  2. Guys Today I fitted my dashcam from my previous car to the Karoq. My car has a rain sensor, so I decided to power it using a FitDvr adapter. This piggybacks into the wiring to the sensor and gives switched power, so no parking mode. Dongar also do a fitment for our cars, but were out of stock at the time. I took my time, ensuring proper connection and no damage to mirror shroud. It was dead easy. One thing to note is that the power doesn't switch off until 30s or so after you lock car and comes on when you open the door. For a video, watch FitDvr on YouTube for fitting to an Audi. Hope this helps someone.
  3. On my little A series (it has the current software for touch screen etc) you simply say the word "next track" and it skips. No " hey Mercedes" required. If your car is similar, there are several commands you can use with direct speech too
  4. andrewww joined the community
  5. I had a colleague who had one of these. The engine sounded great and he loved everything about it....except it ate front tyres strangely enough. MB said they often do that. Something to do with the standard alignment (it hopped about at low speed, especially manoeuvring and in cold weather). In the end, he took it to an alignment specialist and they adjusted the car to what they considered a more 'sensible' set up and there was once more peace, in the world.
  6. Was ordered in January , No problem wish they would have let me know as little things like this sway customers to other place 👍👌
  7. Not best impressed was expecting Contis .
  8. My Skoda Superb also just has the standard screen for the tyre pressure settings. A bit poor really. My 2015 Vauxhall has individual pressure display for each wheel which I woupd argue is a cheaper make of car. Bit disappointed when I first noticed.
  9. The Skoda 'configurator' for UK-specification Fabia cars currently indicates that five brands of tyre (Continental, Goodyear, Kumho, Laufenn, Nexentire) may be factory-fitted depending on the particular model and wheel-diameter that the buyer has chosen. 15" wheels may have Continental, Goodyear or Kumho. 16" wheels may have Goodyear or Nexentire. 17" wheels may have Laufenn or Kumho. 18" wheels will have Laufenn. I'm sure that the contract that the buyer signs will have a clause warning that the vehicle's specification is not set in stone and that the manufacturer has the right to change it. (I was at a Skoda dealership last Wednesday and there was a brand-new 130 in their showroom. The car had Continental tyres...
  10. Today
  11. Could be the alternator belt as you suspect but flat ribbed ones generally dont screech as much as V belts unless loose/glazed/oil contaminated or perhaps a tensioner/bearing has failed puting it out of alignment. Check the edges for wear and also check tension of belt. Alasdair
  12. As there are no further updates available for the colombus unit in my superb, thought I `d try Waze for the satnav? As far as I can tell phone is set up correctly and paired to the car no issues, but I cannot get any voulme through the car speakers like it`s supposed to do. Anyone had similar issues and know how to get it to work or is my colombus just not compatible? 2014 Lauren +Klement Superb Estate..
  13. How do you check this max privacy ?
  14. Some applications cannot be updated while you are driving. Try stopping the car, apply the handbrake and see if the app will update with the ignition on but engine off. Also check you are not on max privacy. If it won't then a trip to the dealer my be needed.
  15. I might have answered my own question. It appears the mk3 chassis is different to the mk2 so you need a different towbar. Pity. Still it means I now have a mk2 towbar to sell😃
  16. Hello all. I've owned my current Octavia 1.5tsi dsg SEL estate for around 8 months, now. It's on an 20 plate with fssh, 50k from new. I have a very intermittent screeching noise that seems to be coming from the mid to front end of my car. Occasionally occurs, after the car is fully warmed up, with or without the aircon on, only under heavy load or from a hill start, once moving with my foot down a bit. It's a screeching type sound that lasts for around 2 seconds. Not during tick over, but could occur at any speed. Originally I thought it may have been the aircon compressor or compressor pully, but I've now realised that it can occur with the aircon off or on. I dont think its a brake related or wheel related sound. My thoughts, dsg, alternator belt? I don'tthink its at the point where it would be easy to diagnose, as its not constant. I also have a Skoda extended warranty, until Nov, but at this point I don't think I'd waste my money having Skoda look at it, until I was a bit more sure what may be causing it and if it was easily diagnosed/replicated. Any ideas? Thanks.
