  2. aleks0603 joined the community
  3. It will not raise the Floor. It will fit in the spare tyre well. You may have to put something on top of it to support the floor.
  4. Same here with 1.5 petrol...dealer is aware and had car in for 3 days for a sw update....and it has stalled once since then...I'm not confident...
  5. I can't give you the part number but we had this issue on our previous Yeti and I followed this 2018 thread. I bought both parts but the main one was wrong, despite trying to carefully match and even the garage said it's very easy to get the wrong one. I would have a look at LLL Parts schematics or Skoda-parts.com as a starting point.
  6. Hi everyone! I’ve wanted to install the FL taillights for a long time. They fit perfectly in terms of mounting points and are plug-and-play (pin-to-pin). However, when locking and unlocking the car, I was getting turn signal errors, and the animation wasn’t working. I fixed the turn signal errors by changing the Leuchte 18 and 19 parameters. I replaced the pre-FL lamp type “LED Blinkleuchten mit Ueberspg absch” with the FL setting “LED Kleinleistung ohne Open Load Diagnose.” The turn signal errors are now gone, but the animation still doesn’t work. Does anyone know if the animation can be made to work? Is it coded separately? Does this LIN version support it? IMG_2779.mp4
  7. Meant to add if yours has a towbar fitted they sometimes were fitted with a microswitch in connector to disconnect rear fog light to stop back glare from trailer. If its failed it could be the cause. Alasdair
  8. Seems one has to push the fuse cover down a bit, then they slide after a bit of fiddling. Thanks, answered my own question.
  9. Hi, the default language of Briskoda is English. Please use an online translation tool (e.g. Google Translate) to post in English. Thanks you. Briskoda admin Hola, el idioma predeterminado de Briskoda es el inglés. Por favor, utiliza una herramienta de traducción en línea (por ejemplo, Google Translate) para publicar en inglés. Gracias. Administración de Briskoda
  10. I think I have an alternator rectify leak as my battery has gone flat twice. How do I open the engine bay fuse box. There are lock slider, but I can't seem to move them forward, is there a knack to it? I can the isolate the alternator and check for a drain. Thanks
  11. Try the cable connector itself not the contacts but if theres still no voltage its probably a broken wire as I think the fuse does front and rear unless its the actual switch for the rear thats failed? Not sure what route the cable takes from rear Alasdair
  12. Hi @bluebill , I have exactly the same HW and SW versions. Please keep us posted if you successfully update to 0742 (engine On?). It would be great to know whether it also resolves Android Auto connectivity issues. Thanks!
  13. Today
  14. Hi, thanks for your interest. The car is now sold and off to new home.
  15. @bluebill Lookie here...
  16. DQ381 has issues till mid-2020, I believe. After that it doesn't. So for 2022/3 this isn't an issue anymore.
  17. I got a new update this morning too. Seemed to drop on without issue. Didn't get a chance to read what it was about, as I was moving and the screen gets auto-hidden, and by the time I'd stopped it was finished.
  18. Are you getting like a sloshing noise from the heater matrix behind the dash ? I've done the bleed on vcds and still getting the noise from behind dash , have you checked that because the original ones can leak . I've just ordered a sniff test to check if the pressure in the coolant tank is just air or still exhaust gas .
  19. Hi all! 2019 Scala, Bolero MIB3, HW 033, SW Train MEN3_EU_SK370_P9305P, MU SW 0463. Could someone kindly PM me the files for 0469, 0741 and 0742? And has anyone done this on HW 033? Thanks a lot!
  20. I checked bulb socket contacts but the ground in the socket is shared with the other 3 lights (night/brake, turn and reverse) which work properly
  21. When you say no power have you checked to a reliable earth or just accross bulb contacts? Alasdair
  22. Hola soy Juan de España y encontré este magnífico foro de nuestra marca, conduzco desde nuevo un octavia rs 1.8t, espero aprender mucho aquí, un saludo. Hello, I’m Juan from Spain. I came across this fantastic forum dedicated to our brand. I’ve driven an Octavia RS 1.8T since it was new, and I hope to learn a lot here. Best regards.
  23. Not sure on kamiq but I managed to get a bit of stiff fence wire at the grommet where cables come through bulkhead from ECU etc on my old Octavia and an Old Seat. Then pulled cable back through. Easier from engine bay on mine. On some of the grommets there is a small nipple that you can cut off and feed through there. Alasdair
  24. Finally 4 'Michelin Pilot Sport 4 SUV' have just been mounted this morning on my summer rims, since there was a €120 bargain for 4 Michelin. It was easier with these rims off. I'll tell you how they are within ~1 year cause they won't be mounted on my Kodiaq before next spring...
  25. interceptor joined the community
  26. An OTA finally appeared this morning saying new features will be available after a restart, still showing as 332 though ☹️
  27. bluebill joined the community
  28. Sorry to revisit this post but can someone confirm that a 185x65xR15 will fit the boot well without having to pack up the boot floor, thanks.
  29. Bopman, can you where to purchase this item (and engine thermostat) for 2.0 l 170 bhp TDI DSG please? I see them online but not sure of compatibilty.
