Past hour
- Play in between outer and inner track rod end
Warrior193 started following Play in between outer and inner track rod end
lizzz joined the community
1.2 TSi CZJC Lumpy, stalled, wouldn't restart
UK Gov departments do need to keep in with big foreign companies it seems - "let the plebs burn" - and so reduce the pension burden.
Hola, desde España
Welcome to the forum, Juan! Having an Octavia RS 1.8T since new is great, there can't be many original-owner cars left. How's it holding up? And have you done much to it over the years, or is it still mostly standard? There's plenty of knowledge on these engines here, so don't be shy about asking questions. Photos of the car are always welcome too.
AmeliaParker started following Hola, desde España
Zeko started following Skoda superb
Skoda superb
Hello everyone. I have a problem with camera on my superb 2022. When sensor are active I can hear only sound of them, can’t see the rear of car on display. No fault on dashboard. Does anyone had this problem?
Zeko joined the community
MartinLipert joined the community
Today
^^^ My MY16 Octavia (1.4 TSI CZDA) experienced this issue two years ago - reported it to DVSA as a serious safety issue - the reply I received was 'No fire safety issue as there was no ignition source present'! There was a recall for exactly this issue in the US - the VW recall was 24GI.
Wheel nut torque
That used to be for the "biggest" 4X4s in VW Group world.
Chri Harris on Cars.
Yup, though best kept away from steam train enthusiasts!
Wheel nut torque
From the manual for the pre-facelift: Have the tightening torque of the wheel bolts of the mounted tyres checked with a torque wrench as soon as possible. The specified tightening torque is 140 Nm.
Rbz5416 started following Wheel nut torque
Wheel nut torque
120Nm is a good starting point!
Battery issue or?
9 volts is a bit low when cranking - I'd suggest a battery test if it's falling that low. From memory, around 10 volts is a healthy limit.
This could be the first one being reported on this forum:- Fuel Leak! - Skoda Fabia Mk3 (2014-2021) - BRISKODA
I have just watched Chris Harris on cars and him driving the TWR Supercat. It is a month since it came on YouTube and some how it passed me but. He is just a test driving god and a dude IMO. PS. Love the Ravage A110 and his vid driving it and his meet up.
Evolution13 started following Chri Harris on Cars.
Wheel nut torque
I have been though the hand book and searched the forum, but can not find the wheel nut torque setting. Any offers. 2025 Karoq, 1.5 sportsline, 19" wheels.
I don't think that VW Group ever did a recall and fix campaign for this problem in Europe - they always seem to stick with "it's just wear and tear - now give us your money". It does not seem to affect every engine over a certain engine production period - but that car's engine will probably be within this period of "uncertainty" - if a bolt fails, ie its head snaps off, then there should be some indication from the dashboard as the fuel rail pressure will drop below its intended level - and petrol will be spraying out over the front of the engine - and I don't think that is healthy. This might sound like I'm being alarmist, but when I initially found out about it, I was seriously concerned and contacted DVSA about it, and they replied to say that they knew about it and VW Group had told them that there is not a safety issue as the driver will get a warning from the dashboard that something is wrong! In other words, there is not "enough meat" in this issue to set their flag to issue a recall or any other action - so all is said to be good. There does not seem to be any fixed time period or mileage period in a car's life when this will happen if indeed it is going to happen.
Battery issue or?
My 1.5 is 14 months old, twice it has failed to start along with a stream of unrelated error messages. The first time (new car 3 days old) after leaving for a few hours it did start with fewer error, several restarts cleared the messages. Next day I took it to Skoda, they spent about an hour on it and found no faults, they said it must have been a glitch! 6 months later it did the same, but multipule restart attempt and opening / closing locking doors, the error went away and the car started. Each time this happened, the battery could have been low, the first time being in the Skoda garage, the second time it was frosty. I do not use the car regulary, so once a week I put my battery charger on it to charge it to 100% I believe that the cars alternator only charges up to about 80% to allow for some regen. Not good for starting, not good for the life of the battery. I think there are several posts on this in the forum.
