Past hour
damosings joined the community
LED tail light failure
Thanks, more food for thought. I'll try to dig out the OBDII adapter that I've got somewhere and look for codes but it may be easier to let my garage take a look.
- 1.4 TDi Spluttering and Loss of Power When Up to Temp
Today
Well. Changed thermostat and temp sender in end of engine. Also cleaned out the anti-shudder and EGR valves, the interior of which resembled a coal merchant's yard. Had to scrape and scrub and scrub and scrape and used two tins of carb cleaner, resulting in fingernails that may never look clean again despite the Black Mamba gloves I was wearing. Seem to have got things moving in these parts again. Put it all back together with some new gaskets and sealing washers. I must say that the connector flange between the EGR valve and the Exhaust EGR pipe is an absolute B****** to get to and remove the bolts!! Took hours to remove and replace. My back is now in spasms. Cleared fault codes after putting it together. Took it for a good 12 mile test drive last night with a mix of city and country roads with hills and dual carriageways. Got up to temp quickly and stayed at a steady 90C. Only got the slightest of hiccups but that was coming off the throttle doing 65 in 3rd on the Dual Carriageway and a tiny bit on a hill following a slow car. Got back, checked for code. Nothing. Clean slate. Hurrah! Or so I thought. Son replied it was playing up a little as he got nearer to work this morning. Arrgh! I'll see what his verdict is when he drives home this evening.
Cairus's Leon FR
Details to make... https://youtu.be/hzqmJYvWZxE?is=QbtXyx7i8l30OGJU
lighting protection is controlled by the BCM I believe. There are 7 fuses that protect circuits supplied by the BCM but only the individual headlamps get their own fuses. So if part of the light isnt working and some is then its the light unit thats failed and needs replacing. If whole of the unit isnt working then it may be that the BCM is cutting power as a protection measure, but this would report a diagnostic code
Binx1310 started following LED tail light failure
Scala SE L 1.0 TSI 115PS - console keeps rebooting
Go to dealer
imart143 started following Scala SE L 1.0 TSI 115PS - console keeps rebooting
Did you ever find out about fuses? I have also wondered where the upstream source of electrons for rear and tailgate light is as both have failed. I can't see any mention of rear lights on the fuse diagrams for my year (2016) and would prefer to avoid the escalating cost of a replacement cluster assembly.
HI! We have a Scala SE L 1.0 TSI 115PS where the console keeps rebooting. 69 reg. Reboots about every two minutes irrespective of whether there is any bluetooth device attached. Car bought second hand. I've done the following: Deleted/disabled the previous User but we haven't added another Primary User. Not sure if we really need to? Removed all the previous phone profiles. Checked for updates but there doesn't appear to be any. Attached is a photo of the version nos. etc. Any ideas what I can try? Could I try a Factory Reset or may that cause more problems than it might solve? I'm no mechanic. I put petrol in a car and get it regularly serviced, otherwise my knowledge is pretty well zero. Thanks. Ian Watkins
ianw1000 started following Scala SE L 1.0 TSI 115PS - console keeps rebooting
cbgman started following LED tail light failure
- ACC control
cbgman started following Skoda Superb Mk3 (2015 - 2023)
How to remove A-pillar trim?
Hi Uberlano. Did you disconnect the battery negative terminal before removing inner a pillar trim.
robsie started following How to remove A-pillar trim?
- Another flashing oil light, but perhaps a bit different to the others?
I know it is an old thread, but could be helpful to others. Had a similar problem with the warning randomly appearing when lowering rpms on a 1.2 htp 2008. After much time spent on it, I replaced the plastic oil filter holder and no more problems. Orings seemed fine, so might have been an issue caused by overtightening by the mech's that damaged somehow. BestPaulsk started following Another flashing oil light, but perhaps a bit different to the others?- Karoq 2.0 TDi 2019 - has developed a tic. Mechanic is just throwing my money at it with no effect
Couple of thoughts, and I'm not a mechanic. I had the 2.0 TDI 140 bhp engine in my 2013 Touran, so was on the VW Forum. It might be worth asking the same question in the engine section of that forum, there is a very knowledgeable and helpful guy on there who runs an independent VW garage. The other thought was fuel supply; so fuel filters, fuel pumps, does this happen when the fuel level is low in the tank, is the tank cap breather blocked, could there be water contamination from condensation forming in the fuel tank?Paulsk joined the communitysueian started following Hellos and Goodbyessueian joined the community- Karoq Sportline 2024 2.0TSI - What lights do I have?
