  2. kzolee joined the community
  3. skoda_kodiaq joined the community
  4. Ben23 joined the community
  5. Might be debris in sump pick-up strainer.
  6. changed the oil pressure switch; however, when the car is running, the level on the dipstick shows low but stopped its normal oil and filter change tomorrow
  7. Today
  8. Interesting.. thankyou
  9. Thanks, I’ll try that.
  10. Thanks @Carlston . I have a Greenline model which I think may be lower than standard models for efficiency, perhaps adding to my problems?
  11. Found it.Is this the latest.If not how do i get the latest.
  12. I had a screw in one of these "sealed" tyres and it leaked. Had to replace the tyre.
  13. Not sure on the Scala but my old octavia 1.9tdi wasnt too bad a job to do once I got everything off. My newer Octavia on the other hand was tricky as some great car designer?? put the DPF and heat shield in the way of getting to it from engine bay. Managed eventually but awkward with my big hands. I used Sachs ones each time and they have caused me no problems at all since changing them. Alasdair
  14. To conclude this topic, having been assured by the main Skoda dealer, an independent garage in my village, and then by Autohaus Edinburgh that it is not a heated screen, I got on to Autoglass and arranged for a replacement to be fitted. On the appointed day I got to the depot to find a different technician to the ones I had spoken to before, standing by a brand new, gleaming, heated screen in a cradle, ready to be fitted. He first took the two trim panels off from the base of the screen, to reveal the two sets of wires and connectors, one at either end of the screen (it is apparently heated as two separate halves) proving that it was a heated one. Then, having first told me that he couldn't do much diagnosis, as he wasn't an auto electrician, he poked about with the connections, including something behind the cover by the rearview mirror housing and doing what he called a 'continuity test', and found that the glass was now heating up a treat, to the extent that with an ambient temperature of 12o C it became almost too hot to touch! This is a tale, then, of several garages and one pair of Autoglass technicians who didn't bother to check things properly, and another Autoglass man who did (and in a very helpful and friendly way). I still feel slightly sad, though, to have had to drive away leaving that gleaming replacement sitting in it's cradle at the depot! Incidentally, after all that aggravation, I now live in a house with a garage for the car to live in, so I probably don't need a heated screen now anyway!
  15. CJJE replied to Nebb's topic in Skoda Karoq
    Well mine has now been cured! Skoda Customer Services sent instructions to my garage when I had my 6 year service a few weeks ago, and updating the car's software from 0276 to 0334 seems to have let the update work. I suspect the old software level wasn't compatible with the update. As a bonus I now seem to have gained a lot of Radio Logos that weren't available before. There was no charge for the update, although it might have been covered by my extended warranty.
  16. Hi all first posting i have a 2020 Octavia vrs Device part number 5E3035816F Hardwarw H56 Software 1941 Display unit/control panel hardware H44 Display unit/control software 2088 Navigation database 23.1 Media Code 3.1.4 do i need to update this if so can i do it or the main dealer. sorry if this is in the wrong place
  17. CJJE replied to ian-inhome's topic in Skoda Karoq
    I suspected the QR code was to install the MySkoda app on your phone if it wasn't already there. And the Home Assistant link presumably just gives you access to the MySkoda app via Home Assistant? It seems overkill to me, although it may be useful for charging an electric car perhaps. This Home Assist stuff seems to be asking for trouble! I had a new shower installed in my bathroom recently, which could be linked to my WiFi! Even the plumber admitted the idea of being able to remotely control your shower seemed anything from pointless to dangerous! But if your kids hog it, perhaps you'd want to turn it after after 10 minutes??
  18. Never heard for MEN2 patch for 2021+, also didn't heard about triggered CP with this patch. Bootloop is possible if you corrupt eeprom memory, damage it physicaly, etc.
  19. Thank you very much, Alasdair, for your help and the useful advice! I'll make sure to pay special attention to the top hat seal when fitting the pipe into the master cylinder. Once everything is fitted and I've tested the car, I'll post an update with the results. Hopefully, this will finally solve the clutch problem! Thanks again for taking the time to help me!
  20. Is there a patch that will work on 2021+ cars? Heard one time that doing this patch just yielded locked CP, and bootloop even.
  21. Hi, as @Ridvan_V993 said, you can try and if not working write back default dump. I personally believe this patch will not work on cars 2021+.
  22. Or maybe just accidental damage during regular servicing - like when the air filter was replaced or other service work, aided by hardening of the plastic.
  23. As mentioned previously on my Octavia it only needed the top hat seal although it came with an o ring as well. The top hat seal pushes firmly onto pipe and almost clicks into place. Its very easy to knock it off when trying to fit pipe into master. Just watch where it goes if it comes off. Took me a while to find it again. Hopefully will cure problem. Alasdair
  24. If you were to unplug the LIN connector from the alternator while engine is idling on driveway, that ought to trigger the charging system warning light, I would think?
  25. Why not, you can always return it to how it was if it fails. Just keep your old EEPROM dump on hand 😉
  26. The gloss black on my Mk 3 Octavia has gone dull, i’ve tried various polishes, with no real success. Anyone any ideas as to what to use to shine it again? Thanks
  27. Baxlin started following B pillar gloss black
  28. Once the work is complete. Switch on the ignition. Clear any existing faults, otherwise it will not be possible to exit the brake pad replacement mode.
  29. Whereabouts are you based?
