Whats the latest MO13 software available?
Anyone?
Hubertt joined the community
2012 to 2019 Superb Refresh
Agreed, I do like the full LED lights, I can also update it as and when releases are available if needed with my diag unit. I get your point though.
Not keen on that colour personally and I don’t like the look of the facelift model as much. MIB3 as well which can be quite buggy
Octavia water pump
Depends where you are, as I’m based in the South East. Drop me a message!
Jack Point
Damn - that’s surprising, sorry. I know Awesome GTI and Powerflex themselves don’t have them, but you should be able to get them. Is there any word on how long?
https://www.autotrader.co.uk/car-details/202610167041901?utm_source=share&utm_medium=ios-app This is the low mileage one. Anyone on here recognise it? A proper history background would be nice. But then it doesn’t have the other options, the paint needs a pro mop quoted starting from £700 depending on scratch depths and damage. Looks good in the photo, but up close so disappointing. And it’s a bit too bling, I’m more for an understated paint job. Electric blue, I thought it was Cobalt blue. Think Audi called this Nogaro blue on the RS4 B5 I had a midnight blue S4 as even then the nogaro was too bling.
MikeTheThinker started following VAG Diagnostic
Perhaps see if you can negotiate them fixing the advisories if you pay asking price. Make sure you show us some pics if you do buy one!
- VAG Diagnostic
Infotainment don't recognize status of ignition
Glad you got it sorted and impressed on the effort of coming back after 4 years to post the solution!
Binx1310 started following Infotainment don't recognize status of ignition
Personally I’d go with higher mileage for the options.
hebi123 started following VAG Diagnostic
VAG Diagnostic
Hi! 🚗 I'm looking for people with a VW / Audi / Škoda / SEAT / CUPRA to test my VAG Diagnostic app (Android). So far I've mostly tested it on a bench with a simulator, and now I need readings from real cars. The test version only reads data: it detects control units, part numbers and fault codes. It does not clear faults, code anything, or change any car settings. The test takes about 10–15 minutes. What you need: • an Android phone, • an ELM327 Bluetooth OBD adapter (e.g. Vlink); Wi-Fi adapters won't work, • a VW group car, ideally from around 2012 onward (Golf 7, Octavia III, A3 8V, Leon III and newer). Older cars are useful too. 📥 Download the app: https://drive.google.com/file/d/1-jvtmcPDvu_mjCv1VXyD7VxkI3PqVS8l/view The current version is tester-2 from 4 November. The app is available in English, German and Polish, and it automatically switches to your phone's language. How to run the test: 1. The car is standing still, ignition on, and the adapter is in the OBD socket and paired with your phone. 2. In the app, tap the OBD connection card at the top, then "Connect" next to your adapter. 3. Choose "Full diagnosis." The first time, press "Activate PRO test" (it's free, you're not buying anything), then press "Full diagnosis" again. 4. Press "Run Auto-Scan VAG UDS," then "Run full Auto-Scan UDS," and wait until it finishes without locking your phone. 5. Press "Show result and fault clearing," take screenshots of the result, and go back with the arrow. 6. Press "Copy diagnostic log" and paste it to me in a private message or by email at [email protected]. Add the car, year, engine, gearbox and adapter. 🔒 The app masks the VIN and serial numbers in the log by itself. In the screenshots, cover the VIN if it's visible. Please send logs to me privately, not to the group. ⚠️ Don't use clearing in "Engine diagnostics" or "OBD Terminal," since Auto-Scan is enough for this test. Scan only with the car standing still. If you have VCDS, OBDeleven or Carista, please also send a screenshot of their fault list. That comparison would help me a lot. A log from a failed scan is valuable too, so send it freely. Thanks for your help! 🙏
Kodiaq steering wheel vibration
So now you got no vibration at all?
