Modifying Your Fabia MK III
11 hours ago, Fab1493 said:
Awesome! Yeah let us know please, Im only in Doncaster area
ahh im around Doncaster a lot (Bentely) youve probably seen me from time to time kinda distinctive
  • Replies 1.1k
  • Views 285.6k
  • matt_black_90
    matt_black_90
    New emblems from Superskoda
  • matt_black_90
    matt_black_90
    I've built a small 8" subwoofer for my Fabia It's designed to fit snugly in the "basket" in the trunk and have a quick connection so it's easy to remove if needed.  If someone wants to see
  • Just bought my monte carlo a few weeks ago.    Only done a few mods to it so far.   I've lowered it on eibach springs (30/45mm) and sprayed the badges black.    Also clay
17 minutes ago, Fab1493 said:
Question for the group - is everyone here with a MK3 TSI running standard accelerator pedal?
The delay is really getting on my nerves and apart from "Audi mod" (which I cant even get the code for on my OBD) is there anything else I can do?
I remember driving a 1.2 TSI Leon in Sport & that felt so much sharper!
no delay on mine with bluespark just put foot down n it goes
A map cures the dead pedal. I’m on 145 stage 1 1.0 tsi
Never ever have I seen you! Would like to though cause it looks brilliant & going forward if I do see you I'll know its you
Mine has a stage 1 too to around 130 & the pedal lag is still there & its so obvious its annoying. I even did the test on an empty straight in 3rd gear on boost and it is very obvious the delay between the pedal being all the way down and the car actually reacting. Clearly just me with this issue though, perhaps itll be cured when I get a custom map
Sounds to my like the person mapping may not have adjusted the pedal lag who mapped it?
Probably not, it was a local garage who are a dealer for off the shelf maps (Quantum Tuning) - good bunch of guys though!
Wich standard engine did you map? The 95 or the 110hp engine?
It's a 1.2 90 standard
I vaguely remember seeing something on Carista OBD about accelerator pedal threshold settings but can’t remember what the two options were...
I’ll look later when home from work.
Controlled by time and controlled by threshold (position).
the latter gives a more direct feel.
These are the options with OBD but an access code is needed which I dont have.
Just spoke to Awesome GTI regarding stage 2 & they said not to even put a downpipe on these because the turbo will break & if you put a new turbo then the engine will go. Anyone got anything to say regarding this?
Decat'ing runs the risk of potentially nuking the turbo unless it is properly custom mapped in.
See I was thinking going down the route of getting a sports cat... in fact I was literally in the process of trying to arrange a date that suits both me & the guys who are doing it...
I didn't need an access code with Carista Beta for this. Tell them you want to try out the beta for throttle position and they'll help.
Remap from who if you don't mind me asking?
The Estate looks great, by the way. Really smart.
Hey guys!
So for suspension, I've decided to order myself a pair of Bilstein B8's + Eibachs since that's within my budget.
However, as I'm seeking to run a flush setup on my Fabia, what rim specifications would yall recommend?
  • Flush Setup - When the wheels match the car fender line just perfect, with maybe a bit of tyre poke.
  • Stock is 17 x 7j, offset +46 (ET46) ... However, the wheels seem too... "inside the fender-line" that it looks bad.
  • If the cars gonna be lowered, might as well try and make it look good lowered too right? ;)
I've seen some people say an offset of +38 (ET38) is good too, but what's the general recommendation? :)
4 hours ago, xCelcia said:
Hey guys!
Agree! The wheels are too far in - I'm running ET38 but the rears could do with coming out a bit more.
Mine are stock width tyre 18x8j ET42. This is as far in as you can possibly get with an 8j wheel so works out almost flush.
34 minutes ago, Dannyboy85 said:
How much is it lowered by? I'm thinking of getting some 18s ET35 but just worried about it catching the arches. I can't raise it if it does either as I'm on the Eibach springs.
Et35 is going to poke a lot even on stock tyres your going to struggle as the actual tire will be out of the well. Mine is lowered by about 55mm but the tyre is fully in the well wheel in line with the body.
It would be another 7mm on your ET42 but mine would be slightly higher. 🤔
What size wheels do you have and is it lowered?
Im running 17" x 7j - yes it is lowered on Eibach springs
@R44YVY how are you finding the 155bhp Fabia? 😀
