Past hour
14000Ah is ~ 15.3Ah/day, won't knock a measurable dent in the battery's SOC even if it fell by this amount. Some blame the frequent starting in Stop/Start for a lot of battery problems but if you think of it, each start only takes a fraction of a AH, if you run a VCDS log on battery current, you will catch most of it, mine, shows between 179A and 200A, a 2sec crank will still only consume, 200*2/3600, 0.11AH, your (hot) diesel might pull say a max of 350A for a (we'll give it) 3sec crank, 350*3/3600, 0.29AH, the glow plugs will consume possibly as much even though only on very briefly, if at all, with a hot engine. Even though we all profess to hate this smart charging and a max of 85% SOC etc, I would only worry if the battery is deep discharged and also, more worrying, its internal resistance, which is inevitable. If you accept that say 9.5V is the minimum starting voltage required and on a cold morning your diesel requires 350A and that the standstill battery voltage is 12.5V, voltage drop is 3.0V, internal resistance would have to be, (3/350)*1000, 8.57mOhms, so maybe set somewhere around there as your warning flag. If you forget all that jazz above, just do what I have done for over 60 years, get someone to crank the engine while you watch the voltage on your multimeter with the probes on the battery terminals. I think the majority of damage done to batteries is done in the parking lots where the cars can sit for months with the batteries in deep discharge. I have a April 2026 Polo and I reckon the battery has suffered this fate.
Today
clydeglass joined the community
highly recommend getting a throttle controller like EVC, to address this. i've got one in my Superb, been a number of years. makes a big difference. very easy to install. EVC Throttle Controller for VOLKSWAGEN GOLF
After only 2.5 years my ah is over 14,000ah total energy throughput.
Garage Labour Time Per Job....
That's taking the ****, especially if they didn't even track it. I wouldn't be going back there again, and I'd probably still be raising **** with them. Yes, props for being thorough and replacing the CV grease, but you don't need to take the brake assembly or any suspension off, you can just undo the bottom ball joint from the wishbone. You can take the CV end off without taking the driveshaft off the car with the right puller. I'm not even a mechanic, but the only way it'd take me 5 hours to do a pair of them is if I had a 2-3 hour lunchbreak in the middle.
Play in between outer and inner track rod end
It might just be the picture, but the thread on that track rod looks pretty mashed up, which probably doesn't bode well for the state of the lock nut of the thread in the end. For how little money they are, I'd probably think about throwing a complete new rod and end on the car. For suspension parts, I normally try to get a FeBi / Bilstein part, they probably made the one that was originally on the car
skoda7328 joined the community
Yesterday
1.2 TSi CZJC Lumpy, stalled, wouldn't restart
I find it more than adequate. They can be modified to produce frankly ridiculous power for a little 1.2 (obviously my sister couldn't care less... but I had to look!) My sisters is on 105,000 now and prior to this, absolutely nothing at all has gone wrong. It has 100% been the most reliable car in our family collection. I don't know about those bolts no, I'll swing by on the way home tomorrow and just see if she's got a campaign sticker or marker anywhere under the boot carpet or in her service book. Thank you for this useful info that could potentially make a massive difference to someone's very existence.
Superb Mk4 Owner's Manual Now Available
Confirmed. Just had a look and yes it goes to the web version but you can download it as a PDF . Thanks @Cedwing !
lduffman started following Superb Mk4 Owner's Manual Now Available
Phone connectivity - the big picture
The car can connect to your iPhone by Bluetooth OR CarPlay (of your choosing) at any one time. Connection by Bluetooth is what shows as Disconnected in the centre of your speedometer - this is due to the phone having a CarPlay connection. Using the car menu settings for Phone (or mobile devices, can’t remember the exact name) you can select the connection type for each phone. The car should remember the previous connection selected. To make calls via CarPlay, long press the voice control button (left side of steering wheel) and use Siri (call name).
SteveTheElder started following Phone connectivity - the big picture
Who’s run a 4WD without the rear differential?
ath joined the community
This almost exactly 8 year old (Jan 2019) petrol Polo with a 59AH EFB battery is working perfectly, last set of readings (below) taken last June after 7.5 years, all short runs up to passing it on to our daughter in April, only ~ 40K KMs on it then, now > 50K Kms, wife always inhibits stop/start, I use it as I see fit. IDE01834 Battery voltage 12.193 V IDE01836 Battery current -4.950 A IDE01839 Battery charge status 77 % IDE01841 Battery internal resistance 7.6 mOhm IDE01842 Usable battery charge 28 Ah IDE01948 Battery internal resistance not normed 6.0 mOhm IDE07681-MAS06086 Battery total charging throughput-Total re-charge 3890.7 Ah IDE07681-MAS06087 Battery total charging throughput-Entire energy throughput 4091.0 Ah
Johngerard started following How are your EFB batteries holding up?
