  2. Vcp is vag can pro. Pretty sure it uses its own dongle and pc software. Like £300+. If you want to do it you’re better off finding someone with the tool and paying for it to be done.
  3. We have had to defer a long trip with the new car, planned for the coming week, due to violent storms cutting electricity to the area we were to visit. So, I'll wait until we have actually covered some distance before offering any opinions, other than so far we like it. Sounds dumb (probably is) but I have had to do some online research to find out some of the technical details of what we have bought. A lot of it is quite a new experience for me. The 1.4tsi in our 2014 Octavia was a relatively simple 4 cylinder turbo, but gave excellent fuel economy, and/or performance and yet was smoother than most other engines I have driven. I still love it. The 1.5tsi in the Kodiak builds on that and adds Active Cylinder Deactivation (yes, I know some applications of the 1.4tsi had ACT too), the 'remaining active cylinders' can oscillate between Miller and Otto cycles as befits power/economy demands, and a variable blade geometry turbo is fitted. Numerous other changes but I hope they have also upgraded the plastic water pumps that are prone to failure in the earlier models. From what I read in this forum, something that seems important to owning an 'electric' car is the Skoda Connect App. Unfortunately, this is not available in Australia and in fact the equivalent is not on any VAG group car here either. I have just read that Audi are soon to release their version here so hope that the lessons from that are passed onto other members of the group so we can eventually get Skoda Connect 🤞. Remarkably, the Kodiaq iV has a better drag coefficient (0.29) than my 'sleek' mk3 Octavia wagon/estate/combi (0.31) although the frontal area is much larger on the Kodiaq so the total drag will be higher, but still it surprised me. The big difference between the mk3 Octavia and the Kodiaq is the 400kg or so extra bulk of the Kodiaq and that is going to have an effect on handling and economy. More revelations of my ignorance of the technology and my insights into the Australian electrical infrastructure and recharging facilities and costs to come.
  4. Also Does the vcp comes with the own app or I can use car scanner pro app ( paid full version) ? Thank you
  5. There’s only 1 wire from the alternator connector - blue one. Goes to green/yellow from the engine block plug
  6. Will look shortly, but that may be the LIN control wire rather than the exciter.
  7. It is scary how quickly time goes... I met my wife when I was 21 and my eldest is now 22. The intervening years have shot past.
  8. Today
  9. Regarding warning lights - non today!?! Previously though front assist, rear parking, tpm, other tyre/wheel associated ones and occasionally stop/start. I’m guessing wheel sensor with these, but the battery light is confusing thinking. Could be 2 (or more!) different problems I guess. Random lights have been in the last 2 or 3 weeks but the battery light may not have been lighting for longer.
  10. Going through the obd11 data it claims the battery has a total energy throughput of 14,500ah. VW claim when it reaches 16,800ah( for a 70ah efb battery) the battery is coming to it’s end of life. You multiply 70ah x 240 for EFB’s. For Agm’s you multiply the 70ah x 360.
  11. I tracked it to the battery module and checked continuity and its good. I guess from there it goes to the ecu?
  12. We have passed through your phase of life and are entering a new one where we needed a bigger, newer and safer car (Kodiaq Phev) to cater for a pending exponential increase in additional grandkids. A combination of three child/baby seats across the back will probably do for now. I must admit I did not think that retirement would be this busy, or this much fun.
  13. From what I've seen in other posts, most likely to be the ABS wheel sensor - I'd suggest having the OBD checked for any logged DTCs and get the NSR sensor replaced if that shows up. Is there any significant difference in wear between rear tyres?
  14. I saw this too late, yes it is removable i have posted photos from the tip of this cable, it's square shape and i have lubricate it (plus the whole wire) before install it back.
  15. In the last month I have had 6 Tyre Pressure Faults arise (5 of which have been for the same tyre, Rear N/S). However every single one has been false as when I check the pressure it is fine and matches the opposite side tyre. I was leaning towards a faulty ABS sensor but my assumption is that I should also be seeing ABS/ESC faults also as it's my understanding the sensor controls this elements also. Octavia III Estate L&K 2015 Anybody have any ideas or guidance?
  16. Sadly changing the Gateway is no trivial matter - sorry. It's at the centre of everything. Everything talks to it. I personally wouldn't change it just to get the DCC Mod.
