  2. Yes, the new slide pins slide in and out. I used some BTAS ceramic brake lubricant. I made sure I cleaned the face of the hub etc. I picked up a new hub today, so shall fit that tomorrow, fingers crossed this fixes it!
  3. It was indeed broken wiring between the the tailgate and vehicle body. You where spot on thanks so much.
  4. vnds_t joined the community
  5. Ignore, I missed that it' a TSI! ☹️ I'd walk away from that - that yearly mileage for the past three years will not have done any favours to the DPF - if it's actually still in place (should be MOT failure if removed). DPF regen history would make interesting reading!
  6. . @reedy10 Welcome to the forum. I am pretty deaf but it sounds pretty rubbish. Have you seen and read the Pinned thread on the 1.8TSI & 2.0TSI,s at the top of the Octavia Mk2 Forum? Maybe this engine has had work done, or maybe it could be an excessive oil drinker. 1.8TSI,s are a lottery. 76 pages of many horrors. Any record showing spark plugs changed any time recently, or air filter?
  7. Dealer. 53 k miles, definitely matches mot. Been driven last 3 years 2 - 3 thousand a year only. No record of exvess use. Tes tappety sounds right. Ither than this the car looks great.
  8. Thanks for the replies all. After a month I finally got the second key, which meant I had to go back to the garage, a trip of 83 miles, so it could be co-ordinated in, took an hour. Free of course. I had to chase them a bit but all's well in the end.
  9. Extremely unlikely that the VAG product has any 'magic ingredient' in it, just buy a reputable silicone grease.
  10. vav4ik joined the community
  11. JohnEric joined the community
  12. Welcome to the forum. Is this private or dealer sale? What is recorded mileage, does this match MOT history? I don't hear anything particularly unusual with that recording, possibly a little 'tappety' is there any record of excess engine oil use? Strongly suggest getting an independent vehicle inspection though.
  13. You are correct, car can potentially blind incoming traffic in auto mode because of the central barrier and how late will recognize incoming cars. So this is not perfect solution but I believe the best we've got at the moment. And that is why I mentioned that I personally don't use auto mode on motorway unless it's quiet and not so many cars. I don't think Skoda would offer repair to millions of cars( European drivers have same problems) for free even if they would recognize problem on my appointment. Most likely they would do exactly the same thing that this guy did to help me sort it out. But I agree, that is potentially solution causing blinding drivers if used on busy motorway. As per GPS slowing car in 30mph zones as an example, I can't comment as my car hasn't got sign recognition so I never relied on it.
  14. I've earmarked all I need to change the plugs on my iV's 1.4 engine. The only thing I'm unsure of is that in the workshop manual it states I should coat the base of the ignition coils with silicone paste. Apart from the price, is there anything exceptional about VW OEM silicone grease? If I want to buy non-OEM, is there anything I should be looking out for?
  15. Hello fellows and ladies, I would like to ask You for a help with my recent problem with my Karoq 1.5 MY2020 Day by day, the right rear LED suddenly stopped working (it dimmed, it is not fully 100% light?) Has anyone experienced a similar issue? Is it something I can fix myself? Is there a way that led bar can be replaced, or does the entire rear light part need to be replaced? I already checked the Fusebox - all good there. I cleaned all connectors with contact cleaner and scrap them a bit to made better connection for ground. I also read on diffrent forum that someone had similiar issue and some kind of PCB module had "cold solder joints" but I couldnt reach that person that he would explain what and where exatcly. So this is by far everthing that I had in mind to check, Any more clues and information I would be grateful Thanks in advance
  16. Today
  17. Hi Issue: Over a longer journey the air coming into the cabin reduces and gets warm. If the aircon is switched off the air blowing into the cabin increases significantly, if after a few mins the aircon is switched back on the pressure of air coming into the cabin remains constant but it now cools again. Under the car is a pool of water. Internet search: The search results suggest a faulty interior evaporator sensor, part number 5Q0 907 543 A. Which causes the compressor to run permanently, this causes continuous cooling and ice to form on the fins (apparently). Challenge: There is no video showing how to remove the lower dashboard panel below the steering wheel on a RHD car (which is where it suggests I need to access to replace the sensor). Firstly have I got the right place for a RHD car, secondly does anyone have any pictures/manuals, showing the removal of the lower dashboard on the drivers side for a RHD car? Or better still a video/still images of replacing the actual sensor. Thanks in advance!!!
  18. I’d check the folder structure first, because with these Skoda/VW map updates you normally can’t just copy the downloaded parent folder onto the SD card. The files and folders that the car expects usually need to be directly in the root of the card, exactly as they were arranged in the original update. Also, the formatting could be the problem. Depending on which infotainment/navigation unit you have, exFAT may not be supported even if the Mac lets you format the card that way. I’d check the exact requirements for your 2015 unit and try FAT32 if that is what the update instructions specify. One more thing: if this is the original navigation SD card, some Skoda systems use a specific card that is tied to the unit. In that case, formatting it or replacing it with another card can stop the navigation from recognizing the data at all. So before copying anything again, I’d check: exact infotainment system, required SD-card format, and whether the contents of the update need to be placed directly at the card’s root. The multiple folders in the download are usually all part of the map package, not separate optional folders.
  19. kinn777 joined the community
  20. Have you checked the brake servo vacuum hose for splits or cracks at the junctions of the hard plastic sections?
  21. You just clean what you can without moving the butterfly, which is 98% of it. They don't sit fully closed when unpowered if I remember right. So far I don't know which engine type you have, so it's hard to know specifics.
  22. That sounds like there may be a sensor fault preventing the activation. IIRC Seat belt & drivers door switch are involved, are they working ok ? According to AI ( which of course could be wrong! ) A Škoda "Auto Hold currently unavailable" warning means the system cannot maintain brake pressure at a standstill. It is usually caused by an unfastened seatbelt, an open driver's door, a weak 12V battery, or a temporary electronic glitch. Normal braking remains fully operational.
  23. Jools joined the community
  24. Thank you for the reply Auto hold is activated. But if I press to try and change it. I get the same message " this function is currently unavailable"
  25. Good luck. Please let us know how you get on.
  26. Check that Auto hold is still enabled. IIRC The automatic parking brake only engages, on ignition off, if auto-hold is enabled
  27. amine joined the community
  28. Thank you @Cairus, it worked and I got rid of the error! I installed the 3000er.xml dataset via ODIS yesterday, didn't try the 3600er.xml one. Can you please tell what the differences are between them and what car they are from?
  29. Surely if you disable the GPS link then the LED Matrix will still be blinding oncoming traffic - the whole point of the car knowing it is on the Motorway is so it can dip the right hand section (as the auto-dipping will not work where there is a central barrier blocks the oncoming headlights) It's just that it is dipping the wrong way (dipping the left hand side rather then the right) Also does this unlinking of the GPS and Camera effect the ability of the car to slow down when approaching a change in road speed (for instance, currently it uses the GPS and maps to slow down the car to 30 before you get to the 30mph sign)