First of all, thanks for all the input in this thread. I know it's been a while, but I finally found the root cause of the problem and wanted to share my findings. The problem turned out to occur almost exclusively on hot summer days. I suppose that explains why it didn't happen very often, considering I live in Sweden! Then the car started draining the battery. When I measured the current draw, I discovered that the infotainment system was consuming power even when the ignition was switched off. At the same time, the infotainment fault was still present. You were right that the problem was related to the CAN bus for the infotainment system. When I scanned the control units, the infotainment unit wasn't even detected. When I measured the CAN bus at the back of the infotainment unit, there was no voltage. About two years ago, I had problems with the electric tailgate actuator. Back then, I discovered broken wires in the moving wiring harness near the actuator. So this time, I removed the rubber boot for the bigger cable harness and found several wires with cracked insulation and broken conductors.
leklivet started following Infotainment don't recognize status of ignition
So the low mileage one 25K is 1K GBP more, built within a few months of each other Doesnt have DSG paddles, road sign recognition camera, drivers seat massage and has 19 inch rims rather than 18s. Massive difference in price and I have a trade account with a massive tyre wholesaler. The higher mile one has the above options 1K less but digging into its history, it had a cracked sump and lost oil to point red pressure light was noted but immediately turned off. Sump was replaced at a dealer and no issue reported since. Has the much cheaper tyres better colour but note on last mot for front lower arm bushes rear worn but not displaced or causing excessive movement. Im going to buy one or the other this weekend unless something else comes up.
Software update groundhog day
Hi, Take a look at the thread I've mentionned in Superb Mk3 forum. Problem solved for me with version 339 or so (see one of my last messages).
Scout Owners Register
1. No Waiting / Storm Blue / 2.0 TDi PD / MY09 (Pre-facelift) 2. andyjl1968 / Anthracite Grey / 2.0 TDi PD / MY07 3. Nick_H / Arctic Green / 1.8 TSi / MY11 4. dekka48, / Black Magic,/ 2.0 TDi PD / 2008 5. skodal / Anthracite Grey / 2.0 TDi CR / MY11 / Hopefully September!!! 6. foo / Anthracite / 1.8 TSi / 2009 7. Stuart / Arctic Green / 2.0 TDi PD / May 2010 8. NikNak / Anthracite Grey / 2.0 TDi CR / MY11 / Delivery around August 2010 9. Constant / Brilliant Silver / 2.0 TDi PD / Jan 2008 10. Gaz196 / Black Magic / 1.8 TSi / MY11 Sept 10 11. GGG / Anthracite Grey / 2.0 TDi PD / May 2010 12. Pedro Pete / Anthracite / 2.0 TDi CR / Arriving end Sept? 13. Inego / Brilliant Silver / 2.0 TDi PD/ Jan 10 14. Kumquat / Satin Grey / 2.0 TDi / Nov 2009 15. CEPi / Cappuccino / 1.8 TSi / Apr 2010 16. sparky2 / Satin Grey / 2.0 TDi PD / July 2009 FL 17. Normcall / Red / 1.8 TSi / 2009 18. username taken / Black / 2.0 TDi PD / June 2010 19. RandyAxion / Cappuccino Beige / 2.0 TDi PD / November 2012 (delivered next week) (American in Germany) 20. rkenny / Satin Grey / 2.0 TDi PD / March 08 21. GroundHog / Satin Grey / 2.0 TDi PD / MY08 22. Captain Kremen / Satin Grey / 2.0 TDi PD / 2007 07 23. ralle / Cappuccino / 2.0 TDi PD / 2007 57 24. atkinsong / Candy White / 1.8 TSi / May 2010 25. uscouter / Cappuccino / 2.0 TDi PD / March 2010 26. Eddie Deguello / Anthracite Grey / 2.0 TDi CR / Sept 2010 27. London Les / Satin Grey / 2.0 TDi CR / Wk 33 Sept 2010 / Alcantara / Xenon AFSII / Spare / Silver Rails / MFSW / Maxidot / Curtain Airbags / MDI 28. Scouter2 / Brilliant Silver / 2.0 TDi PD / Apr 2007 29. harrylime / Cappucino Beige / 1.8 TSi / January 2010 30. Mark999 / Dynamic Blue / 2.0 TDi PD / May 2010 31. Magicknight75 / Black Magic / 2.0 TDi PD / Apr 13 / Standard Skoda spec / Full Size Spare 32. Niall / Satin Grey / 2.0 TDi PD / May 07 / All the Scout standard toys / Xenons / MFSW / Maxidot / Curtain Airbags / OEM Bluetooth 33. Jeeves / Anthracite / 2.0 TDi PD / Feb 2010 34. Niall / Satin Grey / 2.0 TDi PD / May 07 / Standard Skoda spec / Full Size Spare 35. Wilkopilko / Brilliant Silver / 2.0 TDi PD / June 2007 36. Utarg / Anthracite Grey / 2.0 TDi CR / Just been told I can pick it up 17th July! / Alcantara / Spare / Maxidot / MDI 37. Finbarsko / Satin Grey / 2.0 TDi PD / 57 38. ScruffyBadger / Brilliant Silver / 2.0 TDi PD / June 2008 39. Unclelatch / Anthracite Grey / 2.0 TDi PD / June 2010 / MFSW / Maxidot 40. BOBW / Cappucino Beige / 1.8 TSi / May 2010 41. Simon Cobb / Cappuccino Beige / 2.0 TDi CR / Fully optioned apart from MDI and Satnav 42. AuScout / Satin Grey / 2.0 TDi PD / Oct 2008 43. royskie / Red / 2.0 TDi PD / November 2007 44. Bill Blake / Rosso Brunello / 2.0 TDi / Jan 2010 45. downes martin / Rosso Brunello / 2.0 TDi CR / MY 2011 46. Monnae / Corrida Red / 1.8 TSi / MY 2011 47. silver1011 / Black Magic / 2.0 TDi PD / August 2008 / Xenon's 48. billycann / Candy White / 2.0 TDi PD / Dec 09 (facelift) / Raised Boot Floor / Spare Wheel. Really wish I'd remembered Xenon's and Maxidot! 49. Lasseson / Black Magic / 2.0 TDi CR / Delivery Dec 2010 50. Scout60 / Grey Anthracite / 2.0 TDi / 60 Plate 51. Essm / Silver / 2.0 TDi / Nov 2008 / Lots of extras / OEM Bluetooth 52. krimat t/ Cappucino Beige / 2.0 TDi CR / Delivery Dec 2010 53. Fin69 / Anthracite Grey / 2.0 TDi PD / July 2010 54. Snala / Brilliant Silver / 2.0 TDi CR / NZ spec / MDI / Hill Hold / LED DRL's / Oct 2010 55. Thorfinn / Corrida Red / 2.0 TDi CR / October 2010 56. Badgersport / Candy White / 2.0 TDi CR / October 2010 / Polished Proteus Wheels 57. eenymac / Anthracite / 1.8 TSi / March 2010 58. Scuderria / Cappuccino Beige / 1.8 TSi / MY11 (expected in March) 59. Jawsnpaws / Satin Grey Metallic / 2.0 TDi PD / April 2008 60. lard-ajc / Anthracite / 2.0 TDi PD / June 2008 61. Carpus / Anthracite / 1.8 TSi / Sept 2010 62. egide / Satin Grey Metallic / 2.0 TDi PD / May 2008 63. JJBS3 / Rosso Brunello / 2.0 TDi PD / Jan 2010 (Remapped at REVO, much better!) 