2015 VRS TDI - Coolant loss from expansion tank
Turns out I have an aftermarket rocker cover on my car so I will end up replacing the whole cover to see if that helps. The PCV I took out was different to the OEM one and the rubber didnt feel great, it was quite stiff but was intact to hard to say if that is part of the issue or not.
EPC light caused by actuator arm stuck/seized - DIY fix
@Toothache it's still working fine 🤞🏻 probably done 6k miles on it, varied mileage, as far as calibration, I just cleared the faults with OBD11. It's since been serviced/MOT'd at my trusted garage - no issues. The hardest part is access especially if you have fists of ham and thumbs of butter like me.
Update my car from 0156 to 0306
Can I ask - I'm on 0276 and I have the daily "update" message that apparently needs a FW update to be carried out. Reading this thread, it seems that if I update it manually, some other things will break and I can't fix them? Is that correct, or is there a full fix now? Thanks.
petertr started following Update my car from 0156 to 0306
2021 Android Auto - Issue when leaving the car
Long Story short, it was just the app N7 Player.
- Activating SmartLink on Swing 3
Upgrade oil cooler
It wasn't before I uprated it. Back to the drawing board, as I still feel something isn't working correctly
Can’t select drive. Only M
The box has never been serviced. I don’t think I’ve ever been asked. I refused the brake fluid and aircon clean this time. I’m really puzzled. I’d like to find out what the problem is before I send it to the dealer.
Suitable glow plugs
The recommended plugs are Champion CH700 but are there other preferences used by owners please?
FlyByMe started following Suitable glow plugs
SOS error call workshop
Funny enough, ours has been behaving itself for the last year or so, but it's just started playing up again this last week!
Felicia's have blower motor relays?
It's 1.9D, right? Those use different heating from Favorit, so I'm not familiar with it. But you should be able to locate the resistor pack in the engine bay, following wires from the motor. There are two bimetal contacts that appear to short the resistors if they overheat. It's possible that the one for 1st speed got stuck.
Digital cockpit.
Hi lee, no maps on screen, mph as numbers and a rev counter plus additional vehicle information you can select.
Digital cockpit.
Hi Derek. Thanks for the videos and information really helpful. I test drove the car yesterday it has the Digital cockpit which displays speed as number's and a rev counter above in a line or circular around mph number which works well, i pick the car up monday. Regards robsie
Digital cockpit.
This 2022 Fabia-related video may also be of interest as it shows a variety of different Virtual Cockpit displays.
Amundsen MIB2 Firmware Update
OK, no worries. Thanks for responding 👍
Unfortunately I don't have it, 0359 is the most current firmware I have
It’s better but still not great, changing the PCV today to see if that helps.
Hi Pab567, Google has brought me here to you. Are you able to help me getting the software upgrade MST2_EU_SK_PQ_P0369T for my 2017 Yeti radio please?
Yeti_Kev started following Amundsen MIB2 Firmware Update
Any update on the oil consumption Sharpy?
- Constant creaking / rattling from the doors of my Kodiaq Mk2
1.6 TDi Greenline glow plug replacement
A perfect outcome. Well done. Well worth the prep and planning involved.
I took advantage of the very pleasant sunny weather we've had this week and got the torque wrench onto the glow plug as soon as I got home from a drive. With an initial setting of 20 NM the glow plug started turning before I hit the torque setting. The plug that came out was a Bosch. I don't know if it was the original one or not? The new one went in easy peasy. Fault codes cleared with my Launch diagnostics tablet. And the warning light on the dashboard has stayed off since. The actual replacement work took less than 30 minutes. It's only a matter of time before another glow plug goes. I'll cross that bridge when I come to it. I paid £14 for the Bosch glow plug, from a local GSF that had it in stock.
Fabia VRS LE Register Part Trois
Anyone selling fabia 1 1.9 tdi VRS
- Yesterday
Desperate for a brake servo!
As title. My existing brake servo on my 05VRS is As title. My existing brake servo on my 05 vRS is playing up and I desperately need a replacement. New aren’t available, pattern parts seem to be extremely thin on the ground if at all and the secondhand ones on eBay look terrible when they come up. If anyone has something that would suit, I’ll be grateful if you could contact me. Thank you.
Ghost speed limits
The speed limit on most of the minor c roads around north northumberland register 20mph despite speed limit of 60 is very annoying and obviously a mapping error