  17. The car was getting me down a bit this week as there was hesitation in 2nd and 3rd, vibration in the cab from an uneven idle and the issues on start up. I was messing about with the pipes and took the one pictured off and put it on again and everything has went back to normal. The car is responsive and you can’t even hear it running. No idea what I’ve done, perhaps cleared an airlock or in typical mechanic fashion they’ve maybe not put the pipe back on again properly and there’s been an air leak. Thank goodness for that.
  18. Did you remove it? 😊 In Octavia 2 we pull last part in direction of edge like slide phone. Corners have forks.
  19. We managed with a Fabia estate with two kids so I'd expect you'll be fine with a Karoq. It'll be a fair bit bigger than a Q2. The Kodiaq is quite a bit longer and has a massive boot but if your parking in London is tight you might struggle a bit with it as it's only a smidge shorter than most traditional parking spaces which are only 4.8m
  20. Lee01 replied to Lee01's topic in Motoring News
    https://www.skoda-storyboard.com/en/lifestyle/chainsaws-and-sparklers-discover-the-traditions-of-rally-fans/ Škoda StoryboardMeet the Peaq: Comfort Just Like at Home - Škoda StoryboardThe interior of the Škoda Peaq electric vehicle is literally an oasis of calm. It offers comfort and relaxation not only while driving but also pampers passengers even while charging. See how the engi
  21. That may explain my late MK2 octavia as its not nearly as responsive as my old one. Its probably as you suspect factory programmed throttle lag to reduce emissions. Did read you can change it with vcds but not sure how. Someone on here will know. Had a quick google and AI came up with this but it is AI so I would be wary of messing up ecu until sure The Mod: Change the Throttle Response behavior from "Gradual/Incremental" to "Direct / Controlled by Threshold". [1] VCDS / OBDeleven Path: Go to Control Module 44 (Steering Assist). Select Adaptation 10. Find the channel named "Driving Profile Switchover" (or Kennlinien der Lenkung). Change the value from Incremental, controlled over time to Direct, controlled over threshold. [1] The Result: It makes the pedal mimic an old-school cable-driven throttle. The computer acts instantly on how deep you push the pedal, rather than waiting to see how long you hold it down
  22. Alasdair1 started following Slow gas response
  23. Skoda includes the Direct TPMS instructions in the manual because they build heavy-duty fleet versions and armoured/high-security variants of the Superb that do require live pressure sensors. However, for standard UK/European consumer models, Skoda only installs the Indirect ABS-based TPMS If your car actually had the system shown in the manual, it would require physical wireless sensor valves inside each wheel. If you have standard rubber or standard metal valves and the car forces you to manually hit 'SET' in the menu, your car has the standard indirect system and will never show the numbers My Skoda has the similar screens for tyre pressure as yours.
  24. Hi guys sorry I know this is an old thread. I had the same issues and changed my bulb but its not working. A mechanic told me it could be the balast or something. Can it b3 checked without ordering a new one or taking the whole light out as its a ball ache.
  25. Hi! I just got a used Skoda Fabia 2018 (MK3 NJ) manual 5D style 1.0 TSI 95hp. I know this is not a performance or sports car - and I’m not after advanced tuning - but there is one thing that is annoying me. Compared to my older Skoda Fabia Mk2 the older car had a much more direct gas response. The new car has significant lag when pressing the gas pedal especially switching gears - it takes a whole second before it even reacts which making shifting really jerky. Specifically when going from gear 1 to gear 2, I switch around 3000 rpm and with the gas pedal to the floor it takes like a second before anything happens and there is significant drop in revving I suspect this is some artificial lag introduced based on some European law euro emission savings or similar. I have access to vas5054a odis, vcds and odb11, I am in no way a pro, but I’ve been able to do some coding and flashing on my superb successfully. Grateful for any pointers or help on any low hanging fruits here
  26. Hi, We’ve got one 2 year old child and a second due next January. We live in London and currently have an Audi Q2. We are looking to upgrade but aren’t sure whether a Karoq is big enough/ enough of a change? The Kodiaq looks great but also wondering if it’s too big for London? Any advice would be much appreciated! Thanks
  27. Kohi joined the community
