the truth about electric cars
What so many of you all are wilfully ignoring is the many Luddites, as you call us (which is disrespectful; we don't call you evangelists, do we?), are that we can see that BEVs or something similar will eventually take over as the fuel of the future. There is plenty of evidence of that being the case, other than the one that you all keep eluding to, that of global warming and its causes. You all love to claim that it is the result of us burning fossil fuels and putting toxic emissions in the air, when there is evidence to suggest that actually is not true at all. Let's look at the one that so many of you keep referring to, that of air quality leading to loads of premature deaths as a direct result of tailpipe emissions. So how do you square that with the fact that life expectancy has risen dramatically over the years? It is a fact the UK has far better air quality with lower PM. 2.5 in the air than Hong Kong, which also has a far higher average temperature than the UK. UK life expectancy is 80.208 as opposed to Hong Kong's figure of 85.68 years. I was born in 1949, and following the graph across, I have already exceeded the expected life of 1950 by something like 2.5 times that figure, hmm. The UK has an average of 8-11 microg/m³ of PM2.5 compared to Hong Kong's average of 15-17 microg/m³ of PM2.5. The UK has 2.1M BEVs, while Hong Kong only has 80,000. The average annual temperature for the UK is 10°C, while for Hong Kong it is 23°C. Density of population per sq. kilometre: UK = 258; Hong Kong = 6,755 So the UK has an annual lower temperature, better air quality, lower population density and far more BEVs but a way shorter life expectancy. Hmm, something is not quite adding up to support the claims that more BEVs, fewer emissions, etc. Clearly, there are other factors at play here.
G65 sensor no signal
Code reader showing no signal to both G65 & Air quality sensor, I’ve replaced both sensors with Skoda parts from dealership and still error code is showing, Aircon is non operational. Any help would be appreciated
Cajk started following G65 sensor no signal
BBZ Fabia Having a Meltdown
Might do - I had similar codes and limp mode on a Civic Diesel I had a number of years ago that I could never seem to get to the bottom of, assuming it was a MAF sensor issue - until I found that someone had failed to replace the air filter when it was serviced and hence it had been in there a long time - a new filter and no more codes!
LIMP MODE ISSUE
if is a 1.2 tsi cbz my suggestion is that it could be a coil pack, look also for the ignition leads, being a 2015 it could be already equipped with the upgraded one (the difference is the heat sheild on the cable), a known fault that can cause a limp mode is the turbo actuator, in my 2013 fabia a faulty coil pack and later a worn spark plug never caused a limp mode 'just' the epc light followed by tcs ecc., (a completely worn ignitoin lead did cause a limp mode once). A faulty wheel sensor normally dosent cause a limp mode, in my fabia I've broken one wile replacing a front wheel bearing and no limp mode just abs tcs tpms warning, also on a 2016 octavia scout 2.0 tdi 184 bhp a snow chain sliced the wheel speed sensor causing all sorta of faults but again no limp mode.
Jack25 started following LIMP MODE ISSUE
Software Update available for Bolero?
Hi all, I heard that Skoda have released a bug fix update after 1800, 1804/1806. Is that available with anyone here? If yes, can you please share the link for the download?
Oil filters
What make of oil filter do skoda use as standard, Bosch, Fram, Mahl, VAG or are they specifically marked Skoda.
royread started following Oil filters
Indeed. Salary sacrifice does not always look great as those quoted deals don't seem to be anywhere near what the tax relief should provide. We, at Bollore and CMA/CEVA were told we were going to get SS EV deals but time passed and they never materialised. The EV grants have been nice from both the Con government and current government but both are icing on the cake and I was always buying cake rather than bread (ICE). ICE cars loads of bread to run and don't taste as nice to take the analogy a bit too far.
GIULIO joined the community
khcup joined the community
royread joined the community
my wife looked at salary sacrifice and worked out that because it included tyres and maintenance costs it was actually cheaper to buy cash and haggle. My employer refuses to provide salary sacrifice.
Like climate denial there are those that cannot see the clear mass of evidence in front of the them for what ever reason. BEVs are already great and improving rapidly. ICE cars are pretty much stuck in the doldrums. As my fellow converts we gave driven ICE for decades, in my cases done about 1M miles and owned about 50 of them. Sadly many Luddites still around or maybe it is an initial purchase, credit obtaining thing but clear to me that BEVs are the future, whether that is LFP, Na or whatever battery chemistry. I too am tired of this thread and will try and not contribute any more as it seems flogged to death. Am looking forward to even cheaper running from October 1st though when VAT on charging at home goes to zero. Just bought £33 public charge charge from Gridserve so about £5 VAT, not nice compared to home.