64. Greenie58 / Brilliant Silver / 2.0 TDi PD / July 07 65. Browny / Black Magic / 2.0 TDi CR / On order... 66. Slimboyfat303 / Silver / 1.8 TSi / 2011 67. az12d / Cappuchino Biege / 2.0 TDi / 59 Plate / Awaiting new one in Feb 11 68. 6nations / White / 2.0 TDi / Arrived June 2010 69. Scoutel / Cappuccino / 1.8 TSi / January 2011 70. London_Jock / Pacific Blue / 2.0 TDi CR / Ordered Dec 10 / Expected build May 11 71. 27motorhead / Cappuccino / 2.0 TDi / March 2008 / Bought from Marlborough Skoda in August 2008 / Ex-Sales Managers car 72. Fatlip / Anthracite / 2.0 TDi / 1st Feb 2011 / Yipee! After 7 months wait! 73. alannfrost / Safari / 2.0 TDi / DSG / Arriving early June 2011 74. Speedy_Gonzales / Anthracite / 1.8 TSi / Ordered 06/02/11 delivered 15/06/11 / Polished Proteus Alloys / Multi Function Steering Wheel / Maxidot / Spare Wheel 75. Trenca / Candy White / 2.0 TDi PD / FL February 2011 / Xenon's / Folding Mirrors / Towbar 76. Scout Master / Rosso Brunello / 1.8 TSi / Most extras ordered except Sat Nav / Ordered Aug 10 / Delivery 1st March 11 (hopefully). 77. Cullenator / Cappucino Metallic / 1.8 TSi / Black Leather Interior / June 2010 78. scousemouse / Black Magic / 1.8 TSi / Arriving June 2011 79. m1cvt / White / 2.0 TDi PD / March 2010 80. Placey / Black Magic / 2.0 TDi / Mar 08 / Soon getting a new one the same in April... 81. Zippy / Steel Grey / 1.8 TSi / Due August 2011 82. theptyboy / Black 83. stevo1 / Brilliant Silver / 2.0 TDi PD / Nov 2007 84. steviehg / Aqua Blue / 2.0 TDi CR / Sunroof / VBF / Maxidot / Ordered 16/11/2010, Last update 29 weeks 85. rosswm / Brilliant Silver / 2.0 TDi / July 2007 86. mlp / Anthracite Grey / 2.0 TDi CR / May 2011 87. scoutabout / Storm Blue / 1.8 TSi / May 2011 88. Uncle Bulgaria / Cappuchino / 2.0 TDi CR / DSG / May 2011 89. Anddenton / Anthracite Grey / 2.0 TDi PD / May 2008 / Maxidot / Multi Function SW / Xenon HID's / Columbus SN / Bluetooth / MDI / Headlight Brows / LED DRL's / Blue LED Interior Lights / De-chromed Badge-less Grill 90. Jasper13 / Brilliant Silver / 2.0 TDi CR / DSG / Polished Proteus Alloys / June 2011 / Had to wait 6 months but love it now its here! 91. Tonyp5a / Anthracite / 2.0 TDi CR / Polished Proteus Alloys / July 2011 92. sandal farm / Red / 2.0 TDi / Polished Proteus Alloys / July 2011 / Ordered Nov 2010 93. Carabus901 / Black / 2.0 TDi / Polished Proteus Alloys / Jul 11 / Ordered Dec 10 94. Turboscout / Black / 1.8 TSi / July 2011 95. biker123 / Red / 2.0 TDi / 2008 96. Octapuss / Aqua