Matrix headlights with auto high beam
Yes, on my '21 vRS I have the lights on Auto (on the lower switch), and it's just a matter of pulling back on the headlight stalk/switch to return them to normal operation
CS363 started following Matrix headlights with auto high beam
This one was purchased legitimately. I can’t speak for @Danoid s one though…
Did you mean "Great find by @danoid my dealer"? 😁
DJB2024 joined the community
Cool White LED torch installed. Part number 3T0947417F is from a new Tiguan, multivan or T6 caravelle and is a straight replacement. It’s B E A utiful. The last yellow light now gone! Doesn’t come out great on the photos but I’m very pleased! Great find by @Danoid Before After
Trunk Torch/Light - LED Upgrade
Back home this evening and white LED torch installed. It’s B E A utiful. The last yellow light now gone! Doesn’t come out great on the photos but I’m very pleased! Great find by @Danoid Before After
Superb Air Vent Removal/Fitment
Nice, looks like a pretty straightforward job once you know how to get the vent out. Good to hear the cheaper replacement turned out to be decent quality too. I’ve used parts from brands like ridex before and always think it’s worth comparing options, but if the AliExpress one fits properly and works well, that’s a good result. Thanks for sharing the guide!
JackTurner started following Superb Air Vent Removal/Fitment
Greetings from Finland
All the best with your project Takkis and welcome.
minsy started following Greetings from Finland
martino1960 joined the community
- Lcc not working
I’ll pm you
Octavia MKIV 2021 1.5 TSI: fluid around fuel filler opening, is the inside of the neck supposed to look like this?
Moved to Octavia MkIV forum.
As @skomaz says it's a blocked drain tube. I had the same issue with Mrs Moley's Kamiq recently. I removed the blockage with a thin piece of wire. The drain hole is in the area marked with the yellow circle.
johnythenailer joined the community
SuperSkoda Shipping
Used to be small packages up to 2KG only after Brexit, think they send larger stuff now by DHL, I've never had any problems, never ordered anything large like a rear spoiler etc though, drop them an email see what they say.
Georgii joined the community
Hi all! I'm 30 something year old male from Finland. I got my first child about a year ago and the need for bigger car and isofix seat was imminent, so my trustworthy 2004 VW Bora 1.6 petrol had to go. I started looking for bigger car, as we needed to transport 2 adults, 1 baby and all their stuff for 2-4 weeks at a time because my job. I spotted 350 000 km 2014 Skoda Superb 2.0 TDI 4x4 Estate with good service history at an auction, and I thought it was superb mk3 rather than facelifted mk 2 so I bought it with 4000 €. It was about 3000 € cheaper than same mileage Superbs in Finland, so I was satisfied with my purchase. Soon I started to notice it had lots of small flaws: heated seats did not work, it did not warm in the wintertime, rear wheels did not engage at all and cabin is quite noisy. Other than that I like Superb a lot! There's room for take my whole family and all the stuff that we need while being 4 weeks away from home! I changed DSG thermostat and it seemed to fix the warm up issue. Then i changed Haldex oil and filter fixing the rear wheel drive. Now I have plans to restore Superbs old glory. At the time I'm planing to do follow: Fix heated seats (still no idea how..). Cover the cabin floor and doors with noise insulation mat. Remove all the rust and redo the body rust protection coating. Install MIB STD2 (I just received used unit from 2015 Skoda Yeti). Wish me luck. I hope to afford an electric vehicle in next 5 years or so, but until then I'll be fixing my Superb.
Takkis started following Greetings from Finland
Removing pcv valve
You have answered my question. Thanks
Hello from the East Midlands, UK.
Recently just bought my second Skoda ... because the first one impressed me that much! 😎 2014 Superb Tour de France 4x4 2018 Kodiaq Edition 190PS DSG 4X4 (5 seater) Most of my cars have been VAG over the last few years but it seems that the balance of quality/price of Skoda has drawn me away from Audi and VW. I already have a couple of questions ... but I'll go find the correct place to ask 😉
ukEvo started following Hello from the East Midlands, UK.
ukEvo joined the community
What skomaz said. If you didn't notice a strong smell of petrol when you mopped it out then it's just water.