Same here, no deals or bungs on my car and my wife bought hers without any offers. She haggled on price but you do that with any car. In our street we have 2 Skoda Enyaqs, 1 cupra Born, one ID3, a Kia EV9, Kia E niro, a ford mustang, a nissan leaf, peugeot e208 a Ford Capri, and en e corsa. That's a street of 17 houses. Of that lot the EV9 is the only one that is a company car
Amundsen Sat Nav Total Failure
As you are probably aware 'Unbranded' SD cards will not work with the MIB2. When you had the problem with the original card, did you try ejecting and re-inserting it in the slot?
Breakdown
It sounds similar to the issue we had with our Fabia mc 2023 bought from new from Johnson's Skoda. There have been three frightening occasions when just about all power was lost - potentially fatal on a slip road or busy island. I have posted about this at length a couple of month back but the forum is poor when it comes to finding threads. I think it's inexcusible that there has been no recall and that dealerships lack the common sense to check that important software updates have been applied. The update in question came out a couple of years ago so it is a known issue. However, VW are not known for being straight with customers - remember Dieselgate. The dealership and the forum proved of no useful help. It was suggested that the battery would need frequent charging due to most of our journeys being short. I bought a suitable charger which made no difference and had an AGM battery fitted. On my last visit to the dealership they tried to sell me a new battery and then a new car. The Fabia broke down for a third time but I had found out that the AA have "silver service vans" with technicians and equipment tailored for VAG group cars. They are trained to a high level for Skoda cars. I requested that we have such a van sent to our home address. The technician knew what the problems was almost immediately. There's been a software update available for a couple of years that fixes the issue which relates to the throttle body settings. Cables like we had with carburettors have been superceded by electronic controls with sensors. After half an hour was spent updating the car's software we were assured said that the issue wouldn't happen again. The technician also said the battery had nothing to do with it. So far so good but we are still recovering from Fabia anxiety. The only reason I'm on here today is that the dealership just emailed me to attend an event as a VIP customer. I don't think so!! The service manager told me to get out and take my car somewhere else when I became very annoyed with their failure to sort the car's issues. Their diagnostics failed to find an issue so how can you fix a car that's perfectly OK? I will add one positive in that the manual gearbox Fabia mc if fully updated is very good to drive. The Fabia is not likely to continue in production as VW group are starting to feel the pain of strong competition from Chinese manufacturers. We have decided to keep the car but it will be serviced by our local garage rather than a main dealer.
DSG in Traffic
We own both dry and wet clutch DSG cars, 2015 and 2023 respectively, the 2015 dry clutch doesn’t have autohold only hill hold, so the operation is not identical, the dry clutch car is fractionally slower engaging the drive from stationary, but creeps on idle sand as the wet clutch car.
High Beam Control (Light Assist)
hi i been facing same problem after purchase my mobile app show activated ,shop app in car show activated but no Light assist button in menu skoda support keep sending me to dealer i contacted 3 around me but no response. i got HW : 5WA937086K 016 SW : 5WA937086R 0136 DATASET : V03935324EA 0001 I compared my backup in VCTool what i found was in central electric09/adaptations/LCM/Expanded High beam control/ i got basic configuration where other backups with basic LED they had high beam lights assistant and when i tried to change it i couldn't because function not available that backups has V03935356TC/V03935356TX datasets and SW 0136/0137 so i bought VNCI6154B + VCTool (needed for reverse camera retrofit anyway) requested stock data and dataset was V03935356TX with all calibration etc. 2min flash and central electric09/adaptations/LCM/Expanded High beam control/high beam lights assistant was there light assist button appear in menu
milloo24 started following High Beam Control (Light Assist)
was just about to say the same
'Sleep package' rear headrests
I bought a pair from Skoda Parts as I've used them before, took less than a week to arrive. They're slightly wider than the normal ones......
Unfortunately it isn't, I've ordered a branded sd card with latest maps. I've read that the branded ones are coded. I'm hoping that the replacement card will resolve the issue.
How do I save the settings?
Which simply highlights the idiocy of Skoda's approach.
DSG in Traffic
The coasting function is slightly different on later models. On my 74 plate it only operates when in 'Eco' mode, on my earlier 71 plate it operated in 'Normal' & 'Eco'
NottsIan started following DSG in Traffic
2017 Yeti value ?
Just dropped you a DM 👍
Came across an old post from 2020 with BBY engine codes P1553 and P1504 with same symptoms as yours. Sorry cant seem to post link but he had done a major overhaul on engine and it started and ran then got the codes with EPC,ASR Idle all over the place and no response from throttle. Eventually they did the following and it cured it. It was solved by resetting the ECU to factory defaults by writing value 00 to channel 00 in the engine control module. A bit above my zone but might work Alasdair
Alasdair1 started following BBZ Fabia Having a Meltdown
DSG in Traffic
I've noticed it coasting at times. Going downhill engine braking disappears when it happens 😲
DSG in Traffic
Cheers. I grew up there and lots and lots of family in Macduff and Banff. Anther thing about DSG,s is if there is 'Coasting Function' and if enabled or used.
DSG in Traffic
Do you happen to be in Macduff No, but I do go there on occasion 🙂
