Sacked by my dealer...for complaining about poor service!
That sounds as if they cannot now be trusted - unacceptable that they 'missed' the control unit fault report when they were diagnosing other issues.
Long motorway journey - losing coolant, no cabin heat, rad fans on, temp guage low!?
Rather surprised that a probably overheating engine was indicating low coolant temperature - suggests that temp sensors may not be located in ideal position.
Steering wheel radio control
To avoid any misinterpretation, don't use graphite powder near anything electrical! - it's electrically conductive. Great in locks, but for switches, use a dedicated switch contact cleaner or isopropanol only.
During this long motorway run, what was the oil temperature showing while the coolant gauge was displaying low? Was the coolant level correct before starting the trip?
Power steering fluid location
Pretty sure the Mk3 Fabia power steering is electrically assisted only - no hydraulic operation. To confirm, Google the specifications for your vehicle.
Replacing the alternator (Generator?) in a Fabia
The slipring you say was darker than the other possibly indicates that the associated brush was not making proper contact - there does look to be a considerable amount of wear on both sliprings too. I'd suggest that the old carbon brushes are unserviceable.
Main screen doesn't work
Hello, welcome to the forum. I'm pretty sure these infotainment systems are coded to the vehicle - assuming the replacement unit is functional, I believe that at the very least you will need to get this done.
Topped up with wrong coolant
Assumption is for full synthetic oil - American sites are saying ideal oil temperature for TSI's is in the range 110 to 127 C. Over 102 C is great for eliminating any combustion waste products from the oil. I haven't done the conversion from F - but references suggest fully synth oil doesn't start to break-down until well north of 250 F
Hello
Hello Tony, welcome to the forum. Sorry to hear about your wife. Did you have to sign a non-disclosure agreement with The Company? 😇
Approved used 2015 VRS, can anyone give me some advice please?
DSG problems can be an issue, particularly in regards to correct servicing, depending on type fitted.
Octavia iV High Speed Handling
Suggest looking at condition of RH strut damper first. To your knowledge, is this vehicle still at stock ride height? Bump-steer is a normally unavoidable consequence of changes in steering geometry during suspension travel and is not always an undesirable factor - provided it is uniform and predictable.
Although the current tyres fitted may not be ideal, it is highly improbable that matching tyres, whatever the make, will cause the OP's issue with bump-steer in one direction only.
You're ok - G11 is compatible with G13 and G12++. Get engine refilled with G13 or G12++ / G12evo once the leak is fixed. Be aware that the system should really be vacuum-filled with the new coolant to avoid issues with airlocks.
Hi, I think you will be ok with what you've used so far. Wait one and I'll check compatibility and come back.
One problem with that without access to a test track, will be willingness to take it to speeds where this becomes an issue.
One thing to check - is it possible that the LH transit block is still in place? Bump-steer in RH direction only could suggest more suspension movement on the affected side.
Does this 'diving to right' behaviour while travelling at speed present itself all the time - or in curves only? if only in curves, is it only in right curves, I.e. bump oversteer?
COOLANT CHANGE
Ditch the bag - or replace the expansion vessel for one without it if your present unit has one. There apparently are some later expansion vessels containing a more robust (plastic, tubular) silicate dispenser, but I'd suggest going without the 'teabag' type.
COOLANT CHANGE
The coolant service life is reported to be shorter without the silicate dispenser, I have just had the coolant changed in the Octavia, after replacing the 'Mit Silicat' expansion tank for one without it 4 years ago.
COOLANT CHANGE
Hello, welcome to the forum. I would recommend getting it done by an independent garage who have the correct equipment. You might be lucky and not have too many issues with airlocks by doing it yourself - but there is some risk that you will. Are you changing the coolant because you have removed the silicate bag from the expansion tank?
Hello!
How big a mortgage do you have to take for a bottle of Scotch nowadays? I can still remember some of your Countrymen visiting Moscow just for the Vodka when I was on a trip there in the 80's
Battery Charging, How to Check?
One thing that might be getting overlooked with predominantly low mileage running is the likelihood of plate hard sulphation as a result of persistently lower charge state (<75% SOC) In this instance, a good case for the occasional maintenance charge to 100% with a suitable charger.
Hello!
Good morning Jatra, welcome to the forum. From your comment about converting to multifuel, I'm guessing petrol is horribly expensive there?
- Errors after changing battery
Karoq 2021
Have you tried a search on the forum? I'd guess that all models use a similar alarm unit - from what I've read, the unit is sealed and the self-contained battery is soldered onto the PCB. It appears that the alarm unit is not intended to be a serviceable item. Replacing the battery appears to require cutting open the unit, and de-soldering the old battery - but there is a possibility that the PCB suffers damage if the battery electrolyte leaks.
