  2. Well done! I found with mine the first time was the hardest, and since then they come out easily, they could well have never been removed since factory! The chrome strips clip into the main part so may well have come out a tiny bit when you pulled them off. May just need a gentle push back into position, or the overall piece may need realigning to push home.
  3. Cemac joined the community
  4. Today
  5. The clip that holds the bonnet support pole has come away and will not go back in place. I bought a new one from Skoda for £3 and I can’t figure out what I’m doing wrong. Can anyone advise how I get this yellow clip to lock into place. Image below is a picture of the clip I’m having trouble with. It’s a library pic not my actual car.
  6. iamwill joined the community
  7. How do I change my email and address Please?
  8. EJB started following Change details.
  9. I've actually had a pretty positive impression. They offer a huge range of parts at competitive prices.
  10. Sounds like the cabin blower motor or debris trapped inside the fan. Since the noise changes with fan speed and disappears when switched off, I'd start by checking the pollen filter and blower fan behind the glovebox. Leaves or worn motor bearings can cause exactly this kind of clicking and whining. If the motor needs replacing, Ridex car parts could be one aftermarket option worth comparing.
  11. Hmm. Not sure it’s a leaf. Had an explore under glove box - removed air filter and noise still audible. Definitely sounds like it’s coming from driver’s side in RHD set up. When I put fan on you can hear the initial noise in this clip. Sometimes it lasts a couple seconds. Sometimes it’s 5 seconds long. And then disappears. Could it be a bearing of some kind? IMG_1926.mov
  12. Looks like it's HSK 3D who makes them in the UK. https://hsk3d.co.uk/store/skoda-octavia-mk3-rs-vrs-rear-diffuser-fins-3d-printed-bumper-splitter-styling https://www.ebay.co.uk/itm/318144171141
  13. Sanburn at Coventry are fairly cheap. They’re on the Bayton Road industrial estate. Other than that, eBay is fairly good for parts
  14. We have been getting 12V low warnings from the car the last few days, and also it's been offline, so I know the 12v is in trouble. Reading around this topic there seems to be no definitive on whether or not mains charging or driving the car charges it back up, so my question....can I put my Noco battery charger on it " old school " if you like and charge it up? . If I do, will it mess up the cars electronics?
  15. Try opening the car with the key fob at the same time as pressing the flap, works for me
  16. Finally. After much cursing, swearing, copious amounts of WD40, plastic trim removal tool insertions / prodding & general faffing about for nearly 2hrs I managed to get the dam things off the car to access the fog light units. Surely it shouldn't have to be that hard? Installed LED bulbs which look great & now match factory headlights. However, one re-installed trim cover is not sitting quite right. The chrome strip is not flush with the corresponding piece on the lower bumper☹️. I'll leave it for now but my OCD will not allow it remain like that. More faffing required after I thaw out & have a cup of tea 🫖.
  17. Hi, so winter is here in Norway, and because of my joints grabbing and driving with the cold steering wheel isn't the best. So is there a way to take a wheel from a different car on the PQ46 platform and add that without too much hassle or is it a case of connecting to a custom timer/relay or something? Much thanks A cold Norwegian
  18. At the moment TPS (if you have one near you willing to sell to the public) price for 5 ltr Quantum 5w30 (Fuchs) is roughly £28 inc VAT.. Quantum 0w20 is about £41.50..
  19. If you tell me how / where to find them, I'll take a look
  20. Original battery probably another covid victim - likely completely discharged during layup and just left like that, resulting in serious hard sulphation.
  21. Fantastic! Thx so much for the steer. I'll get onto sorting this now.
  22. Had a quick google and it came up with this on AI. Most Likely Causes on a Škoda vRS (EA888 TSI / TDI) Faulty or clogged VVT solenoid (camshaft adjuster magnet/spool valve). Oil sludge, carbon buildup, or internal coil failure prevents the solenoid from opening and closing properly. [1, 2, 3] Damaged wiring or loose connector. Broken wires, frayed insulation, or oil intrusion inside the electrical plug on the cylinder head disrupt the signal to the ECU. [1, 2] Low or dirty engine oil. VVT actuators rely entirely on clean, pressurized engine oil to function; low oil levels or overdue oil changes commonly trigger timing solenoid faults. [1, 2, 3] Vacuum/PCV leak (secondary contributor). On TSI vRS engines, a torn PCV diaphragm or split breather hose often causes severe idle bouncing (900–2000 RPM) alongside timing faults. [1, 2] Step-by-Step Troubleshooting Check your engine oil level and condition. Top up if low, and note if the oil is dark or overdue for a change. Inspect the solenoid connector. Locate the exhaust camshaft adjuster solenoid on the cylinder head (typically on the timing-chain side of the engine). Unplug it to check for oil contamination, corrosion, or bent pins. Test the solenoid resistance. Use a multimeter across the solenoid pins; a healthy VVT solenoid typically reads between 5 and 15 ohms (an open circuit or zero reading confirms a failed unit). Clean or replace the solenoid. If resistance is normal, removing and cleaning the valve with brake/carb cleaner can free up a sticky spool, though replacing the solenoid or magnet is usually straightforward and inexpensive. Check for air leaks. If replacing/cleaning the solenoid clears P0078 but the idle still jumps, inspect the PCV valve and intake hoses for vacuum leaks. [1, 2, 3, 4, 5, 6, 7, 8]
  23. the admin team has already asked that all posts are made in english. Consider this an instruction to follow the forum rules you agreed to when you joined and use english or your account may end up being restricted. there are several translation tools available on the internet, for free, including google translate which works very well even with car related technical language.
  24. Take a look at VAGhelper: https://skodapilot.com/vaghelper/ Pretty sure that includes at least one Yeti config which might give you a good starting point.
  25. I had a new battery fitted to my 21 plate Octavia in May by the Skoda dealer. In the space of a month the car had gone from complaining the 12V battery was low to completely dying on me. A neighbour got the car started with a jump pack, and then tried charging it and reconditioning it with his CTEK but I think the battery was too far gone. If the car was left for more than 2 days without a run the battery would be dead. I didn't ever think the original battery was in good condition. I didn't have any tools to check it. But Start/Stop would only ever activate after a long drive. I don't think the early life of the car helped the battery health. My Octavia was manufactured in July 2020, but not registered until May 2021. So it probably sat in a car park for 10 months. I purchased it in January 2022. But I did always wonder why Start/Stop rarely activated. Once the new battery was fitted that all changed. Start/Stop now activates all the time when stationary in traffic even after just a few minutes of driving. Overall getting nearly six years from the original battery was probably quite good.
  26. This is the advice of the Motor Ombudsman The Motor OmbudsmanThe garage will not give me a courtesy car. Do they have...There is no legal or Code obligation on any accredited business to give you a courtesy car. Click here to find what to do if a garage will not give you courtesy car
  27. Yep. I'm going to give that a go. LED fogs waiting to go in 🤞
  28. MVegvari joined the community
  29. @Colin170CR - if u get a flat trim removal tool, u can insert it between the bumper and the foglight grille at the points shown in the pic below to pry it out. Back view.... Front view....
  30. Hello, Could you please help me to get the latest firmware of this Octavia 2015 infotainment? Thx, Attila
  31. Yeh, everyone I've spoken to agrees with you. I'll get that ordered today. I still have the front brakes to work on to keep me busy.
