DGW started following Problems after ABS module replacement
SaladKnife joined the community
- Problems after ABS module replacement
Electrical problem or ABS problem
Measure and check the battery voltage while the vehicle is starting; just because it is new doesn't mean it is in good working order.
Cairus started following Skoda Yeti Head unit clock 00:00 , Electrical problem or ABS problem , Steering-wheel control of phone? and 3 others
- Steering-wheel control of phone?
VCDS - OCTAVIA 3 vRS FL - Fog Lights with High Beam Lights
can someone please send me the file MHIG_EU_SK_K1552
Check this https://mibsolution.one/index.php/f/157055 User: guest Password: guest
- Skoda Yeti Head unit clock 00:00
Skoda Fabia Monte Carlo 1.2 TSI CBZB - Alternator belt tensioner replacement and Water pump recommendations
Thanks Imart and Pete, I googled GPM after seeing it on Pete's pic and came up with the GPM Nidec group too. I think GPM were bought out, which may explain the change in manufacturing location. I'm also not sure if they sell replacements, or were/are supplying direct to the manufacturer on new cars only. Imart have you been using Gates in the past and how have their reliability been? There's a lot of opinions about impeller material, plastic or aluminium. But I think if the more common failures are the internal seal and subsequent leak through the pinhole drain, or the bearings, then the impeller may not be the problem if the car is having regular coolant changes with the specified coolant. My INA kit should arrive today, and Ill post pics of it shortly. Thanks.
Constant app updates
I’m meant the infotainment system
- Yesterday
Looks like update 0334 is the answer, as all I can say is since I had the large system update on to software 0334 and the repeated 3 other updates I've not had the daily update prompt for over a week now.
This afternoon I had 7 updates, all for different things like 'background digital services", "application updater" etc Shop was also updated to a new version 338.322... So it does seem that 0334 is an enabler to release the next round of updates. Let's see in a few days, hopefully the constant updates will stop. I had a reply back from my dealer and he confirmed that the new 0334 OTA update would fix the problem. Gabbo
Bobslay started following Connection and Infotainment issues new Skoda Enyaq 85 Sportline
Hi, Took delivery of a Skoda Enyaq 85 MAXX two days ago. I am running 6.0.0. I am having real issues with connectivity and the infotainment system. My iphone 16 keeps disconnecting so carplay or even just phone via bluetooth shows a connection error. Sometime a reboot of the Skoda system connects back up, sometimes a reboot of the phone does it, sometimes neither and then an hour later it just connects. Is this a known issue or is my set up wrong? I hardly ever connects automatically when I get in the car. Also the infotainment system keeps freezing (unresponsive and Skoda logo stuck on HUD) and I have to hold power for 10 second to reboot. Is this a known error. I know 6.0.1 is going to be available in a couple of days but that doesn't seem to have anything to do with these issues (in fact it may make things worse). Any advice or comments welcome, thanks
Am I alone in thinking Skoda are not as good as in the past.....
Skoda used to be good honest cars, thedealers were good honest dealers, they were helpful, very helpful. Now I am not so sure. We have a Karoq and a Kamiq, both 22 plates. It's been mentioned before - the Kamiq, you have to control far too much via the touch screen, that for the ventilation is a massive and a potentially dangerous situation and the lag getting it to work or return to where you were times is far too long. The annual charge of £80 for updates and connected features is pathetic, the maps and speed information are wrong all over the place, satnav giving direction in contravention of a S22 - direction road sign - immediate 3 points. I raised a report about it once, their promise was a 7 day reply - well that was actually a month, then no further reply to my reply. Voice control - absolute joke! Of late I have noticed that when listening to DAB radio various stations repeatedly drop out. Now I have noticed this as I've been travelling the same routes in both our Karoq and our Kamiq - a totally inferior listening experience. I just wish I had noticed it in it's warranty. But I do have a Skoda service plan and an extended warranty. Today I rang the dealership and explained the issue, yes it is something they could look at but then burst the bubble by blabbing on about a possible charge, a not insignificant £130, I asked if the extended warranty would not cover it? We won't know until we look, was their response. So I could end up with a bill then...... Pathetic! Now I like my Karoq but I had a minor paint issue around the pseudo brake cooling vents in the front bumper, still in warranty then, sadly and from a different dealership just repeated fob-offs, perhaps it should have gone further but with way bigger life and family issues to manage - it is just a bit of plastic. Overall I am really disappointed and not feeling much love towards Skoda. I think I might cross the gap to Kia, for starters you get 7 years of updates included and give them a voice instruction and it responds immediately.
I believe this is just the Infotainment system software and not the software in the ECU which only Skoda dealers can update. For example the fix to ensure Kessy does not lock the car with the let’s inside could only be done by a dealer.
Is this just marketing baloney?
Call me a cynic, but I'm guessing to qualify, you need to finance it with them, take out the Gap insurance, have it Diamonbrite'd, order a boot mat, mudflaps......
2019 Kodiaq – water leaking into driver’s footwell after heavy rain
Hi, One of my friends faced that with an Opel Corsa in the early 2000's. We finally found a leak at the lower edge of the windscreen. There was a thin hole in the windscreen bonding. I suggest having a look there.
- Superb 3V3 tailgate struts - Beware Autodoc
Hi, I'll check if I have 0334 version too, but I had the same updates twice today. 🙄 A bit irritating in the end...
2027 MY difference
You can have a look over the User Manuals (https://www.skoda-auto.com/apps/manuals/Models) The main differences are the implementations of GSR2.0 Phase 3 (enforced as of July 2026). I think the requirement that impacts the end-user the most is the implementation of Advanced Driver Distraction Warning (ADDW) (camera-based, sensor located in the rear-view mirror), which can be annoying to some. It is the same system implemented already in the latest-gen Superb and Kodiak. The answer I received from the Skoda Infoline regarding a similar question: "All Octavia vehicles produced from calendar week 14/2026 onwards are compliant with GSR2 Phase C"
evilsheep started following 2027 MY difference
Electric seat working but memory buttons not working
Hi guys - I can still move the seat around but when I come to use the memory setting buttons - nada. So does this mean it's not a fuse issue? If not what else could be the problem?
I got this today from the dealership where I purchased my Karoq: We have a truly amazing opportunity for you - starting 9am, Friday 18 September. For 10 days only, we are giving you the chance to purchase a brand-new Škoda at cost price. Yes, the very same price that we pay! This exclusive, limited-time offer has been made possible due to an unexpected release of only 150 brand new 76 reg vehicles, made available to us by Škoda UK for sale in September. Due to these exceptional savings, we anticipate high demand for these vehicles so we are limiting to one purchase per household. Orders must be placed between 18 and 27 September and delivery by 30 September to qualify. As always, our team will be on hand to assist you with any enquiries and ensure a seamless experience. Anyone else getting these 'out of this world' sort of treatment?
John N started following Is this just marketing baloney?
What is this 2-pin connector under my 2005 Fabia 1.4 TDI ?
Hi, I haven't fixed any of these yet, DFM wire is still disconnected.. But I don't think I've run into any issues so far; do you know what kind of situation this might lead to?
Surface mount component identification?
You're welcome.
Thanks for the help @Graham Butcher Much appreciated. 🙂
