  2. Thank you DerekU I will check it out. I’ve never had this on a new car before.
  3. I buy oil and filters then take my car to a nearby garage (5 minute stroll) to simply change the oil and reset the service light. Brake fluid, pads and discs when the time comes. Changing air and pollen filters takes 5 minutes. And online filters cost peanuts compared with a dealer. All products are the Real Deal. Saves a fortune.
  4. I’ll check the manuals see if there’s a list Edit. No list in the manual. It does go through each individual bulb and how to change it but it lists bulb type as part of that rather than one master list.
  5. Hello. Same issue. Got it booked into Maidstone Skoda for 12 Nov. I just wanted to check that you have not had the error message again after the fix?
  6. 2016 Fabia with the dome lense over the dipped beam bulb
  7. Help needed The led DRL on my right drivers side head light failed as the headlight sprung a leak at the seam between lense and plastic case next to the wing Bought new skoda headlight from skoda dealer and fitted it but the dipped beam is just far to low Odd but the nylon adjuster looked as though some tool had already been on it so I was suspicious The main beam was ok with a tweak to its adjuster which was in perfect order I have rotated the dipped adjuster until i feel resistance. ( anti clockwise was lifting beam seemed odd direction as main was clockwise to lift ?) but it dipped beam still pointing down onto road and far lower than than it should be
  8. Hi I am about to do the same with my one as I have the very same code on my car now . Ordered the plug with wiring just in case my ones are broken to replace them as I am there and now looking for the valve itself. Can you still get them oem valves ? Really appreciate your time here sharing all the info you have and experience 😀 Thank you!
  9. Today
  10. This 1-year-old topic may be of interest https://www.briskoda.net/forums/topic/536354-wipers-very-noisy/#comment-5981475
  11. the first few posts on this thread lists nearly all of them
  12. Hello, I’d like to bring up an old thread of mine again. Does anyone have any ideas regarding my issue? It seems that the authorized service center doesn't even know what to do or suggest—according to them, everything is fine. The sound in the link occurs almost every morning, or during the day after the car has been sitting for a while. Lately, it has also been happening after long drives. The sound appears when the car is rolling in 'D' (Drive) gear, or when starting to move in 'D' without pressing the accelerator pedal. As soon as the car comes to a stop, the sound disappears. They replaced the belt tensioner this week, but it didn't help. Also, besides this sound, there is some jerking when accelerating. Thanks for your thoughts. https://youtube.com/shorts/4iBDhxFsDdc?feature=shared
  13. Crikey are the OE front wiper blades this noisy on all Fabia’s?
  14. Lee01 replied to Lee01's topic in Motoring News
    Skoda 3D printable accessories https://www.skoda-storyboard.com/en/skoda-world/printly-clever-custom-accessories-you-can-3d-print-yourselves/ 'The world beneath the upholstery' https://www.skoda-storyboard.com/en/skoda-world/the-world-beneath-the-upholstery/
  15. Should I perform an update for the software, or should I continue using it as is?
  16. Is there an explanatory video?
  17. Firmware 0480 Only Install when the unit is patched, you need modify Meta File and Audio Channel Change Side, After Update left is right
  18. There’s a full list of bulbs to be replaced to LED I started writing down each bulb and location - but was taking ages And wondered if there was a list or do I need to keep going 😂
  19. Is there any visible damage to the loom in the vicinity of the wiring core failure - or is it not accessible?
  20. I totally agree with you, but it was the only thing I could think of. I think this was the root cause to all the electrical gremlins I had before, So I probably unnecessarily changed the alternator as well. I´m just glas that it works now.
  21. mateiapostoiu joined the community
  22. Matus22 joined the community
  23. It could be that the brake pedal hasn't returned fully. Try and lift it with your toe. Also check reservoir isnt full to the brim. Only other thing I can think of is ABS unit. It may require vcds or similar to bleed if air got in while changing calipers. As its all four wheels I reckon its trapped hydraulic pressure somewhere between master and ABS. Alasdair
  24. Hi Only the boot (half) of my 2013 Superb opens.Is it possible to open the full hatch manually to examine the wiring in the hinged area. What does the Torx Bolt pictured do?
  25. jjtone started following Dual Tailgate
  26. I have just fitted new front dics calipers and pads to my 2015 skoda roomster 1.2 tsi with 35000 miles the items were replaced as brakes had seized on 1 wheel following a successful mot/nct test a d 1 front disc had been fried so to speak after fitting new brakes and bleeding system all 4 wheels are locked any ideas
  27. Yes Sir, Mr. Thread Revival.
  28. So when I collected my car Smelt of dog constantly Detailer says they have painted over the dog hair with black spray paint While he will do his best to get a lot of it off Is there part numbers for new side pieces, maybe bottom carpets and back of the seats? This is what I’m faced with So might just replace Part numbers and pieces be perfect for all rear pieces Estate
