Legend88 started following Jack Point
Skoda enyaq 2022 full electric won’t start after crash
@Jay787763 Has your issue been solved yet?
Kodiaq steering wheel vibration
Ive found on some polish forum that its possible that those OEM silentbock are to "soft". Some users replacw them Audi S3 silent block,
All In - anyone cancelled shortly after having a service, did you have to pay extra?
Found a post on one of the Tiguan forums where a poster was doing a lot of miles and needed two services per year. He bought All In at £29/mth during a discount period, had two services, then cancelled it after a year - had to pay a £39.32 settlement fee. So he got a minor and major service and MOT for just under £400 - way cheaper than it would have been paying normal dealer retail prices. I'm pretty miffed with our dealer - they were absolutely adamant that All In couldn't be taken out and used to pay for the service and MOT just before the car turns 3, yet Tiguan owners are reported their dealers could do it by setting up All In on the day the car was serviced.
Dont think that Its halfshaft, i didnt have vibrations after some changes, but now i got some small, halfshaft will vibrate on acceleration. Steering rack has some difficulties and I hear some strange noises even when both shock absorbers are charged
What you think about halfshaft or CV joints? In my opiniom resonance come from floor on passenger site also. They said that resonance on steering wheel could by coused by many electric engines of assistant system. Those systems are directly connect with steering rack.
I changed on warranty right ball joint and left bearing, they also changed both back silentblock of front arms and I have small vibration back again. In my opinion, this is resonance of system from the road or its steering rack
Kodiaq 2017 - Strange 9 errors from nowhere
As I posted earlier, my car gave the same multiple errors as soon as the ignition was turned on, and the cause was a wheel sensor.
Wireless phone charge bay - iPhone Pro Max
just seen this - I do find the right charger bay doesn't always charge though, the left always works, anyone else seen this?
arovbukay started following Wireless phone charge bay - iPhone Pro Max
Timing stuck at 38
Hello mate, There no adjustment on the camshaft on mine, you lock it from the end where the vacuum pump sits. So being is screwing with my fuel and I don't know what
Hello, I have same issue with kodiaq 2.0tsi 4x4. In Poland warranty service said that every VAG car have some vibration problem. I changed mc person bearings and gearbox mount. Nothing change with vibrations. User Akodiaq please contact priv
KamilM started following Kodiaq steering wheel vibration
KamilM joined the community
Can anyone help identify these hoses/parts
@Binx1310 can confirm you have the right part in your post, mine above was wrong. I ended up replacing because it was actually broken in two places and it basically came off completely in my hand. The 3M 24 self adhesive electrical tape is very good for that sort of thing if you can patch up though.
2.0TDI 184hv coolant issue
So I have problem with my 2015 octavia 2.0tdi 184hv. I can drive the car normally for how long ever I want, but when I floor it a couple of times, the coolant reservior is empty. Some of the coolant is outside the reservior, but most of it comes back to reservior when I open the cap. Already done: changed reservior cap, changed main waterpump, changed thermostat, checked for combustion gasses in reservior with combustion test, not the liquid one and there was no combustion gasses in reservior. I think it should not be the headgasket, because in normal drive there is no problems. Could egr cooler only give pressure to the system when I floor the car or could it be some waterpump, glogged radiator or leaking intercooler. I did pressure test while it was cool and there was no leakage. Also put 1 bar pressure to turbo and pressuretester on reservior and the pressure on reservior didn't go up. Should I just buy the egr cooler or is there some test I should do first
Joni5629 started following 2.0TDI 184hv coolant issue
- Felicia MPI: Strange Front-End Noise – Brakes & Bearings Replaced
Mood lighting, good but not good enough
Thanks David, but I already realised that. It's individual OR driving mode, but I really want both. Red for sport mode, and my very tasteful purple and blue individual colours for the rest of the time with my individual driving profile. I'll just have to add it to my list of annoyances...
Skoda News
Some good news. https://www.skoda-storyboard.com/en/press-releases/skoda-auto-in-the-first-nine-months-of-2026-strong-results-and-second-best-selling-brand-in-europe/
Timing stuck at 38
On the 1.9tdi BXE the camshaft pulley has three bolts in oval holes. When I did mine I had to loosen and adjust slightly. First I used locking tool kit and fitted belt then removed kit and rotated engine by hand but after a full rotation I had to adjust bolts slightlyt to get timing locking tools in again. Wasnt much probably 1mm but it may be enough to affect timing. Think they will run if only one tooth out but would be very noticeable. If its just slightly out by 1mm it may explain your problem. Alasdair
Alasdair1 started following Timing stuck at 38
1.5tsi put put sound on tickover diagnosis
https://www.skoda-parts.com/spare-part/05e133366dt-ventilation-pipe-with-akf-valve-skoda-46956.html Found it on Skoda parts. But also found another post where @imart143 said that he used 3m self amalgamating tape to repair it so I will give that a go before spending £170!
I think I’ve found it but will definitely try the tape at that price! https://www.skoda-parts.com/spare-part/05e133366dt-ventilation-pipe-with-akf-valve-skoda-46956.html
1.5 TSi - engine mods - intake / exhaust etc
Thank you. I will message them and see what they say!
Pretty sure the res delete has a subtle but noticeable effect. Note what JRRS said - anti-drone res delete. There is a closed-end tube added to the delete pipe which basically helps offset motorway drone. Probably same principle as noice cancelling - bouncing sound waves to a certain length so they’re coming back and offset the sound at fixed revs. Just an absolute guess mind you. RPM is based in Norfolk - pretty small outfit that do it all in-house. When I spoke and told him what year/engine the car was, he knew enough to ask me to look under the car and check as they had removed the res on some other models - sure enough, nothing there so I trust he has a bit of experience with the brand etc.
This is the same as I have on our 1.5 tsi. Just posted about it. Can you let me know part number please and I can investigate options.
Binx1310 started following Can anyone help identify these hoses/parts
Thanks for the reply Probably best of going down the custom exhaust route then, to stop any issues with fitment. I’m not sure what I want to do Sounds ok being standard Nice to have a quiet caR.
Activating SmartLink on Swing 3
Same issue here, with a cheap Ottocast it does not work. It is, as far as I can see, a compatibility issue. I updated the Ottocast firmware with no solution. My conclusion is VAG MIB units have deep hardware incompatibilities with certain multi-protocol conversion chips. Dedicated single-protocol adapters like AAWireless (which has specific VAG compatibility toggles in its app) could be the solution. For now I choose to use the cable solution as AAWireless is a bit expensive. But xmas is coming...
fuel filer panel
cheers buddy ! just trying to find out which solenoid it is on my car i think it could be 1 of 2 types, thanks kev
glow plugs
yea i have been told that, and that your car wont do a regen if there is a problem with the glow plugs. they do a bigger job than you realise. thanks!
