vanko joined the community
Ains changed their profile photo
Flat Battery in Key Fob - Warning
Update: I saw a low battery key warning on the screen last week... which kicked in my "change all the batteries now paranoia"! All 4 (3 keys and immobiliser fob) were swapped for new Duracell CR2032s, which I did annually on both previous VW Golfs, and it was also just before service, so another minor cost avoided. I tend to buy a pack of 10 from Amazon so I have them on hand, and ... they have a longer lifespan than their annual use.
PHEV service intervals
If you are on a Service Contract, you can do an annual fixed 12-month, 10,000-mile servicing, my Superb IV estate 1.5 TSI/25Kwh has just gone in at 9 months and 10,700 miles, as we recently got back from touring France and will average down until next summer. This has always my preference, although the petrol engine has probably only run for no more than 70% of the time; I prefer the full annual inspection, which came with a video of all of the underside verifying no damage to any of the components/covers or leaks of the shock absorbers, a full tyre condition report and new oil/filter all documented across a circa 60 point proforma. They didn't check the tyre sealant because the boot was full, partly with a loose space saver, so I am double covered in any case. Given it's a big, complex car, I would not want to leave any of this for 2 years? Trans City also got to the bottom of a rogue Electric/Hybrid switching problem (user error with the App) and changed my number plate for £24, as I had applied for a DVLA change in the morning and had the eV948 form.
- Direct Firmware Download needed for Bolero in Octavia III
setnike started following Direct Firmware Download needed for Bolero in Octavia III
setnike joined the community
- Yesterday
VRS Mk1 crankcase ventilation system
Dean- thanks for the heads up. The SAI removal/etc is a bit involved but I'm sure I can manage it- in fact, the vacuum tube hoses by the dipstick could well be at fault- that would explain my low boost/ bad economy issue. Whether it has anything to do with my oil leak, I wouldn't know. The hose kit I bought had the vacuum tube assembly included, which I didn't fit. Maybe I should. It looks well complex to me, but I've got my head around the engine bay now so it could be a job for sunday. I've been pointed to a supposedly good mechanic though, at the very least I'm gonna get him to get his VCDS on it. Might tell me something. Incidentally, what does N249 /N112 refer to?
'Sleep package' rear headrests
https://www.facebook.com/share/v/1JV3CRBkLr/
Fabia 2 windows stop after 10 minutes.
Ah, nightmare! 😂 Thanks for this. I'll look in to getting the correct one. Thank you for your knowledge. Robin
Robin started following Fabia 2 windows stop after 10 minutes.
Radio harnesses
Hey, recently i bought a skoda felicia I break Super I, i have a 68 horsepower engine and i was trying to find how to connect a new radio on the car but i ran into a big problem firstly i how prevously a skoda felicia II but i don't think that the same interior harnesses for most part, but i remeber it was not like ont mine, i cannot connect a new radio on the plug i have on the car, i try to find an adaptator but no chance all of them are not compatible with my plug, so i need a little help, i know on some car the radio harnesses is connected on the cigars lighter on the fusebox but for me i don't find any form of document explaining all the connection of the fusebox, and i don't want to break my car on the fisrt month of ownership, So if you know how i can connect a knew type of radio harnesses i would realy value the help. oh and BTW the car is from 1995, and hasn't change radio i also send a picture of the fuse box if needed. Edit. the radio can be turn on even if the key is not on the ignition, so i know for sure i have a direct connection between radio and battery
Alexandregau started following Radio harnesses
G65 sensor no signal
Yeah Skoda looked them up via VIN, I’d also checked off a mates sensor too when the code didn’t clear. Same year and same sensor code. Checked the voltage to Climatronic module and this is correct. So issues must be on the main loom on the scuttle.
Alexandregau joined the community
iceman2 started following Transfering witter towbar to mk3 superb?
I'd like some advice please. I've had a witter detachable towbar that I fitted on my 2012 mk 2 superb for many years (I kept the old bumper support). I've just bought a 2023 mk 3 superb and need a towbar on that. Will I be able to unbolt the towbar assembly from the mk 2 and refit to the mk 3 or do I have to buy another, slightly different witter towbar assembly all over again ? Any advice welcome, thank you
Garryalln12 joined the community
Not sure. Something on the LIN bus causing trouble? What were the part numbers of the replacement sensors? Did Skoda look them up via your VIN?
So if those readings are correct what could be the probably cause of the no signal? Any ideas
They are probably referring to earlier, non-LIN version of the sensors. LIN sits at a high level when no data is being transferred, I believe.
Well all documents I’ve read so far point to 0.5v - am I missing something what should the correct voltage be
Pin 2 is a LIN bus connection; why do you think it should be at 0.5V?
It did yes. Done some further probing. Pin 1 - ground 0V Pin2 - signal 11.0V Pin3 - power 12.5v This is with ignition on, same readings at both sensors. Cannot don’t where the signal wire is picking up a live feed from. Should only be 0.5v.
- Škoda Octavia 3 MIB1 MSTD_EU_SK_P3420
Geoff001 joined the community
Did those include fuse 34, a 7.5 Amp ignition switched one?
Hello I own a 2015 Skoda Octavia 3 with an Amundsen MIB1 unit. Current SW Train: MSTD_EU_SK_P3420 (MU0435) Part Number: 5E0 035 874 A I would like to update my unit to MSTD_EU_SK_P6230 (MU0490). I have been looking for the original firmware archive MSTD_EU_SK_P6230 (0490).7z, but unfortunately all public download links seem to be gone. If possible, would you be willing to share the firmware archive or a valid download link with me? I would really appreciate your help.
irina0911 started following Škoda Octavia 3 MIB1 MSTD_EU_SK_P3420
Question Related Instrument Cluster/Trip Computer
Hello, My observation: this is working when you use Travel Assist and it depends on type of the road. In my country (Poland) it only works on highways (2 or 3 lanes) but not on expressways (even 2-lanes same direction nor inside cities). It's not working with ACC in my case despite of type of road. Pic from today: Superb IV - 2025.
Cam007 started following Question Related Instrument Cluster/Trip Computer
irina0911 joined the community
2024 Karoq Virtual Cockpit – Classic view auto-switching to built-in nav when CarPlay active
My July 2024 car acts as discribed by the OP. Can't say it bothers me. A few steering wheel button taps & I'm back to my usual dash display.
Some Question on New Superb Combi
benmankowitz started following Some Question on New Superb Combi
- 2024 Karoq Virtual Cockpit – Classic view auto-switching to built-in nav when CarPlay active
Never had this problem until a couple of weeks ago, I rolled back the update on Android Auto and reinstalled it on my phone, then reconnected to the car and it has not changed the VC layout when I go into Waze or MapsPWX01 joined the community- Nox Sensor Fault / Replacement
Thanks for that. This confirms what I found out this morning that these sensors have their own control module and don't require reset after installation.- Considering purchasing a used low mileage Monte Carlo 1.5Tsi DSG
So far so good for me, as for the infotainment, that’s only a hop and catch and not a regular occurrence, holding the on/off button down for about 10 seconds to reboot it usually solves the issue.