I commented on your post of the FB Group. I was curious and did some google searches. Apparently AFS predates Matrix LED, on start up AFS lights should sweep the beam either up/down or left/right and when driving the beam should 'bend' round a corner. This is an image of the Matrix LED dipped beam on my 2023 (73) 2.0 TSI Karoq Sportline. These are definitely Matrix LEDs, its on the Digital Certificate, and once on main roads (ie speed limit above 30 mph) the beam adjusts automatically for vehicles in front or oncoming. The Digital Certificate also mentions Cornering Function, the low level lights at each front corner will automatically come on to cast light to whichever side the car is turning, I can't be sure now whether its indicator or steering wheel that triggers it. The headlights on my Karoq sweep up and down when the engine is started. I have had a further thought - on the rear suspension there is a mechanism, the bit with the green plastic link piece to the right of the NSR driveshaft, I believe this is a load or position sensing device that automatically adjusts the beam height, (doing what the dashboard thumb wheel would do if it was fitted). If that isn't connected or working correctly that might be affecting the beam height. I have now looked at the advertised spec for a 2024, 24 plate 2.- TSI Sportline, it shows Comparing that to the printed copy of the advertised spec for my Karoq only has the section circled. I've checked the 2023 Karoq Brochure and the Light Package is standard so 2023 and 2024 Karoq Sportlines have the same Matrix LED headlights and functiona;lity.thamestrader started following Karoq Sportline 2024 2.0TSI - What lights do I have?- Sistema Smart link
Translation (Tradução) I bought a 2024 Skoda Kamiq, with the understanding that I needed to activate 'Smart Link' to access apps from my smartphone. However, when I visited the brand's dealership in Vila Real, I was told that my specific model is not compatible with the activation of this service. My previous car—a 2000 Mazda Demio—had a screen I installed myself, which worked very well, especially for Waze. I bought a technically more advanced car, yet it turns out it isn't compatible with the Smart Link system. Can anyone tell me if there is a technical or software-based solution to enable this functionality using the car's existing hardware, or will I have to buy a separate screen? Olá. O idioma predefinido no Briskoda é o inglês. Por favor, utilize uma ferramenta de tradução online para publicar em inglês. Isto serve para garantir que obtém o maior número possível de respostas úteis. Obrigado pela sua compreensão. Administração do Briskoda. Hi @manequim The default language on Briskoda is English. Please use an online translation tool to post in English. This is to ensure you get as many helpful replies as you can. Thank you for your understanding. Briskoda Admin.- Sistema Smart link
Comprei um Skoda Kamiq de 2024 com a indicação que tinha de activar o Smart link para poder ter acesso às aplicações do meu smartphone. Acontece que fui ao representante da marca em Vila Real e lá disseram-me que o meu modelo não é compatível com activação desse serviço. O meu carro anterior, Mazda Demio de 2000, tinha ecrã instalado por mim que funcionava muito bem, principalmente para o Waze. Comprei um carro tecnicamente mais avançado mas que não é compatível com o sistema Smart link. Alguém me pode informar se existe algum meio informático para usar o equipamento do automóvel ou terei que comprar outro ecrãmanequim joined the community- Karoq Sportline 2024 2.0TSI - What lights do I have?
Is this a Sportline Edition model? If so, AI suggests it does have AFS - but that AI information might not be correct. Best suggestion I can make is to check the 2024 configurator to confirm - or check with the VIN.PSDR joined the community- Fabia 2024 SE comfort mpi fault
- Fifth gear popping out (gearstick)
Might be worth checking gearbox oil level/condition as well as its a 2005 car. Could be low Alasdair- Karoq Sportline 2024 2.0TSI - What lights do I have?
According to AI, not all Karoq model trims are fitted with AFS as standard - do HBs operate when switched manually on the stalk? Check on 2024 Skoda options list what yours has as standard. You could also try an online VIN decoder to see what you actually have.- Fifth gear popping out (gearstick)
Might be worth resetting gear lever cables and check that the selector on Gbox is not seizing especially the plastic triangle shaped bit. Alasdair- Wheel spin on moderate throttle
Just to reinforce StevesTruck's message. Many years ago, or so it seems, I had a new Audi A4 Avant which would spin its wheels at every opportunity. Only after a few thousand miles when I checked the tyres & found that the wear on the tyres was uneven did I get it sorted - it was the steering geometry at fault. Once corrected it was a far more sure footed car.- skoda superb mib3 multimedia black bar problem
Here is the solution to this problem: https://www.drive2.ru/l/747128872385908278- Karoq Sportline 2024 2.0TSI - What lights do I have?
Thanks for the reply. Ive been back twice now!! Getting usual dealer fobbing off, 'theres nothing wrong with them'. I cant find any way to adjust the beam though, (like in the old days with a thumb wheel on the dash!)- Karoq Sportline 2024 2.0TSI - What lights do I have?
Welcome to the forum. Take it back to the supplier and insist they inspect the headlights for correct function. Quite possible your lights do not comply with MOT requirements if as described.