Rum4mo The looseness appears to be between the track rod ends! Just to right of locknut in photo, but lock nut is done up tight. QuoteWhy does it look like the TRE lock nut is not bearing up tightly to the TRE end? Mechanic said you can get your nail in that gap as it opened and closed, but I've had a go at tightening lock nut with wheel off ground and it is tight. That photo was taken before getting home so maybe it did tighten up slightly. Kwik fit assured me if lock nut was loose I'd quickly get adverse symptoms with steering... I've tugged on inner track rod ball end and it has no play. The outer tre with rubber seal is not damaged and swivels as normal. Nut is tight. Weird situation. I repainter calipers in summer and this play in wheel wasn't present. Lemforder outer tre Possibly Delphi or similar inner tre
Mine is just about on 4 years and working fine. The car is often left sitting in the garage unused for several days at a time so I always keep it 'trickled' on the CTEK charger with the car locked (to assure full shut down).
SouthernComfort started following How are your EFB batteries holding up?
- Play in between outer and inner track rod end
Bonnet support clip come away
One final thing, the correct part number for cars built up to 15/05/16 is 1U0 823 397, and the correct part number for cars built from 16/05/16 onwards is 6V0 823 397. I don't have any reason to consider that there is much of a physical difference - but the part number was changed for a reason. Also 1U0 823 397 was changed to 1U0 823 397 121 Rapeseed yellow at 01/08/22 and 6V0 823 397 was changed to 6V0 823 397 121 Rapeseed yellow at 01/10/16
I need to take mine out to get it rebuilt - Octavia Scout 2015 - and according to Google, if I take out the diff and prop, but leave the CVs in the hubs, it should be ok. Has anyone done it for long? Has anyone got a good spare diff in the uk midlands
Haldex versions
Did you have any luck? I know a guy in Wales I’m going to get to rebuild mine (2015 Scout TDI). I’m not very near Wales though, but I trust him.
Fabia VRS LE Register Part Trois
419 checking in 🫡
Battery issue or?
Drop is normal to 9V when cranking.
imart143 started following Battery issue or?
barn find felicia pickup.
Got a deal on disks and pads so they're in the post as well, but they won't go on till it's driving, it can live on lipped disks and cracked pads for now. I still hope it's going to just come together in an almighty RUSH and go down the road and MOT first time.... but also I'm insane, so...
Great result, I didn't post to this thread as I had nothing useful to offer seeing as my wife's 2015 VW Polo 1.2TSI 110PS, ie the "D" version is still running perfectly at over 61,000 miles. Your sister's car's engine was built in the "production period" where the high pressure fuel rail retaining bolts torque was suspect due to an assembly line tooling issue - do you know, if it was bought used, if the bolts had been checked or replaced and torqued correctly prior to her buying it? My wife's Polo seems to have been built just months before this engine build error. They are very "pleasant" engines to have in a small car.
Software Update available for Bolero?
I didn't find one newer than 1800.
The thread on the inner TR is in the steering rack - so is the inner track rod tightened up correctly to the rack - or has its ball joint failed - which brand of parts were used. Surely, with an assistant you can work out which end is causing this problem. Edit:- I hate working on cars when it is near freezing - crap happens though!!
Just got some new tyres Michelin ps5 for the fabia that were in black Friday deal. Tyre fitter noticed 3 to 9 o'clock play across tyre on front left wheel. Showed me it moving near lock nut which was tight. Fitted inner track rod ends 55k ago but both outer track rod ends had split on rubber. I fitted lemforder outer TREs and new ball joints then wheel alignment. March 2025. The play seems to be the thread holding the outer and inner TR together. So, do I just replace 1. inner and outer TRE? Both sides inner tre and outer tree? Do both sides and think about new shocks and springs, top mounts, drop links (55k miles, 9 years on) in case shocks are problem. At 65k last shocks were toasted but suspect due to previous owner. However on our watch rear shocks were hitting bump stops after 30k miles. Don't you just love doing these jobs in the cold 🥶 If 3. Other than a dealer where should I get all fasteners for the strut? Thanks Ps same number of threads visible on both track rod joints on both sides of front axle.This pic shows the affected side but really doesn't show anything unless you watch video
bmbmdmb started following Play in between outer and inner track rod end
Battery issue or?
More likely to be the drop in battery voltage during cold crank - then the voltage recovers when the alternator kicks in.
Warrior193 started following Battery issue or?
Radio cutting out new starter motor
Reporting back The add-on hardware for radio did not work. Incartec 10-602 was fitted and had no effect on losing the radio's power. Returned. Incartec said try 10-603 which is for start stop vehicles and has capacitors. Upon switching on ignition the radio behaves as if it has been disconnected for a long time. The presets are lost and the time. Volume is set at default. On cranking it maintains power to radio but having lost most of the functions on ignition on, it is pointless. Don't know if this is a faulty old stock (it contains capacitors), but I'm returning. I'll put up with radio cutting out. Breezy Pete - ferrite connectors. Do you think these are still worth trying? Thanks
