? Thanks
Agreed. But experience tells me that even doing that and resetting the TPMS it'll sometimes eventually throw a warning on a long journey.
- Fabia 2024 SE comfort mpi fault
Hello from France!
Hello everyone, I’m thrilled to finally join the Briskoda community! I’ve been browsing the forum as a guest for a while now, and the amount of useful information here is incredible. Here’s a brief introduction: • Where I live: I live in France. • My car: I drive a 2026 Škoda Fabia IV with a 1.0L TSI engine in Monte Carlo. • Color: RED. I’ve owned this car for 8 months and I love it so far. I joined the forum to learn more about maintenance tips, the MIB3 infotainment system, and general advice. I look forward to chatting with all of you and sharing our experiences! See you soon, Pheon1x19
PheoN1x19 started following Hello from France!
PheoN1x19 joined the community
Firmware Request MST2_EU_SK_ZR_P0480T
Hello! I'm looking for the MST2_EU_SK_ZR_P0480T file to update my Amundsen MIB2. I currently have P0456T with display and sound errors. Can someone help me?
Mike-74 started following Firmware Request MST2_EU_SK_ZR_P0480T
A quick tea break job of replacing the broken plastic trims on the rear bench so the red flag pops up properly. Worst bit was retrieving the old broken clips so the new trims would fit. New parts from skodapartsdirect.co.uk
Mike-74 joined the community
As to the original tyre size being the issue and a different circumference. Simples if not directional then swap to other rear side and reset the TPMS and see if warning changes. If so then no question best replace that tyre.
Direct TPMS was available on some models as a cost option - but indirect (ABS) type is more likely on your vehicle. Presumably your TPMS does not display actual tyre pressures ? - if not, your system is indirect type.
Warrior193 started following Tyre Pressure Sensor fault when tyres changed
You can fit a different tyre like a spare or even have tyres at different pressures so total diameter / circumference and set the TPMS to remember that and get no TPMS warning if no change after set. Try it. It is how it is. You do not need to have a constant TPMS warning while running a little mis-sized spare wheel as Skoda sells / supplies.
Ok - just finished a short test drive and checked speed of wheels - all 4 were virtually identical at different sustained slower speed. Could it be an intermittent fault arising from the pick up ring on the bearing having some rust/contamination? Just trying to get an idea before having a look or asking local garage. Fats
If it takes ages to warm up it could very well be the thermostat thats past it. My old Octavia was the same. Not bad in summer but cold weather took ages and just made it to 90 after a long hard run(normally sat at 60-70 and it would noticeably drop the minute I let car idle). Changed it and it was fine after that. Reckon your right in changing temp sensor at same time to rule it out. I would do the above first and if no improvement maybe EGR valve clean and check wiring loom to injectors. If the loom is dodgy it could be affected by hot temps and cause misfire etc. Alasdair
Boot latch
Hello got a 2013 Skoda fabia mk2 1.2 SE 532 Just got the thing boot latch died right after I got it . fitted a replacement (not OEM mind you) now I have a door open check light on no matter what I do. I have moved the thing and 8 times same with the holding pin plate on the bottom no luck same light and boot light on. The thing catches and closes but the latch will not move all over to full closed position make contact and get rid of the lights. Any mods and tips welcome
Incorrectly Identified NSL Speed Limits
@stepred My best guess is that it's something to do with Traffication. It's not the raw map data as I've verified that's correct with the online version. It's also not the camera, as it happens where no signs are present. So I can only guess that Traffication is maybe adding in what it thinks is "live" data, possibly from long since removed roadworks. But even that is questionable given that roadworks rarely have a 20 MPH limit. If by any chance your Traffication is coming up for renewal, maybe let it lapse & see if the issue goes away. Unfortunately I renewed mine in the belief that Skoda Connect knew what they were doing when they said they had a fix...