Blue / 2.0 TDi CR / DSG / June 2011 97. scoutdave / Storm Blue / 1.8 TSi / 2010 (owned from Aug 2011) 98. lamlash / Satin Grey / 2.0 TDi CR / Oct 2011 / No Extras 99. jpgb / Safari / 2.0 TDi CR / DSG / 2011 100. diesel steve / 2.0 TDi / Rosso Brunello Red / June 10 101. stringbean / Rosso Brunello Red / 2.0 TDi CR / December 2011 / Maxidot / MFSW / Xenon's / LED DRL / Curtain Airbags / Spare Wheel / Polished Proteus Alloys 102. Scoutmaster / Aqua Blue / 2.0 TDi PD / June 2010 (owned from new) / Sat Nav / OEM Bluetooth / Maxidot / MFSW Xenon's / Alcantara / Electric Seats / Curtain Airbags / Full-size spare / Raised Boot Floor / Shark Remap 103. indianinorge / Corrida Red / 2.0 TDi CR / MY 2012 / Webasto / Amundsen Sat Nav / DAB / Delivered for Christmas 🙂 Can't take the smile off my face! 104. Locheil / Silver / 2.0 TDi / May 2007 / (2nd Owner, 63K miles, FSH etc.) / Xenon's / Curtain Airbags 105. smurfster / 2.0 TDi / May 2007 / 104K miles 106. Samwise / Dark Metallic Green / 2.0 TDi / July 2008 / 41K miles 107. rz67 / Satin Grey / 1.8 TSi / October 2011 108. Scuff / Rosso Brunello / 2.0 TDi / Oct 2010 (2nd owner / 12K miles) 109. Tattster / Brilliant Silver / 2.0 TDi / June 2008 110. DoggieScout / Safari / 1.8 TSi / Sept 2011 (ordered March 2011) 111. Danrock101 / Grey / 2.0 TDi PD / 57 Plate 112. Shooter / Anthracite Grey / 2.0 TDi / Xenon's / Sat Nav / Leather / Heated Seats 113. Dr Dom / Black Magic / 2.0 TDi PD / 57 Plate 114. You pies / Athracite Grey / 2.0 TDi CR / Sept 2010 / Shark remap, fantastic drive now 115. Scoutfox / Cappucino Metallic / 1.8 TSi / Feb 2010 116. Howardian1 / Brilliant Silver (tho' rarely clean enough to tell) / 2.0 TDi PD / June 2008 / Private Plate / Proteus rims in summer / Spitzberg rims in winter / Leather & Alcantara / MFSW / Maxidot / Xenon's / Sat Nav / Brink Towbar 117. BigLad01 / Beige / 2.0 TDi PD / Jan 2008 118. mountainandsea / Brilliant Silver / 2.0 TDi CR / 2012 / Maxidot / Xenon's / Columbus / Full Size Spare 119. Paddypaws / Black Magic / 2.0 TDI CR / Apr 2013 / Spare Wheel 120. Andy_G7KNA / Anthracite Grey / 2.0 CR TDi / Manual / Apr 2011 / Used purchase (May 2013) / Xenon's / Folding Mirrors / Maxidot / Electric Seat / Full Size Spare / False Boot Floor / Dog Guard / Curtain Airbags 121. parisbun / Brilliant Silver / 2.0 TDi CR / October 2010 122. lmf / Cappucino / 2.0 TDi PD / MY 2008 123 raincloud / Black Magic / 2.0 TDi CR / Sept 2010 / 60 Plate 124 marekczek / Silver / 2.0 TDi PD / 2007 December / Pre-facelift / Xenon's / Leather Seats / Heated Seats / Parking Sensors 125. ScoutDMC / Red / 1.8TSi / October 2010 126. Fiko / Black Magic / 2.0 TDi CR / MY 2011 / First reg. 11/2010 / LHD 127. Mondorich / Dark Blue / 2.0 TDi PD / August 2007 MY08 / Added RCDD310 DAB Nice! 128. AndyGScout / Anthracite / 1.8 TSi / March 2013 129. RainbowFire / Satin Grey / 2.0 TDi PD / May 2007 / MFSW / Maxidot / Xenon's / Towbar / Auto Tailgate Lift / RNS510 plus RVC / LED Footwell Lights / Puddle Lights / Number Plate Lights / Front Side Lights / Interior Lights / 30 Byte CECM / AF Gateway / Front & Rear Cameras / Heko Wind Deflectors / 2013 Centre Caps & Badges / BRISKODA sticker in rear window! Traded for a18 plate 1.5 Golf eco thingy estate. - Gone, but not forgotten. 