Past hour
Peet joined the community
Chri Harris on Cars.
No, I tend to swerve away from Grand Tour stuff.
Today
Good series that was. Have you seen Francis Bourgeois on the new Grand Tour series. He can drive fast alright.
Apple CarPlay adapter recommendations
Budget one from AliExpress. Used it for about 8 months and it’s been perfect. Once it’s set up it connects by the time the car starts. Only thing I’ve noticed is a tiny delay in audio (e.g when changing tracks or if you’re watching a video when parked up) but this is the same as the wireless CarPlay built in on my wife’s kodiaq so it’s not down to this adaptor. I just found this on AliExpress: https://a.aliexpress.com/_EydTvyw
Binx1310 started following Apple CarPlay adapter recommendations
Radio database field BLANK on MIB3 FM radio - Australia (2021 Kodiaq, SW 0330)
I concluded that PhonoStar don't support mib3 icons in Australia when it last came up before and I looked. The question is what icons do the units have on them in Australia. The DIY firmware update that people do will wipe the icon storage... pretty sure, so buying a secondhand car could be pproblematic. Probably something to check.
ABS fault codes in VCDS but no warning light.
Hi, 2012 Superb 2 Estate - 140cr DSG - 70,000 miles As title really - both rear wheels showed faults during a routine scan. Also ABS Control Module fault. No warning light on display. I had both rear tyres checked for air loss a little while ago and new valves were fitted - so they had the wheels off. Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb Part No: 1K0 909 144 P Component: EPS_ZFLS Kl. 000 3305 Revision: 00H22000 Shop #: WSC 18598 000 1048576 VCID: 372B28B10349808216A-8062 1 Fault Found: 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 219 Mileage: 111296 km Time Indication: 0 Date: 2021.04.18. Time: 10:56:40 Freeze Frame: Voltage: 14.00 V DU Temperature: 31.0 C RPM: 1242 /min Speed: 4.0 km/h Speed: 4.0 km/h Count: 0 Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V2.clb Part No SW: 1K0 907 379 BH HW: 1K0 907 379 BH Component: ESP MK60EC1 H31 0121 Revision: 00H31001 Coding: 863D601609260001610F06E490210082300000 Shop #: WSC 33361 790 00078 VCID: 79AFEE8979DD56F2A0E-802C 2 Faults Found: 00287 - ABS Wheel Speed Sensor; Rear Right (G44) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 1 Fault Frequency: 1 Reset counter: 219 Mileage: 111296 km Time Indication: 0 Date: 2021.04.18. Time: 10:56:40 Freeze Frame: Count: 0 Count: 0 Count: 4608 Count: 83 Count: 50689 Count: 0 Count: 0 Count: 0 00290 - ABS Wheel Speed Sensor; Rear Left (G46) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 1 Fault Frequency: 1 Reset counter: 219 Mileage: 111296 km Time Indication: 0 Date: 2021.04.18. Time: 10:56:40 Freeze Frame: Count: 0 Count: 0 Count: 4608 Count: 67 Count: 50689 Count: 0 Count: 0 Count: 0 Coincidence? What should I look for as a 1st step? Thanks, Fats
Play in between outer and inner track rod end
Thanks all. It is just the picture. It seems to be doing that When assembled it was solid. Kwik fit last to touch it during a wheel alignment. Could the ECP outer track rod not actually be the correct fit? I suspect the threads are indeed damaged internally. I'm going to change them both. But the driver's side which was also changed at the same time, identical brands, is fine. I watched the tech tighten up the lock nut. I even wire brushed the threads and gt85 before presenting for wheel alignment. Tech wasn't struggling at all if I remember (1.5 years ago). Passed 2 MOT (1 was 2 weeks after alignment and other 1 year later). If it had play they would have noticed this. The outer, inner rods don't want to pull apart (yet) but not safe I agree. Just odd it has taken so long to manifest. Is it the lock nut tightened up on dirt (it was all clean at time). Could bad roads cause this? I've changed gearbox mount and top engine mount in this time. Gearbox mount was causing an odd noise on full lock in reverse. Could this damage the joint between the steering rods? I'm going to replace the coil spring, strut shock and drop links and inner outer track rod. Ball joints were done 1.5years ago.
As title states. Trying to source a good quality adapter for only iPhone use. I have tried the AA wireless two+ to allow wireless CarPlay using an iPhone and it was a poor experience for music playback. Nothing would fix the random stutter so it’s been sent back. Looking for the best recommendation or even to start a list, from those that have one that works flawlessly. No need for android compatibility or multiple phones. Recommendations so far are for ottocast and carlinkit, but would like to hear personal experience from anyone who uses one daily without hassle please.
UndertheRadar started following Apple CarPlay adapter recommendations
- Fabia 2024 SE comfort mpi fault
2015 Scout Rear Diff Failure - Options
I have a 2015 Scout with the same problem. I think if I took out the diff, prop and shafts, but leave the CV joints in to clamp the bearings, then it should be ok to run 2WD. My haldex controller is dead as well as the noisy bearings, so I can’t see how it would throw a load of errors that it isn’t already entitled to throw. If traction control tries to run the rear differential then it won’t get a response. If I get the traction control excited - eg if it goes a bit lighter over a hump back bridge, it cuts the power for a second then calms down and carries on.