I actually have bits and pieces but not the entire thing - one of the few cars I don't have all the tech info, which bothers me ... I can swap with lots of other literature 😁 EDIT: I stand corrected, I have a "Workshop Manual Superb III 2015 ➤ General body repairs, interior Edition 05.2018" File D4B80536B1A which is a 163 page PDF, 19.2Mb I would love Engine/Suspension sections, if available ... 🥰
WINDSCREEN
Are you sure it's external surface damage ? Modern windscreens are all tinted and the additives used to produce the tint seem to age and produce a light scattering effect (Oh for the days when simple clear glass was used - last time I had truly clear glass was a 2003 Astra). If this is the case then a new windscreen is the only answer. If, however, it is actually fine external damage then it MAY be possible to polish it out. I have successfully polished out a couple of fine scratches (caused by an incompetent valet at a dealer saleroom) on the windscreen of a Golf using a felt wheel and cerium oxide with a Dremel type tool so I know polishing CAN work in some cases. In my case these were only localised scratches - not a whole windscreen ! And even then it was a laborious process. If you're convinced it's external then it could be worth asking a decent bodyshop or a windscreen specialist if they are able to sort it with a cerium oxide buffing. Like you I am reluctant to go for a replacement windscreen unless it can't be avoided - I've had a couple occasions over the years when the muppets have damaged the paintwork or the new windscreen has leaked.
Rear view camera retrofit
FL_5Q0980556B__0231.frf
Cairus started following Rear view camera retrofit
Tyre recommendations
I don’t understand why a supermini like the Fabia which has an official top speed in the vicinity of 200 km/h and weighs approximately 1,150 kg requires V-91XL rated tires. In my opinion, these are excessive specifications who inevitably call for a reinforced carcass and rubber compound, resulting in a "stiffer" tire. An 88-H rating tire would be technically more logical and appropriate for a supermini hatchback. After all, the same car when equipped with 15-inch wheels in its base trim levels, comes with 88-H rated tires. I believe that the V-91XL specification, combined with the excessively high recommended tire pressure, leads to a less comfortable ride on poor-quality roads than the car is otherwise capable of delivering. Skoda could at least allow for an alternative speed/load rating for those who prioritize comfort. However, for the sake of standardization and economies of scale, they likely opted for a single specification for all 16-inch wheels—one that also covers other, heavier or more powerful models.
That looks pretty typical. The fluid is just water from when it rains - there is a small drain hole at the base of the black plastic surround that allows any that collects to run down through a tube to the wheel arch (you can just about see it in your picture). That will be blocked so just push some strimmer wire or similar through it gently to clear and it'll run away.
JD52 started following Keyless start not working
Most upset, my V3 L&K written off after a cretin drove into me.
The car will be going to IAA Auctions up north. Spec of the car is attached. You may be able to determine why i was a bit upset at the write off. If anyone is interested in buying it to repair I'd be happy to talk to them. Reg number began with BG21.
This seems impossibe
I So Ive been trying to do this job for 3 days now and it and now it's really frustrating me (getting it back in) and that’s a understatement , wiper linkage removal yes i its been the bayne of my life for over a week in all its been painful as well, the only video on YouTube is Fabia and the looks totally different, now i read on here before got started that they removed the firewall but i can only get at one fastener so i know you shouldn’t but i have been bending some parts to get the other out, but i cant get it back in and believe me Ive tried, why did they not put the bolts trough side , any way I'm hoping someone can help me out, thank you in anticipation 2015 Škoda Rapid Spaceback SE Tech (NH1) with a 1.6 TDI diesel engine (engine code CXMA), producing 115 PS (85 kW). It has a 1,598 cc engine, a 5-speed manual gearbox
redoor43 started following This seems impossibe