130. nidgep / Brilliant Silver / 2.0 TDi PD / Mar 2008 131. MarshallTractor / Storm Blue / 2.0 TDi PD / July 2007 / OEM MFSW / Auto Lights / Xenon's / Light Protectors / Rain Sensor / Towbar 132. Pete / Silver / 2.0 TDi PD / 04/2007 / Auto Lights / Xenon's / Rain Sensor / Towbar / Columbus / Full Size Spare 133. Bengas / Anthracite Grey / 2.0 TDi PD / Oct 10 / RNS 510 134. Sax0ndale / Grey (Blue) / 2.0 FSi / Nov 08 135. Jdukvrs / Race Blue / 2.0 FSi vRS / Feb 2007 136. AjeMan / Grey / 2.0 TDi PD / 08 Plate 137. Redscout / Red / 1.8 TSi / 09 plate 138. thesparky / Dark Blue / 2.0 TDi CR / Dec 11 (61) 139. Hendred / Capuccino / 2.0 TDi / 57 Plate 140. FrankieKitt / Brilliant Silver / 2.0 TDi CR / March 2013 141. zar / Silver Grey / 2.0 TDi CR / 2010 142. hawkwind / Silver / 2.0 TDi PD / 58 plate 143. Sydney / Black / 2.0 TDi PD / Sept 2007 144. northturton / Anthracite / 1.8 TSi / 2010 (10) 145. Marge / Storm Blue / 2.0 TDi PD / 2008 MY (58) 146. Innes / Black Magic / 2.0 TDi PD / 2009 (09) 147. Britbusdriver / Storm Blue / 2.0 TDi / 2007(57) / Xenons (good) / Rain Sensor (bad) / maxidot / MFSW / Bolero & Bluetooth / Variable Boot Floor 148. LV11 / Safari / 2.0 TDI / DSG / Apr 2011 / every option except Columbus SN and phone prep 149. verysideways / Silver / 1.8 TSi / Jan 2010 150. pie2211 / Diamond Silver / 2.0 TDi / 2008 MY (57) 151. MantaDave / Brilliant Silver/ 2.0 TDI PD / 09 152. johnarlis7 / white / 1.8 tsi / 2010 153. NicNac / Anthracite Grey / 2.0 TDi / 2008 (58) 154. claudiu2s / Storm Blue /2.0 TDi CR / 2011 155. jimbomk2 / Sahara Beige Metallic / 2.0 TDi CR / 2011 156. Gordy873 / Polaris Silver / 2.0 TDI CR / now 175bhp / 2011 157. pw1969 / Artic Blue / 1.8 TSI / 2010 158. Seedy Jay / Arctic Blue / 2.0 TDI CR / 2011 159. Sean.Mulcahy / Grey / 2.0 TDI CR / 2012 160. cardaft / Anthracite Grey with Red Leather / 2.0 TDi / 2007 161. eyelash / Black / 2.0 TSI / 2008 162. Pumpkin_PL / Cappuccino / 2.0 TDI PD / MY10 163. Mustang86 / Anthracite Grey / 2.0 TDI CR / 2010 164. jetkarcsi / Grafite Silver / 2.0 TDI CR / 2013.05 165. twostrokemick / Blue / 2.0 PD BMM / 2008 166. drewdt3 / Blue / 2.0 TDI CR / Jan 2012 167. mick562008 / Anthracite Grey / 2.0 TDI PD / 2010 FL 168. drewdt3 / Storm Blue / 2.0 TDI CR / 2012 169. Jimbo / Anthracite Grey / 2.0 TDI / 2012 170. BushcraftChris / Candy White / 2.0 TDI CR / 2012 / Powder coated wheels (the way forward!) / Parrot CK3000 / Bolero / Full size spare / Low boot floor / Curtain Airbags / Rain Sensor / Cruise Control / But no passenger handle above glovebox 171. Dansidi / Black / 1.8 TSI / 2011 172. assettt / Red / 1.8 TSI / 2009 173. Bexlee / Black / 2.0 CR / 2013 174. JJBS3 / Meteor Grey / 1.8 TSI / 2009 175. KarlTDiCombi / Satin Grey Met / 2.0 TDI PD / MY07 176. Mattybrooks / Cappuccino / 2.0 TDI PD / 2008 58 177. Tintinandcharlie/ Silver/ 2.0 tdi 140pd bmm/2007 07 178. Bingoronnie /Anthracite Grey / 2.0 TDI / 2012 179. 