Playback from SD Card - MP3's first track missing from album
Feels like some kind of bug around the naming convention or folder structure you're using? Have you checked the headunit is using the latest software version?
Amundsen MIB STD2 infotainment system with Android in Superb II
Maybe post an autoscan from VCDS? A 5L0035680E worked flawlessly in my old FL Octavia and I'm sure @pab567 has sold loads to various Octavia owners too.
Android 11 & Android Auto Wireless
Sorry, your headunit won't support wireless Android Auto, nor am I aware of a software update to add it. Only the very latest MIB3 units support it There are some adapters planned such as AAWireless that should work for you but I've not tried it https://www.indiegogo.com/projects/aawireless#/
Vertical Line through Infotainment screen
If you have any problems and assuming your build week is between CW 22/2017 to CW 48/2018, mention TPI 2051234/5 as that covers this issue
Navigation and reverse sensors intermittent failure
There is a newer version 0478. Amongst the claimed fixes are: You can either update it yourself if you ask @pab567 nicely for a link or try and get a dealer to perform the update (TPI 2049459/10).
Disabling Speed Warning (80 kmph and 120 kmph) on a 2020 Superb
Check in the instrument cluster adaption channels, my VC certainly has "Vehicle speed warning for India" which feels like it could be related
How spotify works on 2010 Octavia?
It'll depend on the car headunit, the bluetooth module, what phone you have and the Spotify app. I'd suggest you pair your phone via bluetooth and see if it works
Maxidot Digital MPH Reading?
Yup, probably possible by changing the cluster coding with VCDS or similar
- Steering wheel swap for a VW
Rollback
For the sake of £20-25, I'd be tempted to buy the file and ask your tuner to take a look to see if it's plausible... Assuming it is, a quick rolling road session should highlight any obvious issues.
Sd card HELP
Nope as the bolero isn't a sat nav 😉
Sd card HELP
As you have a Bolero, the only reason for using a SD card is to either put radio logos or music on. Any standard SD card will be fine, it doesn't need to be a Skoda branded one
Skoda bolero
Nope, a Bolero isn't a satnav unit so it can't do anything with maps I'm afraid :(
Rollback
Doesn't look like Skoda ever released a pre-fix update for your ECU given these are all 9970+: https://vag-flashinfo.de/index.php?partno=03L906018SE I think the unfixed version is probably 6356 based on this post: https://forums.ross-tech.com/index.php?threads/14155/ The most obvious options are to try and find an identical unfixed car as they might be able to copy the pre-fix software off or try and buy an unfixed ECU :/
distronic conection
You can access the wiring diagrams directly from Skoda for a small fee: https://erwin.skoda-auto.cz/erwin/showHome.do I assume that's a front radar unit for either front assist or ACC (adaptive cruise control). Have you tried the CAN-bus wires both ways round? Is their power on the black/green and black/white wires? Are the brown wires grounded? This might help:
What Amundsen unit do I have??
I had a quick google, I can't see any South American maps for the RNS-310. However, for the RNS-315 it looks like there are a few versions: - V3 3AA-051-866-E - V4 3AA-051-866-K - V6 3AA-919-866-AD - V7 3AA-051-866-AK The latest looks to be 2016/17. As always, please check the part number yourself before buying...
Amundsen MIB1 Map Update 2020-2021
@Frdy85 - this thread is about an MIB1 Amundsen. From your post here, this is not what you have so the maps above will not work! You need to figure out if you have an RNS-310 or RNS-315 style Amundsen. - For the RNS-310, I can't see any South American maps - For the RNS-315, there appear to be V7 maps from 2016/2017, I can't see anything newer
Cruise control swap
You'll probably need to move resistors around on the PCB's and possibly even bridge/cut some tracks
- Too many volts?
Lying repair garage and insurer
I doubt an insurance company will take any notice of what we have to say. I'd be tempted to go to Skoda and get a full PR list for your vehicle, then use that to confirm if you have the right PR codes for the storage draw. If you're lucky, @James@RRG_Skoda_Rochdale might be able to help
Cruise control swap
Not on the set the OP posted, that looks like standard CC based on the functions (speed not distance etc). It's probably possible but unlikely to be a straight swap. You'll need to figure out what each function does to the wires as they tend to use a few resistor ladders normally. You can then modify the new stalks to match at which point, hopefully they'll work It's worth checking they use the same carrier to attach the stalks to the steering column too as there are a few styles. If not, that might need messing with too.
Mirror folding and window opening problems
As far as I know all PQ35 based cars (Yeti and MK2 Octavia/Superb etc) can't do this :( You'll need a newer MQB based car (MK3 Octavia/Superb etc).
- MQB instrument cluster odometer/mileage increase service
Octavia mk4 Engine and Car Repair manuals?
I'd suggest buying an hour or two and downloading everything you can find for future use. It's the only official source I'm aware of and given how new the MK4 is, I doubt many unofficial sources exist yet.
I recently retrofitted a virtual cockpit but as it was faulty, I ended up switching instrument clusters a few times which ultimately meant the odometer was incorrect. Rather than use one of the few services to increase the mileage, I purchased the required tool to correct the odometer myself. Given it worked perfectly on both my original and replacement cluster, I'm now offering a mileage increase service for MQB based Audi, Seat, Skoda and Volkswagen (VW) instrument clusters aka virtual cluster, virtual cockpit, VC, active info display, AiD, etc. To my knowledge, most MQB clusters cannot have their mileage adjusted via the EEPROM. To get around this, the tool simulates a moving vehicle which means I can add up to ~4000 miles per 24 hours on the odometer. While I appreciate this is probably quite a niche market, I'm offering my services as this can be a sticking point when purchasing used clusters. The way this will work is: - You send your instrument cluster to me - I'll increase the odometer to the requested amount - If you'd like, I can send a daily picture to show progress - Once complete, it'll be returned in your packaging I'm not sure how to price this so for now I'll say £50 will cover: - insured return postage (UK mainland only) - up to 20000 miles adding (5 days) FAQ: - This tool CANNOT be used to decrease the odometer, please don't contact me regarding this - If you need more than 20000 miles adding, please contact me to discuss pricing - I do not offer component protection or immobiliser services, these require ODIS with an online connection which I don't have - Some clusters may increase at a lower rate, if this is the case I'll contact you with a revised completion time - If for any reason I cannot increase the mileage, I'll return the cluster and give a refund minus the postage cost Regarding the last point, if I come across a cluster I cannot increase the mileage on, I'll add it's part number below and no longer accept requests for that cluster.