Bixenon Headlights auto-adjustment problem
Hello Guys, Cairus. I am back. Today I noticed, that rear sensor reading disapered many times during checking... Log: OBDeleven data log Date: 2026-11-26 10:17 VIN: TMBAB7NP9H7043087 Car: Skoda Superb Year: 2017 Body type: Saloon Engine: CZEA Mileage: 200994 KM --------------------------------------------------------------- 01 Engine System description: R4 1.4l TFS Software number: 04E906027BT Software version: 9177 Hardware number: 04E907309AB Hardware version: X23 ODX name: EV_ECM14TFS01104E906027BT ODX version: 001011 Long coding: 0119003223241D087000 Trouble codes: No trouble codes found --------------------------------------------------------------- 03 Brakes System description: ESC Software number: 5Q0614517CG Software version: 0643 Hardware number: 5Q0614517AG Hardware version: H62 Serial number: 63336000003359 ODX name: EV_Brake1UDSContiMK100IPB ODX version: 036010 Long coding: 1D076A9C3424236F4777060840CA49B8562CC4E2600292751020F078C002420000000012121212B835351919323200 Trouble codes: No trouble codes found --------------------------------------------------------------- 08 Air Conditioning System description: AC Automat Software number: 3V0907044ED Software version: 4101 Hardware number: 3V0907044ED Hardware version: H34 Serial number: 00000B00324323 ODX name: EV_ACClimaPrehVW37X ODX version: 002019 Long coding: 11010004000110011005000000101002 Trouble codes: No trouble codes found --------------------------------------------------------------- 09 Central Electrics System description: BCM MQBAB M+ Software number: 5Q0937084CF Software version: 0236 Hardware number: 5Q0937084CF Hardware version: H34 Serial number: 02001632001418 ODX name: EV_BCMMQB ODX version: 017001 Long coding: 000000000000000000000000000000000000000000000000000000000000 Subsystems: System description: 48x LL 161110 Software version: 0121 Hardware version: 032 Serial number: 00000001611070401503 Long coding: 165DDD System description: RLHS Software version: 0105 Hardware version: 042 Serial number: S4Y16M11D28H07M44S42 Long coding: 00084D System description: Sensor, DWA Software version: 0316 Hardware version: 005 Serial number: 000000000ZY162840X20 System description: Sirene, DWA Software version: 0314 Hardware version: 005 Serial number: 00000000000067654546 Trouble codes: No trouble codes found --------------------------------------------------------------- 13 Adaptive Cruise Control System description: ACC BOSCH MQB Software number: 3Q0907572C Software version: 0196 Hardware number: 3Q0907572C Hardware version: H05 ODX name: EV_ACCBOSCHVW48X ODX version: 001009 Long coding: 2A00600111FFC428949C8045 Trouble codes: No trouble codes found --------------------------------------------------------------- 15 Airbag System description: AirbagVW21 Software number: 5Q0959655AT Software version: 0317 Hardware number: 5Q0959655AT Hardware version: 003 Serial number: 003TYR2CKK7P ODX name: EV_AirbaVW20SMEVW37X ODX version: 002154 Long coding: 98CCC0C0000000005C5400CF000800000065 Trouble codes: No trouble codes found --------------------------------------------------------------- 16 Steering Column System description: Lenks.Modul Software number: 3Q0953521DD Software version: 0235 Hardware number: 5Q0953569A Hardware version: 075 Serial number: 20161022400467 ODX name: EV_SMLSVALEOMQB ODX version: 001015 Long coding: 1004 Trouble codes: No trouble codes found --------------------------------------------------------------- 17 Dashboard System description: KOMBI Software number: 3V0920740A Software version: 8311 Hardware number: 3V0920740A Hardware version: 205 ODX name: EV_DashBoardVDDMQBAB ODX version: 009051 Long coding: 07A501122B80000801882A011000000000000000 Trouble codes: No trouble codes found --------------------------------------------------------------- 19 Gateway System description: GW MQB High Software number: 3Q0907530C Software version: 5286 Hardware number: 3Q0907530C Hardware version: 515 Serial number: 29111610801221 ODX name: EV_GatewNF ODX version: 013020 Long coding: 0B0100047F085700EB00024A080F00010001070000000000000000000000 Trouble codes: No trouble codes found --------------------------------------------------------------- 2B Steering Column Lock System description: ELV-MQBB Software number: 3Q0905861 Software version: 0032 Hardware number: 3Q0905861 Hardware version: H05 Serial number: 16000318766007 ODX name: EV_ELVMarquMQBB ODX version: 001007 Long coding: 0000000000000000 Trouble codes: No trouble codes found --------------------------------------------------------------- 42 Driver Door System description: TSG FS Software number: 5Q4959593E Software version: 0032 Hardware number: 5Q4959593B Hardware version: 010 Serial number: 0000230432192 ODX name: EV_DCUDriveSideEWMAXCONT ODX version: 006001 Long coding: 001D0820D000040000001100 Trouble codes: No trouble codes found --------------------------------------------------------------- 44 Steering Assistance System description: MQB_PP_APA Software number: 5Q0909143P Software version: 2051 Hardware number: 5Q0909143E Hardware version: 204 Serial number: 0001208480 ODX name: EV_SteerAssisVWBSMQBA ODX version: 009129 Long coding: 01000010004000 Trouble codes: No trouble codes found --------------------------------------------------------------- 4B Multifunction Module System description: FCM MQB Low Software number: 3Q0907338 Software version: 0285 Hardware number: 3Q0907338 Hardware version: 001 Serial number: 29111610520147 ODX name: EV_MultiModulContiVW48X ODX version: 001010 Long coding: 000000020100066A00003F00000000000000000000000000000000000000 Trouble codes: No trouble codes found --------------------------------------------------------------- 52 Passenger Door System description: TSG BFS Software number: 5Q4959592E Software version: 0032 Hardware number: 5Q4959592B Hardware version: 010 Serial number: 0000230544712 ODX name: EV_DCUPasseSideEWMAXCONT ODX version: 006001 Long coding: 001D0220D000040000001100 Trouble codes: No trouble codes found --------------------------------------------------------------- 5F Multimedia System description: MU-S--ER Software number: 5Q0035840B Software version: 0359 Hardware number: 5Q0035840B Hardware version: H30 Serial number: SKZAZ2S5278934 ODX name: EV_MUStd4CTSAT ODX version: 001022 Long coding: 03840100FF0000005111000100080A002F0100C40120010002 Trouble codes: No trouble codes found --------------------------------------------------------------- 6D Deck Lid Control System description: HDSG-Modul Software number: 5Q0959107L Software version: 0261 Hardware number: 5Q0959107J Hardware version: H13 Serial number: 31058602000000 ODX name: EV_DeckLidCONTIAU736 ODX version: 001014 Long coding: 1008 Trouble codes: No trouble codes found --------------------------------------------------------------- 76 Parking Assistance System description: PDC 8 Kanal Software number: 5QA919294A Software version: 0038 Hardware number: 5QA919294 Hardware version: H07 Serial number: 00030841861632801801 ODX name: EV_EPHVA18AU3700000 ODX version: 009031 Long coding: 0471051041 Trouble codes: No trouble codes found --------------------------------------------------------------- B7 Start System Interface System description: VWKESSYMQB Software number: 3Q0959435E Software version: 0811 Hardware number: 3Q0959435E Hardware version: 036 Serial number: 0423976491 ODX name: EV_KessyHellaMQBAB ODX version: 004039 Long coding: 032C0C0E03 Trouble codes: No trouble codes found
Phone connectivity - the big picture
Thanks Steve, I'm aware of most of what you mention but as ever with this car it just begs more questions... I've been connecting via Carplay almost since day 1, I understand that it uses Bluetooth for the initial connection then flips over...and I've never once seen this "disconnected" message...until now...why? Looking at the docs the "use infotainment as hotspot" seems to be a cash generator for Skoda if you want to sign up for their data plan. I don't so thought I'd disable that - and found out if you do that it kills Carplay, so you need to keep it enabled...I'm 18 months into this over engineered toy....sorry....car and still finding stuff out, it's crazy. Which is why I'm asking is there a graphic showing how it all links together or a start to finish guide on how to setup the iphone in the car?