59p / Candy White / 2.0 TDI CR Estate / Dec 2009 180. philingle / Silver / 2.0 TDI / Sept 2008 181. cpt_kremin / White / 2.0 TDI Manual / MY2011 182. Vee.Dubster / Black Magic / 2.0 TDI CR Manual / September 2011 183. Maker_of_Things / Silver/ 2.0 TDI Manual / Feb 2009 / 3rd owner as of April 2019 / 132000 miles / drivers seatbelt warning light on, tiny oil leak at rocker cover somewhere / full of north Wales farm yard! 184. kris_kristofferson / Diamond Silver Metallic / 2.0 TDI Manual / June 2007 / 3rd owner as of July 2019 / 157000miles 185. MattM / Green / 2.0 TDI / 2011 186. Purdydog / White /2.0 TDI CR / 2011 187. ibgarrow / Grey / 1.8 TFSI / Oct 2011 / 145,000 188. greyskodahead / grey / 1.8TSI / June 2011 189. Deepsouthscout/Brilliant silver/2.0 PD TDI/2013. 190. GrizzledBear / Brilliant Silver / 2.0 PD TDI BMM / 205,000 Miles 191. OldUncle / Silver / 2.0 TDI (BMM) / 2008 - MK2 - Pre-restyling / 262,000+ km or 162,800+ miles. 192. twaredscouts / Corrida Red / 2.0 TDI / 2008 193. WILL2002 / GREY / 2.0 TDI CFCH / 2011 FL / 240,000 MILES RWW299 / Brilliant Silver / 2.0L TDI manual 4x4 / 2012 FL / 200,000 Miles/ Ex-ambulance so i'm the first private owner 194 Flyinghigh/ Red / 1.8Tsi / 2009 Upagumtree/magic Black/2.0L Diesel/154,000m/2009
Where to connect rear fog light wire from bypass relay
Apologies if this has been covered by I can't find an answer. I'm new to both Octavias and rear fog lights. I have a 2011 Octavia estate and am installing a Quasar WH2Q-S-G7 bypass relay for a trailer. Everything is connected and working except the rear fog light connection. I can see that there is only one wire for the running/rear fog light and the light somehow brightens when the fog light switch is activated. How should the rear fog light wire from the bypass relay be connected? Any help would be appreciated. Thanks.
rlnunix started following Where to connect rear fog light wire from bypass relay
upagumtree started following Scout Owners Register
upagumtree joined the community
Is DCC important?
Definitely much cheaper without it!
Radio cutting out new starter motor
Radio - no auto power off setting Starter probably is power hungry Blower and lights don't seem to dim or turn off. Dash lights, backlight remain. Radio reboots after cranking but on a few occasions it did not. I told wife it defaults to standby sometimes so it wouldn't come back on. I've ordered radio loom to smooth out voltage drop. I'll report back.
