Past hour
Wheel nut torque
That used to be for the "biggest" 4X4s in VW Group world.
Chri Harris on Cars.
Yup, though best kept away from steam train enthusiasts!
Wheel nut torque
From the manual for the pre-facelift: Have the tightening torque of the wheel bolts of the mounted tyres checked with a torque wrench as soon as possible. The specified tightening torque is 140 Nm.
Rbz5416 started following Wheel nut torque
Wheel nut torque
120Nm is a good starting point!
Battery issue or?
9 volts is a bit low when cranking - I'd suggest a battery test if it's falling that low. From memory, around 10 volts is a healthy limit.
1.2 TSi CZJC Lumpy, stalled, wouldn't restart
This could be the first one being reported on this forum:- Fuel Leak! - Skoda Fabia Mk3 (2014-2021) - BRISKODA
I have just watched Chris Harris on cars and him driving the TWR Supercat. It is a month since it came on YouTube and some how it passed me but. He is just a test driving god and a dude IMO. PS. Love the Ravage A110 and his vid driving it and his meet up.
Evolution13 started following Chri Harris on Cars.
Wheel nut torque
I have been though the hand book and searched the forum, but can not find the wheel nut torque setting. Any offers. 2025 Karoq, 1.5 sportsline, 19" wheels.
I don't think that VW Group ever did a recall and fix campaign for this problem in Europe - they always seem to stick with "it's just wear and tear - now give us your money". It does not seem to affect every engine over a certain engine production period - but that car's engine will probably be within this period of "uncertainty" - if a bolt fails, ie its head snaps off, then there should be some indication from the dashboard as the fuel rail pressure will drop below its intended level - and petrol will be spraying out over the front of the engine - and I don't think that is healthy. This might sound like I'm being alarmist, but when I initially found out about it, I was seriously concerned and contacted DVSA about it, and they replied to say that they knew about it and VW Group had told them that there is not a safety issue as the driver will get a warning from the dashboard that something is wrong! In other words, there is not "enough meat" in this issue to set their flag to issue a recall or any other action - so all is said to be good. There does not seem to be any fixed time period or mileage period in a car's life when this will happen if indeed it is going to happen.
Battery issue or?
My 1.5 is 14 months old, twice it has failed to start along with a stream of unrelated error messages. The first time (new car 3 days old) after leaving for a few hours it did start with fewer error, several restarts cleared the messages. Next day I took it to Skoda, they spent about an hour on it and found no faults, they said it must have been a glitch! 6 months later it did the same, but multipule restart attempt and opening / closing locking doors, the error went away and the car started. Each time this happened, the battery could have been low, the first time being in the Skoda garage, the second time it was frosty. I do not use the car regulary, so once a week I put my battery charger on it to charge it to 100% I believe that the cars alternator only charges up to about 80% to allow for some regen. Not good for starting, not good for the life of the battery. I think there are several posts on this in the forum.
Today
Phone connectivity - the big picture
Thanks Steve, I'm aware of most of what you mention but as ever with this car it just begs more questions... I've been connecting via Carplay almost since day 1, I understand that it uses Bluetooth for the initial connection then flips over...and I've never once seen this "disconnected" message...until now...why? Looking at the docs the "use infotainment as hotspot" seems to be a cash generator for Skoda if you want to sign up for their data plan. I don't so thought I'd disable that - and found out if you do that it kills Carplay, so you need to keep it enabled...I'm 18 months into this over engineered toy....sorry....car and still finding stuff out, it's crazy. Which is why I'm asking is there a graphic showing how it all links together or a start to finish guide on how to setup the iphone in the car?
Coolant overflows
Before paying for a head gasket I'd pin down where the gas is getting in. A reading that jumps to 105 and drops back to 92 within seconds is often a pocket of gas going past the temperature sensor rather than the engine really getting that hot, and coolant being pushed out only after a couple of hard pulls fits combustion or exhaust gas getting into the coolant under load. A block test done at idle can come back clean when the leak only opens up under load, so I'd repeat it straight after a couple of hard pulls, with the tester on the expansion tank as soon as you stop. The EGR cooler is also worth ruling out, as it's coolant cooled and sees exhaust pressure that rises with load, so a leak there can do exactly this. A garage can pressure test the cooler on its own, and a cylinder leakdown test will show up a head gasket if it is that. Both are cheaper than fitting a gasket on a guess.
SparePartAlam started following Coolant overflows
Correct, Voltage while actually cranking.
Chime after locking and unlocking car
Thanks for all your replies guys. It was the alternator. diode failed
9.5V is not minimal starting voltage. it is a voltage drop during cranking. if you have 9.5V battery, it wont start at all..
