Dealer Or No Dealer?
Go to a VAG specialist independent in future. Discs do not fall for being lipped, that's a racket a lot of garages do, new pads maybe. It's too late now but with your car only doing about 7,000mi a year you could have had it serviced every other year if they used long life oil. Good luck with your future, I hope it is stress free.
KWP started following Dealer Or No Dealer?
1.5 Tsi Power Cutting Out
Our 1.5 TSI never cut out, bought new in 2018 and sold earlier this year after 8 years of trouble free motoring. Now replaced with another one, DSG this time.
2011 Superb VR6 Starts then dies, Fuel Issue??
Hi All My 2011 superb 3.6 is causing me major headsches. Car starts great & then immediately dies. can start it again imeediately no issue but then dies again unless I push the throttle down & get it up to around 25 - 3000 rpm but even then it runs rough & will die again if revs drop Have replaced fuel filter at rear, ensured line from filter to low pressure sensor is clear, have fuel to the in side of the fuel rail(?) . no codes come up when interrogated relating to engine control etc. Is there an easy way to test the HP fuel pump is working correctly? any other thoughts & suggestions are welcomed. Do have misfires on nearly all cylinders when I can get ot to run on high revs.
bdk started following 2011 Superb VR6 Starts then dies, Fuel Issue??
The 220ps experiences, questions & answers thread
You decided to keep it then?
Binx1310 started following The 220ps experiences, questions & answers thread
Clem_82 joined the community
the truth about electric cars
More news of Electric truck roll out by Amazon are other logistic companies......
PC7101 started following Knocking noise/rattle from DCC - Sportline 2.0 Petrol
PC7101 joined the community
Gandalf (MY17 Superb 220 FWD) is currently on Stg 3, producing 400 hp 550 Nm at the wheels. Previously I ran Stg 1 for approx 5 yrs before going to Stg 2 briefly then Stg 3 last year. I've had no issues with any of the stock hardware over the many years. The Stg 1 was an APR Hi-torque tune producing 300 hp 540 Nm at the wheels. Supporting mods then were R600 intake, turbo inlet pipe and elbow. I also had a TCU tune, which made a big difference. Now I've got an IE intercooler & downpipe, Garrett Powermaxx Turbo with stronger injectors. The Galano TCU tune has a Boost-by-Gear function that is specific for the FWD, that does an impressive job putting the power down through the front wheels without wheel spin.
- Problems after ABS module replacement
slamik joined the community
- Yesterday
What have you done to your Kodiaq today?
Hi, full refueled this evening and 17th fill-up in a row under 7.0l/100km. Not that bad for a big 1840kg bear with 200HP. 🙂
@JR RS I think that's a question for you! 😉
Dragging this up, did anyone ever have a confirmed higher stock output from the 220 engine? Looking at doing a remap but not wanting the full 300bhp that most quote, would be happy with 240 - 280
tombee started following The 220ps experiences, questions & answers thread
Welcome to the club
Slawa123 joined the community
Hello from Belgium / New Member
Hi, glad you joined. I drive an Octavia 2014 petrol
DQ200 DSG Mechatronic Issue – Loss of Odd Gears & Low Hydraulic Pressure (P284F00 / P283C00)
Hello again, to convey my previous experience, but I also need a little help. I have been researching this dq200 hoping to solve the problem myself because the price they are asking in Belgium and surrounding countries is crazy. After watching a lot of videos on how to disassemble and assemble, how to test various parameters, I found that I lose pressure very quickly, that the pump works properly and builds up pressure, and I established that it is not a mechatronics problem, but a pressure accumulator or an aluminum plate. Since I couldn't test where the crack is (I don't have a compressor or suitable adapters), I bought a replacement accumulator Kinergo MSU04 for pressure, oil for the mechatronics and for the gearbox, as well as the digtung cover and tubular oil filter and prayed to God that it wasn't a plate. I did not measure how long the pressure holds before replacing. Now with the new one it lasts about 18-20 seconds Does anyone know how long the pressure accumulator should hold pressure while the car is idling?
Indeed. The withdrawal of the Federal EV credits caused sakes to drop big time. EV sales have recovered a lot with fyel doubling in price. The Buzz will need to be biult cheaper, LFP pack etc and buyers happy to pay for a premium over rivals.
Cambelt change for 1.5TSI engine
Cahill in Dorchester
I thought they were not building in the USA in 2026 until dealerships clear stock.
Skoda Fabia Monte Carlo 1.2 TSI CBZB - Alternator belt tensioner replacement and Water pump recommendations
yeah gates or dayco, for example, OE timing belt for 1.5 tsi engine is made by Dayco. For the Volkswagen Group's 1.5 TSI engine (brands such as DADA, DPCA), Dayco produces the main camshaft timing belt (catalog number 941060, 20 mm wide and 163 teeth) and the smaller oil pump or water pump belt/belt (catalog number 941160, 81 teeth). It is about Dayco HT (High Tenacity) patented technology, better known in the automotive world as "White Belt". The white layer on the inside of the teeth is a special film of PTFE (Teflon) patented by Dayco and bonded to the basic nylon-aramid (Kevlar) fabric that covers the belt teeth. Extreme friction reduction: When the teeth of the belt fit into the grooves of the pulleys, friction occurs that over time "peels" ordinary rubber belts. Teflon dramatically reduces this friction. The belt slides smoothly and almost completely eliminates wear on the fabric of the teeth. Protection against lateral wear: The belt moves slightly left and right during operation and hits the edges (flanges) of the pulleys. The white PTFE layer also covers the lateral parts of the teeth, protecting the belt from lateral "backlash" and cracking at the edges. Modern 1.5 TSI engines have high direct injection pressures and develop enormous temperatures under the hood (over 120°C). Classic rubber would harden and crack over time. The Teflon and advanced HNBR rubber from which the belt is made remains elastic and stable for years Internal structure (fiberglass): Behind that white layer and the rubber, inside the belt are strands of high-modulus fiberglass woven into a spiral. These ensure that the belt does not stretch at all over the years and kilometers, thus keeping the engine's timinge perfectly accurate. you dont need that for alternator belt, but i read this on Autoteile.
DGW started following Air quality sensor replacement
Ha! I'm planning a drive to Prague next month. Couldn't have picked a worse time for petrol prices... I wonder if they'll give me a discount for driving a Škoda?
P30603P update file
Hello, I've just got back from a bit a difficult road trip across eurpoe where my skoda superb estates' infotainment system got stuck in a reboot loop. I managed to stop and buy a USB-C memory stick in germany and have brought my system from P1560P up to P27800P which fix the problem and at least some of the journey home was a bit less stressful. I'm now trying to go the rest of the way up to P33200P, but I believe I need a stepping stone to P30603P first. I've tried downloading MOI3_EU_SKMQB_P30603P.zip from mibsolution.one three times, but when i try and extract the archive I get a CRC failure. Is this a common download problem? Do I just need to wait and try again another day or could the file be corrupt on the server? Thanks
Chard started following P30603P update file
Wrong suspension springs -help
Not tried it, I will do next time it's up on the ramp and let you know