- Fabia Mk3 Bolero (P0369T): Android Auto, wireless dongles and Bluetooth all stopped working. Reflash refused, 0480T won’t instal
Power steering (Rapid)
It may have all electric with the same pr code. I'm pretty sure I read when they changed from electrohydraulic to full electric they kept the same pr number 1n1 for standard steering and 1n3 for speed variable. Main worry would be that where is the fluid coming from. Does it look like engine/Gbox oil or maybe brake/clutch fluid. Alasdair
Alasdair1 started following Power steering (Rapid)
Yes. Typical problem is either FEC/SWaP corruption or EMMC failure. Pls go to service menu (long press MENU button) and check what are installed FEC/SWaP codes and if they are valid.
Hi all, Android Auto worked fine in my Fabia Mk3 until 7 November 2026, then stopped. I hadn’t made any changes. I’ve been through everything I can find and I’m stuck. Unit Skoda Fabia Mk III, Bolero (MIB2 Standard, Technisat) SW train: MST2_EU_SK_ZR_P0369T Symptom Android Auto on the phone detects the car and tells me to go to the head unit to continue. The head unit then abandons the connection and drops. The screen shows MirrorLink, then it disconnects. It then re-initiates the sync over and over and never gets anywhere. It’s the same across multiple phones and multiple cables. I’ve cycled through the cables. I suspect something at the protocol level. What fails Samsung S24 Ultra, wired, with several known-good cables Samsung Galaxy A8 (2018), wired: Android Auto won’t initialise Two different plug-in Wi-Fi Android Auto dongles: each one attempts, sees the phone, then abandons iPhone (a passenger’s) over Bluetooth: it pairs, the car presents it and there’s a handshake of some sort, but audio and other functions won’t connect. The passenger tried several times without success. What I’ve done on the car MENU > SmartLink > Android Auto, selected manually SmartLink reset Factory settings > Restore factory settings (full reset); all settings cleared and everything re-paired from scratch Reflash of MST2_EU_SK_ZR_P0369T from SD (FAT32, files in root): the unit won’t accept it MST2_EU_SK_ZR_P0480T from SD: doesn’t work What I’ve done on the phone (S24 Ultra) Cleared the Android Auto cache and all settings Uninstalled and reinstalled Android Auto updates; phone fully updated USB data to a PC works, so the phone’s port is fine Tools: OBD2 reader only. Probably dead, a cheapo clone. No VCDS. Similar threads I’ve found pab567 on a Fabia Mk3 where Bluetooth suddenly stopped: the BT module is built into the glove-box unit and may be faulty. https://www.briskoda.net/forums/profile/112491-pab567/content/page/22/?type=forums_topic_post P0369T to P0480T refused with “dependencies of update not met”: https://www.briskoda.net/forums/topic/536550-cant-uppdate-from-p0369t-to-p0480t/ A P0369T reflash on a Fabia stuck in a Retry/Skip loop: https://www.briskoda.net/forums/topic/534939-infotainment-update/ My questions Has anyone had Android Auto, Wi-Fi dongles and Bluetooth all fail together on a Bolero, with the sync looping like this? What fixed it? Is there a way to force a reinstall of P0369T without VCDS? Does this point to a failed glove-box unit, or something at the protocol level? Thanks.
rlnunix joined the community
Radio stations Logos database updates
I have the same problem. The issue seems to be the InstallerVersion field in Data/fileCopy.ext-stationdb-sqlitedb-base/0/installer.txt. They have incorrectly changed it from 328.2.11 to 1.31.70 after computing the hashes for the files to match the old versioning scheme. As expected, this changes the hash and thus it no longer matches and the system refuses to accept the file. This seems to only affect "MIB3 OI" or "MOI3" units, others are fine. I've attached the corrected file for 1.31.70 where I changed the version back to 328.2.11 and the hash now matches again if someone wants to test, just drop it Data/fileCopy.ext-stationdb-sqlitedb-base/0/ on the SD card and you should be good to go. I also send an email to Phonostar with the details. Both, 1.31.66 and 1.31.70 are broken. 1.31.64 works fine. installer.txt
janil started following Radio stations Logos database updates
Intro
I had one of these as my first car. Excellent choice!
