  1. Yesterday
  2. @pab567 Request for MSTD_EU_SK_P6230 MU0490 Firmware. Thanks in advance !
  3. P S. in the interim I think I will switch start/stop off. I understand there's a button to switch off the system when setting off on a journey. No more rush hour embarrassment with a green light in front of me, hazard lights flashing and an angry queue behind me!
  4. mjasmin joined the community
  5. Thanks for your reply, useful to know it can be done by oneself, however I'm not too car DIY competent (cars have changed too much during my lifetime) so I might be better having the battery fitted and coded at a service agency. I'll get some prices fitted and coded and x chk cost of just getting a battery and the device you recommend, if it's quite different I might try updating my knowledge! Thanks again.
  6. best way is to top up canister with diesel before putting lid back on, you'll never get any problems with airlocks
  7. Been tightening up on car security, days of nobody steals skoda's are long gone, they steal everything and anything nowadays. Got a disklok, and moved the obd connector to a hidden place with one of these, it leaves a dummy obd in the original place and if scumbag plugs into it, it appears to work but no coding can be done. thinking about fitting a hidden kill switch as well
  8. If it's a front wheel drive Superb MK2 estate with standard ride height (ie. not lowered ride height or increased ride height), then fitting slightly stiffer rear springs such as two up in the hierarchy should solve the soft rear end problem when the car is loaded. As mentioned in my previous post the upgraded rear springs have OEM part number 3C0511115AF.
  9. Fairly sure its Torx, we tried Spline and Torx and torx got a much better grip, and all the tensioners for this engine have been torx, i think its just really stripped
  10. I found this video where he prunes using a code reader but says you can just start normally if you don’t have one. He also has other basic service videos on superb which are handy.
  11. hello hope all is well does anyone have the following: VW Polo 6C 3Q0035874A (MST2_EU_VW_ZR_P0241T) stuck in Emergency Download (Device: cpu Module: cpuboot%1 FileReadError). mibsolution.one is down and MIBVault's P0254T.7z is missing cpu/cpuboot_sec/12/default/Bootloader/init_mibstd2_cpu.dat (SHA1 ad9423fb38ff88c37e3521c58d161785c2ced62e). Can anyone share a working GDrive/MEGA link for MST2_EU_VW_ZR_P0253T.7z / P0252T.7z or that 45KB init_mibstd2_cpu.dat file? currently stuck in red emergency download. i used this file (3.5gb)MST2_EU_VW_ZR_P0254T.7z [21/11/2026 21:44] jessreadingx: https://mibsolution.one website is down and doesnt work also @pab567 @varooom
  12. Don't look for them physically, instead use a scanner like OBDeleven or VCDS. That's how u find out part numbers.
  13. fclx0 joined the community
  14. I think that that reason is acceptable when a car part does not cost much, but once the cost reaches a certain level, owners have a right to expect that parts are fit for use - and fit for use over a reasonable period over time/miles. I'm guessing that this part cost roughly £200 from Skoda UK. I replaced a Lambda sensor on my wife's 2015 VW Polo 1.2TSI this year at roughly 60,000miles, even although I was careful with the Lambda sensors connector support bracket, I broke a tang off it when removing the faulty Lambda sensor connector. I fitted a new support bracket this week and while removing the old bracket, I broke a tang of the "other" Lambda sensor mounting point, the new bracket only cost £6 I think, so no big deal - but that was due to the plastic becoming brittle with age and local heat. One annoying bit of this job was, the cable tie mounting that snaps into this bracket, partially broke up while I was removing it from the original bracket - again "not very suitable" plastic - the sort of thing that people used to complain about when buying/using stuff "made in China" - how standards have dropped in Europe, or even from suppliers that European manufacturers use!
  15. I understand. I had more doubts as well. In my country it costs me around 20 euros, which I will compensate by doing the oil change myself and saving in labour costs haha. Also, here’s an article about the reduced noise and vibration levels by using the product: https://www.team-bhp.com/forum/technical-stuff/196980-review-liqui-moly-cera-tec-friction-modifier-my-skoda-laura.html
  16. The last FEAD belt that I replaced was on my wife's 2015 VW Polo 1.2TSI and it was a Contitech (Continental) that I bought. The belt for her previous car, a 2002 VW Polo 1.4 16V, that I bought was a genuine VW Group part - and it was a Dayco "made in France", and it, when opened out and laid down on a flat surface it had a "bow" in it, ie it only touched the flat surface at 2 points - I examined it and discovered that it had been cut at an angle to the weave - or at least the smooth side material had been, I still fitted it and it lasted okay. I did expect better from VW Group, but there again, I've had failed front wheel bearing due to water ingress - and that bearing was "made in France"!
  17. yeah will do, we tried to get the belt off earlier today and the bit kept slipping off, gonna have to take it to a garage, which is rather annoying as i already bought the belt but im guessing they will want to use their own parts for insurance/warrenty purposes i guess i have a spare belt now 🤷‍♂️ or i could also return it as well as its still in its packaging
  18. Oh well, my mate's Autodoc parcel arrived, meant to be 2 rear callipers, but it seems he has been sent 3 Ridex callipers AND a Ridex radio! Hopefully he attempts to refurbish the 2 original rear callipers and just uses these Ridex cheapies to keep things moving!
  19. Not all modern engines can be repaired easily it seems.
  20. No, just a straight change of old for new. It turned over a bit to start and then the eml light came on. Just turned it off and restarted and eml light went out. My mate reckons it was due to low fuel pressure with changing the filter. Been fine since. :)
  21. Rear shocks, electric tailgate struts, rear discs, 2016 diesels had a bad batch of water pumps, others are ok I think. Some DQ381 7 speed dsg's have failed mechatronic units. Other than that full service history and overall condition.
  22. Replace complete tensioner, not just roller, 2 months ago I put on my 1.5 tsi INA tensioner and belt. Car had 100000 kms. Belt seems to be high quality. Shiny surface which suppose to be dayco or gates. Always choose belts with shiny surface, not matt, it is newer technology. More durable. Original was also shiny one.
  23. Just in case someone is interested: I have been running a JL Audio 10TW3-D4 (2x4 ohm) sub for a year hooked to the Canton sub channels. Works perfectly, no problems whatsoever and enough bass for me. I have cranked the stereo to the max and no issues. The enclosure is a car-model-specific from basser.pl. Installing 10TW3 to the enclosure requires some modification to the speaker hole, the original has to be enlarged a bit. Additionally, the mounting flange needs to filled up with plywood. I also took the trouble or lining the inside of the enclosure with 50/50 mixture of sand and poly resin. This made the walls rock-hard.
  24. Where are these modules located or how can I check if my car has the right ones? It's a 67 plate Sportline if it makes any difference. Thanks
