  2. .....although I have, during this freezing weather where salt is being kicked up, discovered that there are no headlamp washer units on our car 🤔. A bit retro, and maybe a bit penny pinching? I'm back to 1990 and a small plastic bottle of diluted washer fluid in the boot, plus a microfibre. At least LEDs don't run hot. TBH, somewhat surprising and not something I thought necessary to check. The body of the front bumper looks too narrow for pop-up washers. Hardly uppermost in the list of life's issues but an odd omission. But in the interests of fairness, I think you would get this on an E-Class 😅. Have a nice day!
  3. Can other mk3 owners confirm that battery light on with ignition is the expected behaviour please? I wouldn't necessarily assume that.
  4. Today
  5. actually it is no charging mode, its much simple. it is switch for off button that works on/off after install. so you turn on or off start stop and it stays in that position when you like to change just press it again. https://www.ebay.co.uk/itm/405999540429
  6. Cuoresacro joined the community
  7. it should be regular repair. or new crankshaft if no machining.. new crankshaft and all new bearings and job done.. new engine? i cant belive that. only if cilinders are damaged. even crankcase can be welded. yeah it is maybe in less rich countries, you Brits buy new engine.
  8. Thank you both. Voltage at battery does vary in line with expected on a ‘smart’ alternator. I have changed the battery and all was good for a few days and then the christmas lights came back on! I have checked the exciter wire to the plug/socket on the front of the engine block and it is good to there from the alternator. I don’t know where the wire goes from there, whether it is straight back to the ecu or to somewhere else so I can’t check further back annoyingly.
  9. Thanks for this. I don’t know what a “CP Master” is, but with the need to involve a Skoda partner, who’ll no doubt say of course we can do it, it sounds like an expensive and a potentially disaster-filled project, so I’ll swerve it….
  10. I don't know why you would put an additive in the oil. The recommended oil for VAG group engines is to the highest fully synthetic oil specifications and why it is relatively expensive. Good enough for endurance racing engines.
  11. Gateway Change, but it is CP Master, you need a Skoda Partner with odis online You will need to re-enable the functions; otherwise, certain features will not work. Do not forget the coding and the dataset.
  12. Ahh. Yeah. Good point! 😳 The gateway is a 5Q0 so it’s a no-no then? Could the gateway be changed JR or would this create issues with other systems?
  13. Yesterday my 69 kodiaq went into.limp mode but i managed to get it home , noticed smoke coming from the bonnet and upon lifting the bonnet I discovered this mess when I unclipped the heat cover .. day before I replaced the dpf pressure sensor with a new bosch one but the car was still coming up with the sensor error .. any ideas guys ? Thanks in advance
  14. Since the introduction of the MQB platform with Immo 5A, there is no longer a "key code" in the traditional sense. When you order a replacement key, it is requested based on your VIN; it comes directly from the factory rather than a central warehouse. The key blade is manufactured by a supplier to match your specific lock—as recorded in the vehicle documentation—and the electronic component is programmed with your VIN. This allows the dealership to officially register (teach in) the key to your vehicle. Alternatively, you could purchase a key from a source like AliExpress and find a skilled CNC operator or locksmith capable of accurately cutting the blank (note that there are two different versions of the key blade). Furthermore, the CS (Component Security) code—which is essential for preparing the key and registering it to your vehicle—resides within the instrument cluster, which acts as the "Immo Master." The tools required for this process typically cost around €1,000.
  15. Yesterday
  16. Hi guys been having trouble with my kodiaq 2.0 tdi 69 plate , then yesterday I managed to get home whilst in limp mode and discovered this damage to my newly fitted dpf pressure sensor .. Just kept flagging up a dpf sensor fault even when it was replaced.. do you have to code the sensor to the car at all ? Just ordered replacement parts from a scrapper of the same year kodiaq ... my car in the last couple of weeks seemed to be in constant regen mode .. any advice would be greatly appreciated..
  17. tommyboy68 started following Melted Mess !
  18. There's probably a huge margin and lots of labour in swapping an engine. Does no-one repair engines anymore?
  19. They did check the hub on both sides and said they looked okay. Checked them for misallignment or warping.... frankly I would like to think you were right as thats a lot cheaper repair than what im starting to think....
  20. Brkicn joined the community
  21. Hub damaged due to heavy kerbing at some point in its life - they should have checked hub face runout after the first replacement discs "went bad".
  22. Hello all. New to the forum, and relatively new to skoda... I have a really puzzling issue i hope someone can help with I have a 2015 fabia mk3 1.4 diesel. Purchased last year. About 6 months ago the brakes developed a pulsation... as if they were snatching rather than biting, so lurching on braking. Took to garage. Warped front discs. Replaced... and about a month later the pulsation returned... same warped discs. Replaced again... now on the 3rd set and its back again. So further investigation undertaken at garage. They ran the car under braking and managed to get the brake temp up to 90 degrees, but brakes were still releasing as they should with no binding. Important... also NO warning or fault lights on the dash So according to the mechanic that eliminates calipers and master cylinder. They do have a vague theory but they are really unsure and ive already had someone else say they can't be right so rather than put it in people's heads ill let people throw there own thoughts at me first. I really hope this can be sorted as I do like the car and would rather not let it go. Any help would be greatly appreciated
  23. JackMaines joined the community
  24. steve2602 joined the community
  25. That seems to be a popular "fixing" price, my mate got that cost/quote when he took his 2019 VW T-Roc 1.5TSI DADA DSG in to get its DSG sorted - he turned it down and sent it to WBAC instead!
  26. ian-inhome replied to ian-inhome's topic in Skoda Karoq
    I followed the instructions in the app to generate a key,then it said to copy it and paste it, only problem is I couldn't find out where to paste it. Google suggested suggested using Google assistant app but that has now changed to Gemini and you can't use that.
  27. Tasior joined the community
  28. Appreciate this is a bit of a bump of an old thread, but I wanted to register to say thank you for this - it's been driving me nuts for years and your post helped me "fix" it in half an hour. Cheers!
  29. molop joined the community
  30. Just an update. It was the seat belt tensioner. It must have been bedding in as it stopped making the winding noise after a week or so. Now you can just feel it tensioning up but no noise 👍
  31. Thank you that is very interesting to hear! I hate to appear defeatist, but I have a health condition and after the battle ensued, and continued for a few weeks I had a horrible flare up. I have to put my health before a car V dealer battle, but at the same time I have no protection if the limp mode happens again. The dealer said please don't hesitate to come back if you have any more trouble..... however I have no faith that they would be willing to try properly to find an answer. It would need to be before march when the manufacturer guarantee expires.
  32. Hi all. I took my V5 into Western Skoda of Dunfermline today. The service department kindly printed off any service history they had on the car as promised, but the parts adviser said he couldn't get me the key code to enable another key to be cut. Was he just being difficult? Can I try another garage or is it just impossible if I don't have the black tag with the number?
