SATNAV maps update?
Hi Alan, Did you by chance want to pass on/sell on that working CD you have? I have tried to serch up how to do it myself but stuck in a death loop of answers. Thanks in advance Voodood
Voodood started following SATNAV maps update?
My car's in a bad way
I mean, I've had the Octavia for 10 years and I just don't need the space now we have another fanily car. I don't drive as much as I used to, and most of that is <100 miles, so EVs make sense. I'm looking at a Cupra Born, which was better to drive than I expected. Infotainment is maddening(!) but I can get used to that, and I think overall it's a really nice place to be.
I had ordered wrong front wipers set Bosch A638S so I removed the rubber from them and put it on the OEM ones I had from the factory. You can call me a "cheap guy" but I didn't want to throwaway 40 euros The rear one fit like a glove on the Scouty - Bosch A405H.
- Amundsen MIB1 Firmware update finally completed - MSTD_EU_SK_P6230 MU0490
Car swap queries
I think these are all things you should be asking the dealer, where's the mat, tool kit and missing lumber support knob. If I remember correctly, sold my Kamiq in August, you get the compressor and tyre gunk, locking nut key and tow eye(s) bolts and probably a wheel wrench. Not sure on the jack and handle, a few cars recently haven't got those in the kit. Yep, I'd be asking the dealer where the missing items are first.
Simply So Clever
Couldn’t understand why my Karoq “bonged” at me when I got in this morning. Nor could I understand why in bright sunlight was the map display night mode, when it’s set to Auto. Then it “bonged” again when I opened the door to get out. Light bulb moment - the light switch had been knocked from Auto to Side lights. Quite clever really - never ignore a “bong” I think.🤔
thamestrader started following Simply So Clever
Porucha snimac polohy vack/klik hridele G40
@Deny Preložil som váš príspevok do angličtiny. Upozorňujem vás, že predvoleným jazykom na fóre Briskoda je angličtina. Na pomoc vám môžu poslúžiť online prekladové nástroje (napr. Google Translate). I've translated your post into English. Please be aware that the default language on Briskoda is English. There are online translation tools available to assist you (e.g. Google Translate) Camshaft/crankshaft position sensor fault (G40) I’m asking for advice to see if anyone has encountered this issue, as I’m at a loss for what to do next and am turning to the power of the internet. Out of nowhere, the car started making a noise like an old diesel engine; it’s a 2017 2.0 TSI (206 kW) with 189,000 km on the clock. The noise stopped after a cold start, but the "Check Engine" light came on the following day. In April of this year, I replaced both camshaft magnets (INA N205 units). Diagnostics showed two errors: 1. Camshaft/Crankshaft Position Sensor Implausible signal Sporadic fault 2. Bank 1: Intake Camshaft Retarded timing setpoint not reached Our first thought was the timing components; we inspected them and found that the previous owner (in Germany) had replaced some parts (specifically the plastic components), though the chain and sprockets had not been changed. When the connector to the exhaust camshaft adjuster was unplugged, the noise stopped, suggesting a faulty camshaft. A genuine Škoda replacement camshaft (complete with the sensor) was purchased. We used old oil mixed with a cleaner to flush the engine (to remove some carbon deposits) and then installed fresh oil and a new filter; we cut open the old filter and found very little debris. We measured the cylinder compression, and each cylinder showed 8 bar. The following were replaced: Oil and filters Sump plug Dipstick O-ring Magnet cover gasket Crankshaft oil seal Coolant Exhaust camshaft Camshaft valve Timing cover plate Sump gasket Sump O-rings Dipstick O-ring BG109 flush After these parts were replaced, the car was started; however, once the engine warmed up and the oil temperature exceeded 80°C, the noise returned and the check engine light came on. Thanks in advance for any advice. I am also attaching the latest diagnostic report.