  17. I visited the Škoda dealership. The fuel vapour solenoid valve was faulty and was replaced under warranty.
  18. Dang! I hadn't noticed that additional downgrade from the previous models' spec. I had the automatic headlamp wash on my Mk3 SE L model, so not having it on a new L&K is indeed astonishing. 😠 I always carry bottles of Autoglym Active Insect Remover (for the midgies) and Fast Glass spray in the car. I find them essential on longer trips in case the windscreen needs a quick clean-up beyond what the screen wash can handle. So now the glass cleaner will need to be pressed into additional duty during the winter. Sigh.
  19. Annoys me that sales of cars in Europe you can opt for All Season of Winter tyres to be fitted, extra 200 Euros or so, rather than only coming with Summer tyres which are compromised below 7c ! Please give the UK choice too.
  20. Hello folks A kind soul stoved in my NSF wing whilst my car was parked in a side road 🤬 Anyway, I'm looking for a wing panel in good condition, ideally already painted Diamond Silver Metallic (9102), the OEM part number is 1U0821105B Anybody breaking a late Octavia? Mine's one of the last Mk 1s and has the facelift square-ish repeater hole. If not, any suggestions about where to get one would be appreciated (in case somebody knows a source not on-line etc.). TIA.
  21. I'll look up later where the exciter wire originates. BCM I expect.
  22. @Tqm What are the other warning indicator lights that are lighting up? What are the actual voltage readings you are seeing?
  23. I can definitely confirm that a MY18 Mk3 Fabia does. I cannot recall any ICE vehicle that hasn't had a 'battery indicator' illuminate when the ignition was switched on if the charging system was functional.
  24. Hi Everyone, Owning my RS220 for more than 5 years now and I'm loving it. Had some maintenances work to do already to keep him running but the support of the community and a good workshop is always great. Now I'm trying to fix some sw related issues that's why I ractivated my account here ;) BR, Lord_Diablo
  25. Hi Everyone, I am currently on MSTD_EU_SK_P3163 and kindly ask for a DL Link for MSTD_EU_SK_P6230. Thanks in advance!
  26. StairBundy joined the community
  27. 'Limp Mode' began to be introduced on cars in the 1990s, so it would necessary to go a long way back to find a vehicle without it. Besides my 2023-built Skoda Fabia that has automatic transmission and a turbocharged motor, I own a 2009 Skoda Roomster with manual transmission and a normally-aspirated motor. The standard specification of the Fabia includes a lot more 'kit' than the Roomster's, so, logically, the Fabia has a lot more to go wrong. My Fabia has a 'limp mode' feature, but so does the Roomster (as mentioned in this 2017 forum topic) https://www.briskoda.net/forums/topic/441876-limp-mode-on-roomster3/ The Honda Jazz has an enviable reputation for reliability, but that doesn't mean earlier versions are 'simple' or that problems with them are easily/cheaply diagnosed and cured, as this 2022 clubjazz.org forum topic proves. https://clubjazz.org/forum/index.php?topic=14521.0 Any doctor will tell you that obtaining from a patient sufficient background information to allow a reliable diagnosis to be achieved can be extremely difficult. In bazz2004's Fabia's case, the car was producing DTCs (Diagnostic Trouble Codes) and these needed to be cleared to allow the car to run properly. But, in Slinda's Fabia's case, the car has just suddenly lost power (Did any dashboard lights illuminate when that happened?) and, after the car was restarted, it recovered and no DTCs were subsequently found. In the 1980s one of my VW Golf GTi cars developed a starting problem in very cold weather. The vehicle was within its 1-year warranty period, so the VW dealership had it for a week, I was given a courtesy car, and parts were replaced. When I collected it, the workshop-manager said "It's still doing it, you know it's not right, I know it's not right and VW know it's not right, but it always starts within 30 seconds and VW says that's 'acceptable'" I didn't like it, but they had done their best. It seems to me that slinda's dealership is doing its best to help, but, as there are no symptoms to explain why the car had lost power and then self-corrected, it's not easy to see what more they will be able to do unless the fault worsens.
  28. .....although I have, during this freezing weather where salt is being kicked up, discovered that there are no headlamp washer units on our car 🤔. A bit retro, and maybe a bit penny pinching? I'm back to 1990 and a small plastic bottle of diluted washer fluid in the boot, plus a microfibre. At least LEDs don't run hot. TBH, somewhat surprising and not something I thought necessary to check. The body of the front bumper looks too narrow for pop-up washers. Hardly uppermost in the list of life's issues but an odd omission. But in the interests of fairness, I think you would get this on an E-Class 😅. Have a nice day!