NunoYabiz started following 2015 Scout Rear Diff Failure - Options
johnny78 joined the community
Yes, sorry the attachment isn't there. Link is : https://www.carchecker.pro/reports/skoda_fabia_mk4_1.0_tsi.html I'll see if I can post the body of the article again. It's a long running nightmare with with our Fabia 4 mc. You just know that the dealers think older customers must be mentally challenged when they continually raise issues that they can't identify with their equipment. At least the article provides some expert evidence. Maybe, even persuade the dealer into helping you out of your pedicament but I wouldn't hold your breath on that one. Hopefully your model comes into this particular category. VAG group and Skoda are in big financial difficulties now. Chinese cars are building their share of the market very quickly.
You are averaging ~ 82 miles/day and 27 stop/starts, seems a extraordinary number of stop/starts, you must spend a lot of hours in the car. Ordinarily, that sort of mileage should have no problem keeping the battery at 85% SOC but couldn't see the SOC increasing by 10% in a short drive, my alternator only seems to charge at 1 or 2 amps after a initial burst of 15/20A for 20 seconds or so after starting, I put a 5A smart charger on my 2026 Polo a few months ago and even though the SOC was down around 70%, the measured charging rate fell to 0.15A so would need a mighty long night to get any sort of charge into the battery, it might charge initially at ~ 1A or so but as soon as the voltage rises to 14.4V or so it immediately sees the battery as being "full" and reduces the voltage to ~ 12.8V + 0.1shA, a CTEK might do better??.
Update of navigation maps
Hello, yes it's free.
jc_whiskey joined the community
Are these updates free.
andypandy1961 started following Update of navigation maps
Haldex versions
Rebuilding. Don’t know the cost but he’s not greedy.
I use the obd11. My battery charge status on average hovers between 68-73%. It never or rarely hits 80%. I’m not sure them readings are entirely accurate because i have seen it jump from 66% to 76% after only a very short drive. Also the percentage rapidly drops if you walk by the car a few times when the key is in your pocket. If your battery drops to 60% the start stop deactivates. Battery resistance has significantly increased. When new it was 3-4 millohms. These days it averages between 5-6 milliohms. Battery usable charge averages between 36-45ah depending on the battery’s mood and temperature. At the moment battery aging charging and battery aging performance is at 68% . That number varies too. Yesterday it dropped to 61%.
sonay joined the community
Haldex versions
No joy as yet 🤷🏻♂️ A couple of ideas to try but they are longshots. Is your guy in Wales rebuilding yours or replacing it? Without meaning to sound rude, how much is he charging?
There does seem to be always something else to a thread as I'm discovering. My suspicion has been that the turbo version ,at least, doesn't take kindly to lots of very short runs. After our service the wife drove to the dentist which isn't far as a crow flies but is always a slow crawl in practice. When she got back she mentioned that the crazy tips as to which gear to choose were back. A longish run has fixed it but getting over 50mph is getting harder and harder with ever increasing traffic congestion. I've just come across an assessment of the Fabia 4 TSI saying that for drivers doing lots of short journeys and wanting an automatic gearchange the cars are not recommended. Ours is a manual version but journeys are nearly all very short in congested road conditions. I've tried to attach the body of the article and have given the link too, but I'm not great with posting stuff.. Hopefully, reputable sellers of the Fabi mk 4 will assess whether the Fabia 4 is a suitable purchase by asking the customer about their driving needs.. Skoda Fabia Mk4 1.docx
Have you got VCDS or similar?, if so, can you record readings like these: Battery charge status (85 %) Battery internal resistance (8.0 mOhm) Usable battery charge (31 Ah) Battery voltage at rest (12.6 V) Battery internal resistance (8.0 mOhm)
Skoda Rapid front left ABS sensor wiring replacement
Reckon best option as pete says is to join it. I did one a few years back. Soldered wires together then insulating tape on each joint and heat shrink each one plus another heatshrink over whole cable plus self amalgamating insulation tape on top. Lasted as long as the car did. Alasdair
Alasdair1 started following Skoda Rapid front left ABS sensor wiring replacement
The wires go direct to the ABS module connector, brown to pin 35, black to pin 36 of the 38-way connector.
MarcoMa joined the community
Incorrectly Identified NSL Speed Limits
ok thanks, I will post again if I get any results worthy of comment.
I noticed my car records the minimum cranking voltage drop in the gateway module. Most mornings it reads 7.90-8v. I have seen it drop to 7.5v. Not sure how accurate that is I left my car in for ceramic coating and when i picked it up the next morning it dropped to 6,6v and a **** load of low voltage codes.( i’m sure they were opening and closing doors while cleaning)The lowest i have seen on a battery tester cranking test was 7.9v.
Bridging it will be much easier than replacement.