Advice on new (to me) 25-plate Scala SE 116 TSI
@bigjohn Thanks for the reply. When first starting, the voltmeter usually shows ~12.8V The stop/start system often works the first time I stop (engine not up to temperature) and frequently fails to work after that. So that seems to be the opposite of what it should be. It will stop and restart after a few seconds or even stop and immediately restart. Several times when stationary in a queue for a long time it has stopped, restarted after a few seconds, then stopped again after ~30s, then restarted after another few seconds. The dealer said they had updated the software to the latest versions. The cruise control surges/brakes on the level. Maybe it thinks it's going downhill...?
totti7 joined the community
Don’t get obsessed with the voltmeter, when you first start up does the voltage raise over 13 volts?:- A)When you unlock the car and open the door even before you get anywhere turning it on the car will have fired up systems and the fuel pump ready for action which will effectively show a lower voltage. B)Modern stop / start charging systems are designed to save the odd bit of petrol by turning down charging after a while (On my Superb my voltage sensitive cool box used to shut down!) but overcharging when on the overrun to recoup energy (down hill etc). That’s why you need a better stop/start battery (EFB or AGM etc) as a traditional wet battery would struggle and fail prematurely. Stop/start errors are common - (eg you’ve only driven short journeys) but could be related to the gear indicator issue mentioned. Only unless your battery is in good fettle, car warmed up etc will stop start work. RE buggy infotainment system, it’s well documented on this forum that it’s buggy. Might need a firmware update - again well documented. Re Cruise control, to some extent surging a bit up hill or braking downhill is normal as the car is trying to maintain a constant speed. Sometimes the effect of this can be tweaked in the car settings?
2011 Octavia 2.0TDI 140 CFHC Fuel Filter Confusion
Had similar problems with my 12 plate. Part number on canister is the part number for actual canister which I assumed was filter number. Local motor factors looked it up and got the correct filter for me. Alasdair
Alasdair1 started following 2011 Octavia 2.0TDI 140 CFHC Fuel Filter Confusion
- Fitting rear wheel arch liners - my experience
DGW started following skoda superb 2.0tdi not reaching operating temprature
@andreas joined the community
Axle stand location
Intuitively that makes sense, but the workshop manual is very strict about not lifting it anywhere else! Which is why I've come here. 9.3 Raise vehicle Raise vehicle with a lift platform or a workshop jack The vehicle must only be raised with a workshop jack in the indi‐ cated jacking points -arrow A- and -arrow B-. a = 12 cm b = 24 cm The jacking points are located at the stiff joints of the bottom side rail.
- Activating SmartLink on Swing 3
Poprosím vás o radu, či sa niekto s tym stretol lebo uz neviem čo ďalej tak skúšam aj takto silu internetu Auto začalo mať z ničoho nič zvuk ako starý naftový motor je to 2.0tsi 206kw 2017 189xxxkm Pri studenom štarte zvuk prestal, no na druhý deň vybehla kontrolka check motora. V apríli toho roku som vymenil obe magnety vačkov. Magnety N205 INA Diagnostika ukázala 2chyby 1.Snímač polohy vack/klik hriadela Signál nedôveryhodny Kontrola závad zap sporadicky 2.rada valcu 1:vackovy hriadeľ sací Nastavení pozdeji nedosazeno Prvá vec čo nám napadlo že to môžu bytrozvody, ale tie boli rozobraté, predchádzajuci majiteľ (Nemecko) niečo menil (tie plastové veci boli menené) reťaz a ozubené kolesá neboli menené. Pri odpojení konektora od výfukoveho nastavovača vačky zvuk prestal, tak pravdepodobne že bude vačka zlá. Vačka sa kúpila originál od škody komplet zo snímačom . Dal sa starý olej a čistič aby prečistil motor (trošku od karbonu) a následne sa dal nový olej filter.. starý filter sa rozrezal, bolo tam minimum bordelu . Zmeral bary na valcoch a každý mal 8 barov. Menili sa Oleje filtre Zatka vane Gumička mierky Tesnenie veka magnetov Semmering kluka Chladiaca Vacka výfuku Ventil na vačku Plech na rozvody Tesnenie vane OKrúžky vane Okružná mierka BG109 preplach Následne po výmene tychto veci sa auto naštartovalo a pri nahriatí motora olej nad 80c sa ten zvuk zase ozval a zasvietil check motora. Ďakujem vopred za nejaké rady Posielam aj poslednú diagnostiku
Deny started following Porucha snimac polohy vack/klik hridele G40
Deny joined the community
