  2. Investigation all possible options, is there a MHEV Mild-Hybrid 1.5 driver without any clicking sound when pressing slightly the brake pedal??
  3. therealslimskoda joined the community
  4. Touch wood he has had it for three years now and no major problems at all bar a bit of usual parts/wear and tear etc and a new clutch but owner before may have been elderly due to lack of miles on clock . Seems to be the simpler they are the better. Its old but only done 80k. Bodywork good and just a small amount of rust underneath on subframe now its got new wishbones. He is looking for something more modern (he wants a saloon which these days narrows it down a lot) but I am keeping it if he gets anything else. Great little car Alasdair
  5. IVANbb82015 joined the community
  6. Tell replied to RodDuggan's topic in Skoda Karoq
    Going back through historic posts of similar situations. One example here. No published solution: Another post I did with links to the USB drives with LEDs Read this post and back: https://www.briskoda.net/forums/topic/532756-mib3-map-updates-202502-06/page/3/#findComment-5970567 That was the one I was thinking off. @wolfr4ge https://www.briskoda.net/forums/profile/237301-wolfr4ge/
  7. jbruem joined the community
  8. Thanks for this Calston. It's amazing that Skoda UK sell this for £225 and that is 'on offer'!! However, the tyres on my Fabia 2026 are 195/55 R16 and the part number for the kit is 6VA0 938 60B rather than 60A. Can't find that one on Skoda-Parts site though.
  9. I have replaced the rocker cover now and done 400 miles, its still burning oil but I think I now have it to about a litre every 1000miles or so, which is a lot better vs where I was. I think I am going to do piston soak and see if that does anything, I still suspect its piston rings. I also realise that when I had the head off I should have changed the valve stem seals as they can leak as well, so I am going to have to borrow a tool that allows me to swap them without removing the head. Might do the soak first though. If I can get it to around 1500-2000 miles per litre I will be happier, still not ideal but would be more acceptable. On the coolant side ive done over 2000 miles now and its only dropped tiny amount from a very small leak on the egr cooler pipes, so nipped them up.
  10. Ouch! Just read the end of your last response! Sod’s Law! Jim.
  11. Hi, Thanks again. I just need to get the removal tool and take it out first as I have all the parts intact, so I may be able to repair it first and put it back into place before buying another. 👍
  12. Today
  13. Then it must have been the feature activation.
  14. 1. SIM Card & Data Usage: For the PRO version, you simply insert your own SIM card (this isn't a factory eCall system with a built-in SIM). Lite version (no SIM): Can use a small amount of data via Wi-Fi (e.g., synced via home Wi-Fi or phone hotspot). PRO version (with SIM): Uses Wi-Fi data whenever a known Wi-Fi network is in range, and only falls back to mobile data when Wi-Fi is unavailable. Even then, it consumes only a tiny amount of mobile data (literally just a few kilobytes for lightweight text/MQTT payloads), so any cheap prepaid or basic IoT SIM card is more than enough. 2. Location Tracking: Currently, vehicle location is used and recorded within the Trip Logbook. Expanding this into further tracking features is purely a matter of software programming – once the project gets funded through initial sales and is properly up and running, I can easily develop and expand these features further.
  15. The mechanic did it, dunno how! In previous post I said "I solved it" as I was from mobile and it was faster way to answer....
  16. Missed services have nothing what so ever to do with Corrosion Warranty Claims as there is nothing in the T&C,s about inspections. ? Is there a body report from every other Service where they carried out an inspection and uploaded that to the system?
  17. It would not be a DQ200 DSG dry clutch DSG fitted to a 1.9 TDI. And anyway it was 2008 before fitted to the engines they were fitted to. DQ250,s were used from 2003 on some VW group vehicles.
  18. StepanBilan joined the community
  19. that amount of rust on the front crash bar is absolutely insane!! good u replaced it!! i like wat u've done with the re-purposed Golf GTi air vent guide. i'm planning to get a set for myself so next time i have the front bumper off, i can fit these. thanks for the idea.
  20. Thanks, I think I get the idea so will hack up a faraday solution and try it out. I think ultimately I might just need to find an external lock box (like Surf Lock) that fits the large key and also turn off KESSY.
