  2. I ended up getting my local shop to do it for mex 1 hr labour so couldn't have been that hard haha My guess is pop rear bumper off and unplug / plug in
  3. Thanks all for your replies. I have changed my mind and I'm buying a less than one year old Scala and am now trying to get more than 6000 for my Octavia combi with 51k on the clock and full service history.
  4. Thanks, I thought I had subsequently posted the correct part numbers, but clearly not! Anyway, these two UK adverts shown below show the relevant part numbers for Fabia Mk4 cars and (as you said above) they are 6VA601011F for the spare-wheel and 6VA093860A for the tool-set. Wings SKODASKODA Spare wheel FABIA IV15“ Spare wheelWhen choosing a spare wheel from the ŠKODA Genuine Accessories range, please refer to the information in the registration document to check that the dimensions of the spare wheel corresWings SKODASKODA Toolkit for Spare wheel FABIA IVThe Spare wheel set is designed for drivers who prefer to use the spare wheel instead of the puncture set in the event of a puncture. Spare wheel set - includes all the necessary tools for changing a(I THINK the spare-wheel for a Mk3 should be OK for a Mk4, but a Mk3 tool-set would definitely be unsuitable as the Mk4 requires a different design of jack.)
  5. I have a 67 plate citigo and noticed this issue at the weekend, rang a local dealer first with a promise of a call back, guess what it never happened, so I rang another dealer who I have had better experiences with and they will not look at it, as the last service record shows at 2018 even though it was purchased from a Skoda dealer in 2020 with an alleged multipoint check. Has anyone had a recent positive outcome to a claim without a Skoda service record?
  6. Unfortunately not. It was doing the same, regenerating all the time, when i first bought it. Had the DPF cleaned, along with a new differential pressure sensor (left hand). Which did make it better. But now its regenerating all the time again, tried another new differential sensor (right hand), so theyre both new but no joy. Did 200 mile round trip over the weekend, and it regenerated all the way. DPF light came on around 70 miles in, both ways. But then went off when I let it sit to finish its regen. Im worried its going to damage the turbo and/or melt the 2 differential pressure sensors. Do I spend aload of money getting a Dpf delete, and taking a gamble with the better quality oils. Or just wash my hands of it and get rid.
  7. Hi, bro. I think your rings get some issue. Maybe you can use some 45%PEA to try to reduce carbon on the rings, though it's hard to solve this problem. The worst situation is replacing rings.
  8. Personally i would not risk it for a biscuit no matter how little petrol is in the diesel from your misfuel.
  9. It is highly probable that high oil consumption is contributing to your DPF issues.
  10. It sounds like we're having the exact same issue. Burning 1l per ~650 miles and constant DPF regens - have you managed to sort it?
  11. The advice your garage is giving you about checking for piston ring issues is complete nonsense! a simple compression test is all that is required - rectifying any issues revealed by the test is another matter.
  12. Looks like no solution to my issue, except engine rebuild, which is much too expensive. Went to all options of high oil consumption and no difference it made. It was always serviced regularly so I'm told rings are an issue in 2.0L skoda octavia models mark 3. I'm topping up for now when needed. Skoda should have taken responsibility for those inferior engines on mark 3 models
  13. I spent about 100 bucks buying a carplay module, and put it into the RCD510. So the RCD510 is the screen used to display while the carplay module working inside. There's a button to switch model between original display and carplay display, which means the car has two central controls. The hardest part is finding the space to hide the carplay module and the harness LOL.
  14. @ashefield did you get to the bottom of the issue? I'm having the same problem and the garage has been useless in diagnosing it!
  15. Today
  16. The garage had it for 2x days and found no issue :D It's using 1l of oil for every 600-700 miles and constantly performing a regen but no issue found. They checked the turbo for leaks, etc and stated that regens were completing successfully. The fact that it regens every time the engine is running indicates there's an issue, surely? I mentioned it's likely a piston ring issue but they stated it was too big of a job to check. Not really surely what to do now...
  17. wye joined the community
  18. Hi there. I'm facing this issue and need to replace one of my rear sensors. Did you ever manage to get info on how to actually get to it to swap it out? Cheers!
  19. Did you Buy an Octavia in the end? Or lose interest in your thread?
  20. The OP has a Fabia MK4, not a Fabia MK3. 6V0093860B and 6V0601011M are both Fabia MK3 part numbers.
  21. 311.6 KB file on MEGA No warrenty your own risk To do Like Firmware Update
  22. MichaelMuntus joined the community
  23. I have an almost all diesel mixture from my petrol Fabia and was thinking of adding it gradually to my 2014 Diesel Honda CRV 1 gal to 1 tank. Will it be detrimental to the DPF or anything else?
  24. My Sportline say's it has one but previous owner had detachable towbar fitted which means there's a cut out under bumper, I waved my foot about under it and nothing so presumed it was diconnected or something to allow for towbar. I was trying to pull the swinging electic socket down one day to plug trailer into and boot opened so must be still there, can't seem to get it to work with my foot but reading comments I have got to get the knack !
  25. Hi pab567, Could you please provide me with the latest available firmware update for my MIB1 unit? Here are my current system details: Device part number: 5E0035020C Hardware: H43 Software version: 0360 Thank you very much for your time and help!
  26. SkiPPy73 started following pab567
  27. Yes i dont want too stiff suspension because i drive this car daily, just looking to replace the tired original suspension with new parts or with upgraded new parts if it really makes a difference. Arent the eibach pro springs progressive springs? Would they still be too firm in a daily?
  28. SkiPPy73 joined the community
  29. I managed to update my unit to 0253 using an SD card. What do I need to do in order to activate Smartlink? Many thanks for your help!