Update: All of the problems have persisted and some new ones have emerged: under downhill braking with a full load (three people plus luggage) the whole car was vibrating the infotainment system is very buggy, often freezing or generating random characters when entering an address into the SatNav or sometimes activating a different random function when pressing an icon on the menu "Stop/Start system error" messages occurring on the dash display The Stop/Start often doesn't even attempt to activate (with the crossed-out A icon showing on the dash display) Cruise control often surges/brakes (feels like I've changed down to 2nd and briefly got massive engine braking) Tacho display showing nonsense gear suggestions, e.g. 6 -> 1 @rum4mo I've bought a 12V plug-in voltmeter. I tested it against a multi-meter on an external power supply and in the car against a multi-meter connected directly to the battery terminals - both times it was within 0.1V, so I know it is accurate. When the car has been sitting for a few hours or overnight, the voltage is ~ 11.7-11.9V and after a journey - even a long motorway run - it is usually ~ 12.3-12.4V. This seems a bit low to me. The car has been back to the dealer twice now. The second time I discussed all of the issues in detail with the Workshop Controller when booking the car in. The first time they said they had "updated and reset all of the software" and the second time they said they had "done some more software updates". To be fair, the brakes are a lot better, but the other problems are just the same. I'm considering my next steps. Should I... buy an OBD2 scanner - is this likely to show anything useful? take the car to my local garage, where I have had previous vehicles serviced for many years, and get an independent assessment go back to the dealer and try to get some redress under the Consumer Rights Act 2015, i.e. a replacement vehicle or a partial refund be done with it and sell the car Anyone got any wisdom to share? Thanks, Andrew
vagfranko started following Activating SmartLink on Swing 3
- The state of early mk4's in 2026?
Jaguar, will it survive?
This is interesting. Maybe Jaguar does have a plan after all? It is a shame if traditional buyers are effectively frozen out by this divisive design, but as I said many times before, nobody was buying Jaguars. I'm also taking this article with a pinch of salt, but there's no smoke without fire, I reckon... https://www.motor1.com/news/811711/jaguar-ev-50000-people-interested/
- skoda superb 2.0tdi not reaching operating temprature
- Yesterday
Hello at last!
Hi JN12 Need to find a fabulous independent myself. Sounds like you are a problem solver. Useful asset to all
Hortiguy started following Hello at last!
Head Unit not starting up
My head unit (central screen) is completely black and not responding at all. The screen between dials on instrument panel is however, fine. Have I bricked the head unit, or does it just need a re-code? I did take it out, as needed to clean the space behind it. Not wanting it to dangle, I did disconnect it. Recently changed the battery, but that was weeks ago, and didn't cause any problems. I've found that the cabin filter only has foam on two sides, not four, so dirt was taking the easy route instead of going *through* the filter 🙄 I have ODBII, or would i need VCDS?
zeta_91 started following Head Unit not starting up
Any difference between diesel and petrol airbox on mk3 vrs?
It does indeed replacing the factory intake system. On the TDI. The EA288 and EA888 are totally different engines. The actual intake duct is probably very similar, but the airboxes themselves are not. You can, from what I've seen, potentially modify the TSI intake to fit the TDI, although I've no idea why you wouldn't just get a TSI intake to begin with. There's no shortage of Racingline/Forge examples.
OccyVRS started following Any difference between diesel and petrol airbox on mk3 vrs?
Axle stand location
Just to add - the jacking point on the sill is actually only for emergency use. The car isn't designed to be lifted here, if at all possible. Absolutely get a decent jack pad.
Well, this thread was a bit of a rollercoaster. I've given my car all it needs, and more, yet it keeps throwing up issues. I've now got an issue with the steering system (probably the rack, unless the drop links have decided to suddenly go), and having just spent over £800 getting some jacking point damage on the sills fixed, it''s pretty gutting. What are you thinking of next?