  21. Yesterday
  22. My VRS has failed the MOT with the NS front spring broken , the parts should be here tmrw so i may try and do it the same day while we have longer days , can I ask a question , You say you can change the spring in situ , is that right ? Would there be enough room to get the spring compressors in to remove the spring over top of the shock ? I was factoring in knocking the strut off the hub and then compressing the spring . Also looks like I have only ordered the bearing and not the top mount , do i need the mount or can it be re-used? Also I dont have a hub splittter so was going to use a screwdriver and a allen key if there is room , good bad idea ? Thanks in advance Peeps
  23. How does the SIM card data plan work or are you expected to purchase your own ? Can the location of the car be tracked also ?
  24. My days, in 18 months this thing will be a historic vehicle of interest and will be LEZ exempt. The law is mad.
  25. Ok many thanks for the reply, I'll try and work out how to do all that!
  26. How you fix the FeC Problem? No way for The Pop-up...
  27. K0d1aqK1d joined the community
  28. Great news. These just keep going. My old one has been revived, and is doing a new owner a good turn.
  29. Fortyeights joined the community
  30. Hi, Sorry I know this is quite a while after the original posting date, but I have having the same issue and same rejection reasons put to me. Would you be open to sharing the contact details for Skoda head office? I have been in communication with Skoda UK customer services and they just aren't listening to me at all, taking accountability or being helpful in any way. I have put it back on them that if they are rejecting my claim due to a missed service, it was while they held my car in a Skoda dealership prior to my purchase of it.
  31. Hi all! This is my first post here but I was really hoping for some advice. The post regards my experience managing my first car on my own, and all had been going well until now! For context, I have had my Skoda Citigo 2017 for 4 years. I purchased it outright at 5 years old from D. M. Keith Leeds, before relocating to the west midlands where it has since been managed by Johnsons Skoda Burntwood. I have generally maintained a low threshold for escalating concerns as I am the only driver in my household currently to notice any issues. When taking my car in for its service and MOT (at Skoda Burntwood) on the 17th August 2026, I informed the dealership that I had noticed corrosion around the fuel cap over the summer. Quick google revealed its a common issue and should be covered by the warranty. Great! Weeks pass since I informed them and no word, I keep touching base with the dealership. Finally, on 8th September 2026 the dealership calls me to tell me the warranty claim (12 year body protection warranty (anti-perforation warranty)) has been rejected on the basis of "Skoda should have been informed 4 to 5 years ago". I push back, initially without full understanding of the specifics of the relevant warranty, but with the rational of my ownership of the car has only just gone on 4 years, and I didn't drive my car much following purchase due to my father falling ill and unfortunately passing a few months later. I was flying back and forth between Belfast and Birmingham a lot. So my car largely remained in the garage and used for short trips. And as mentioned, I was pretty vigilant about the cars condition so I absolutely would have brought it to the dealerships attention sooner if there had been something to notice. I ask for the contact details to escalate and was provided with the contact details for Skoda UK customer services. Over a month later, 6th October 2026, the advisor informs me of an second reason for the rejection now - that service history was incomplete. Yet over the course of my ownership, the service history is complete and all with Johnsons Skoda Burntwood. They quote an extended scope service missing from 2021. Also note, the 4 to 5 years reason has since not been mentioned. With awareness of the conditions of the warranty now, I continue to push back as it is not relevant per their warranty preconditions. It is now 26th October 2026 and I'm no closer to getting this resolved. I've requested transcripts of the call from the 8th September and the 6th October as evidence of the rejection reasons and when I have been informed. I'm just at a loss at this point. I know others have had the same issue and similar rejection reasons as me, yet they have been successful in getting it resolved (such as https://www.briskoda.net/forums/topic/528055-successful-warranty-claim/). Can someone please help me?
  32. TheNailbox joined the community
  33. I had a 14 plate diesel vrs, moved to a 23 plate petrol vrs estate and difference was very small most of the time. 40mpg average is realistic. Recently got a 26 plate with the 265bhp - slightly down on previous mpg figures but hoping its still loosening up
  34. Big thanks to Breezy_Pete for all your help in this matter; I now know why I can't see the shutters. Also, thanks, DerekU, for your input in this matter.
  35. Tell replied to RodDuggan's topic in Skoda Karoq
    That step 6 could be a mib2 high poster getting on the mib3 thread 🫣. You might have one off those units that is stuffed up. Presentation is everything the same as mib2 highs. They are signed files so if anything gets in there it knows and won't work. Sometimes people find downloading it again is helpful. Older versions of pkunzip although I reckon for mib3 you are better off using the built in windows 11 unzip. I've seen an all important file of mib3 getting swallowed up in pkunzip.
