Android 10 Stereo £162 AliExpress gamble! Results:
6 hours ago, nickytheshaft said:
I am not on my car so I can't check. Mine is LHD so I guess it is standard.
If you can extract the dab APK it would be cool
ok i have uploaded the DAB app to my OneDrive, let me know if it works.
https://1drv.ms/u/s!ApKAZf4actzCqHemcBH3d8srXtz0?e=ztQG8B
Still couldn't find the option to switch to RHD though.
  • Replies 778
  • Views 105.2k
  • The job is never finished until you leave DNA behind!
  • Small update as have now gone back in and put a generic external microphone in place. I opted not to put it behind the trim where factory one is as it's blanked off on driver side and didn't think it
  • That screen to map out the steering controls is identical to that on mine.   If you did want to add DAB to it by the way then I can highly recommend the rear amplifier and splitter option.
Thanks, I was out tonight and looked around the different settings but could not find anything to change the doors... Sorry.
Sorted this afternoon. I knew I had done it before but in a different menu then I tried a different password to get into the factory settings which I have have normally been using 123456 but tried 8888 this time and it opens up a slightly different menu and one of the options is the doors.
Wow 2 passwords for a same menu....
I noticed something today, I had FM issues, so I decided to look around my connections. My dab dongle was hooked to the single usb cable..when I was mooving it around, the reception was getting better. I unplugged it and got perfect reception.
I then hooked the dongle to the working plug of the double cable and again, perfect reception.
I don't know why but it worked.
How did you extract the dab+ APK? A friend of mine has a' android 11 unit and his fm app is so much better than ours, I would like to extract it.
Also, I was thinking, the usb cable only giving power could be used to plug a tpms sensor module.
Edited by nickytheshaft
When you go into the factory settings there is an option to backup APK, just run it and then go into file manager and look for an APK folder and they should all be in there,  just copy to a USB drive.
Perfect, if it works on our unit I will share it.
Too bad, I couldn't find the APK. It seems to be part of the rom.
I also tried with file manager
Merry x-mass every one. Enjoy
Did anyone finde a way to add text to speech?
When I install the Google engine, it crashes when I go in the setup.
At time I ordered mine, the listing had it as an option that you had to pay more for. Said email them for it, so I did and then they asked for payment, so I declined. It would have been delivered via email, so some random China hacked APK must be about somewhere for it.
Just catching up here.
Merry Christmas Nicky & all the android gang, I hope Santa was kind.
 Merry Christmas GIF by filmeditor
Yes very kind 😁😁 just recovering from xmas eve and Xmas Day...
This is a bummer and Google speech service doesn't work, it keeps crashing.
I wonder if alternative tts engines will work. I am looking around for hacked ones to try.
I got a Samsung engine from sammobile but doubt it will run...
Ok solved TTS issue.
Install vocalizer
Go to languages settings of the unit and select vocalizer as preferred engine (it seems to fix the issue)
Install speech services by Google
Return to TTS settings
Select Google as preferred engine and Voila, TTS is working
tried it in Sygic and had TTS Voices, I will navigate this afternoon and confirm this.
Install vocalizer
Ok confirmed, with this method TTS is working in Sygic.
Now I am quite happy, the Unit crashes from time to time but it boots quickly and FM reception is really ****ty. I have to sort this out. Maybe unplug the antenna booster. I Also ordered a double fakra for the antenna
My TTS works fine in Google maps but doesn't work in Waze.
In Waze the music volume goes lower when Waze is trying to announce something but get no voice  but in Google Maps the music volume stays the same and no matter what settings I choose it makes no difference.
My FM reception is not that great either but as I use DAB or online radio it is not too much of an issue but I have already ordered a double Fakra for the antenna and it should be here in the next few days so will be interesting to see if it makes any difference.
Not had any problems with crashes yet so that is a good thing.
In the audio settings of dab z, you can set the app to reduce the volume when an alert comes up. The Google notification should be considered an alert.
Try it, it may work. It is what I did with Sygic. The music doesn't completely cut of but the instructions are very audible
(Sorry screenshot in French, I didn't think of changing the language but you will understand it)
41 minutes ago, nickytheshaft said:
Here, you reduce the radio volume and increase the systeme volume (Audio et video in my case)
the systeme volume is what is used for the different apps.
Lowering the radio volume gives you a more precise settings, low is low and you can crank up the radio volume more precisely.
Leaving the systeme volume higher means that navigation instructions will be louder than the radio.
Then go to dab z audio settings and play around with the 2 volume settings, that will fortunately resolve your maps issue.
Then go to dab a audio settings and play around with the 2 volume settings, that will fortunately resolve your maps issue.
I have no issues with Waze.
On my s21 I have no TTS with Waze, I guess it is a picky application
I will have a play around tomorrow and see what I can get working.
I don't have any problem with Waze on my phone either.
Good luck, tell us if you find a good setting.
I also noticed that setting the DSP to POP gives the best sound
These more recent ones all have a vastly different much more modern looking ROM than mine lol
Have you updated your rom?
You started your post in march, the unit I received had a rom of November then I updated to a version from December.
I rewatched your first video and your rom looks better than mine.
My car settings are all small lines, no + / - I have to slide.
Also can you check if you can extract your FM tuner app?
thanks