RobertNrecaj joined the community
14000Ah is ~ 15.3Ah/day, won't knock a measurable dent in the battery's SOC even if it fell by this amount. Some blame the frequent starting in Stop/Start for a lot of battery problems but if you think of it, each start only takes a fraction of a AH, if you run a VCDS log on battery current, you will catch most of it, mine, shows between 179A and 200A, a 2sec crank will still only consume, 200*2/3600, 0.11AH, your (hot) diesel might pull say a max of 350A for a (we'll give it) 3sec crank, 350*3/3600, 0.29AH, the glow plugs will consume possibly as much even though only on very briefly, if at all, with a hot engine. Even though we all profess to hate this smart charging and a max of 85% SOC etc, I would only worry if the battery is deep discharged and also, more worrying, its internal resistance, which is inevitable. If you accept that say 9.5V is the minimum starting voltage required and on a cold morning your diesel requires 350A and that the standstill battery voltage is 12.5V, voltage drop is 3.0V, internal resistance would have to be, (3/350)*1000, 8.57mOhms, so maybe set somewhere around there as your warning flag. If you forget all that jazz above, just do what I have done for over 60 years, get someone to crank the engine while you watch the voltage on your multimeter with the probes on the battery terminals. I think the majority of damage done to batteries is done in the parking lots where the cars can sit for months with the batteries in deep discharge. I have a April 2026 Polo and I reckon the battery has suffered this fate.
clydeglass joined the community
highly recommend getting a throttle controller like EVC, to address this. i've got one in my Superb, been a number of years. makes a big difference. very easy to install. EVC Throttle Controller for VOLKSWAGEN GOLF
After only 2.5 years my ah is over 14,000ah total energy throughput.
Garage Labour Time Per Job....
That's taking the ****, especially if they didn't even track it. I wouldn't be going back there again, and I'd probably still be raising **** with them. Yes, props for being thorough and replacing the CV grease, but you don't need to take the brake assembly or any suspension off, you can just undo the bottom ball joint from the wishbone. You can take the CV end off without taking the driveshaft off the car with the right puller. I'm not even a mechanic, but the only way it'd take me 5 hours to do a pair of them is if I had a 2-3 hour lunchbreak in the middle.
Play in between outer and inner track rod end
It might just be the picture, but the thread on that track rod looks pretty mashed up, which probably doesn't bode well for the state of the lock nut of the thread in the end. For how little money they are, I'd probably think about throwing a complete new rod and end on the car. For suspension parts, I normally try to get a FeBi / Bilstein part, they probably made the one that was originally on the car
skoda7328 joined the community
Yesterday
I find it more than adequate. They can be modified to produce frankly ridiculous power for a little 1.2 (obviously my sister couldn't care less... but I had to look!) My sisters is on 105,000 now and prior to this, absolutely nothing at all has gone wrong. It has 100% been the most reliable car in our family collection. I don't know about those bolts no, I'll swing by on the way home tomorrow and just see if she's got a campaign sticker or marker anywhere under the boot carpet or in her service book. Thank you for this useful info that could potentially make a massive difference to someone's very existence.
Superb Mk4 Owner's Manual Now Available
Confirmed. Just had a look and yes it goes to the web version but you can download it as a PDF . Thanks @Cedwing !
lduffman started following Superb Mk4 Owner's Manual Now Available
The car can connect to your iPhone by Bluetooth OR CarPlay (of your choosing) at any one time. Connection by Bluetooth is what shows as Disconnected in the centre of your speedometer - this is due to the phone having a CarPlay connection. Using the car menu settings for Phone (or mobile devices, can’t remember the exact name) you can select the connection type for each phone. The car should remember the previous connection selected. To make calls via CarPlay, long press the voice control button (left side of steering wheel) and use Siri (call name).
SteveTheElder started following Phone connectivity - the big picture
Who’s run a 4WD without the rear differential?
ath joined the community
This almost exactly 8 year old (Jan 2019) petrol Polo with a 59AH EFB battery is working perfectly, last set of readings (below) taken last June after 7.5 years, all short runs up to passing it on to our daughter in April, only ~ 40K KMs on it then, now > 50K Kms, wife always inhibits stop/start, I use it as I see fit. IDE01834 Battery voltage 12.193 V IDE01836 Battery current -4.950 A IDE01839 Battery charge status 77 % IDE01841 Battery internal resistance 7.6 mOhm IDE01842 Usable battery charge 28 Ah IDE01948 Battery internal resistance not normed 6.0 mOhm IDE07681-MAS06086 Battery total charging throughput-Total re-charge 3890.7 Ah IDE07681-MAS06087 Battery total charging throughput-Entire energy throughput 4091.0 Ah