Coolant overflows
Before paying for a head gasket I'd pin down where the gas is getting in. A reading that jumps to 105 and drops back to 92 within seconds is often a pocket of gas going past the temperature sensor rather than the engine really getting that hot, and coolant being pushed out only after a couple of hard pulls fits combustion or exhaust gas getting into the coolant under load. A block test done at idle can come back clean when the leak only opens up under load, so I'd repeat it straight after a couple of hard pulls, with the tester on the expansion tank as soon as you stop. The EGR cooler is also worth ruling out, as it's coolant cooled and sees exhaust pressure that rises with load, so a leak there can do exactly this. A garage can pressure test the cooler on its own, and a cylinder leakdown test will show up a head gasket if it is that. Both are cheaper than fitting a gasket on a guess.
SparePartAlam started following Coolant overflows
Correct, Voltage while actually cranking.
Chime after locking and unlocking car
Thanks for all your replies guys. It was the alternator. diode failed
9.5V is not minimal starting voltage. it is a voltage drop during cranking. if you have 9.5V battery, it wont start at all..
RobertNrecaj joined the community
14000Ah is ~ 15.3Ah/day, won't knock a measurable dent in the battery's SOC even if it fell by this amount. Some blame the frequent starting in Stop/Start for a lot of battery problems but if you think of it, each start only takes a fraction of a AH, if you run a VCDS log on battery current, you will catch most of it, mine, shows between 179A and 200A, a 2sec crank will still only consume, 200*2/3600, 0.11AH, your (hot) diesel might pull say a max of 350A for a (we'll give it) 3sec crank, 350*3/3600, 0.29AH, the glow plugs will consume possibly as much even though only on very briefly, if at all, with a hot engine. Even though we all profess to hate this smart charging and a max of 85% SOC etc, I would only worry if the battery is deep discharged and also, more worrying, its internal resistance, which is inevitable. If you accept that say 9.5V is the minimum starting voltage required and on a cold morning your diesel requires 350A and that the standstill battery voltage is 12.5V, voltage drop is 3.0V, internal resistance would have to be, (3/350)*1000, 8.57mOhms, so maybe set somewhere around there as your warning flag. If you forget all that jazz above, just do what I have done for over 60 years, get someone to crank the engine while you watch the voltage on your multimeter with the probes on the battery terminals. I think the majority of damage done to batteries is done in the parking lots where the cars can sit for months with the batteries in deep discharge. I have a April 2026 Polo and I reckon the battery has suffered this fate.
clydeglass joined the community
highly recommend getting a throttle controller like EVC, to address this. i've got one in my Superb, been a number of years. makes a big difference. very easy to install. EVC Throttle Controller for VOLKSWAGEN GOLF
After only 2.5 years my ah is over 14,000ah total energy throughput.
Garage Labour Time Per Job....
That's taking the ****, especially if they didn't even track it. I wouldn't be going back there again, and I'd probably still be raising **** with them. Yes, props for being thorough and replacing the CV grease, but you don't need to take the brake assembly or any suspension off, you can just undo the bottom ball joint from the wishbone. You can take the CV end off without taking the driveshaft off the car with the right puller. I'm not even a mechanic, but the only way it'd take me 5 hours to do a pair of them is if I had a 2-3 hour lunchbreak in the middle.
