Side lights
Personally I'd avoid Halfrauds. I had a dipped headlight bulb fitted by them. The car failed the MoT a few days later because the "expert" forced the bulb in upside down.
Throttle Body issue
VCDS is vw group diagnostic software which you can buy from Rosstech. Someone on here may have it near you and could help recalibrate it for you. If not it will need to be done at a vw/skoda garage or specialist unless your local garage has access to vcds or alternatively OBDeleven. On another thought are your brake lights working. A failed brake light switch can cause EML and limp mode? Alasdair
I will try to find out. I don't know him, he is a friend of someone I know and the topic came out during a chat, then my friend took me to see him. He did say its difficult to find if not using ODIS. I'll let you know once I will get in touch with him. Its pretty much disabling GPS to communicate with A5 camera. Then camera is relying on what it physically sees.
Another Oil Consumption Topic
@Linso Were you able to successfully progress?
Barrus started following Another Oil Consumption Topic
Barrus joined the community
the truth about electric cars
Rewriting history.!! Reva G-Wiz or Citroen C1. Nobody mentioned 1 million until the above post. @Graham Butcher
- Accelerate problem
Evolution13 started following Accelerate problem
My mistake; they were the first to produce 1 million of them in 2020. GM with their EV1 and Nissan with the Leaf were the first to put them on sale.
^^^ Yes i read it. Last night in motoring news. It is not only going to be only EV,s being recalled by manufacturers'. Tesla are quicker off the mark doing 'Their Recall'.
Very interesting. Can your friend release what he has done on your car by any chance? I just had a look through a coding and adaptation scan of my SIII and I cannot find the predictive route data in STG 4B. I only have predictive AFS as a selectable setting in the adaptations.
@Evolution13 Yes, I'm aware of that, applicable to new models, as it states in the article you posted, and the start date is 1st Jan 2027. However, the links I posted are recalls on already sold cars in use; they also mention software updates to lower the windows in the event of a crash automatically and stickers being applied, presumably to make the body-coloured flush door handles more visible to responders, which suggests that it is being claimed that they are not obvious enough to rescuers trying to open doors from the outside. It is not clear whether this recall is an interim measure while they design a retrofit replacement mechanical door handle. The article you posted also says that "previously approved models have until January 1, 2029, to update the door designs.
I know the recall above is Tesla specific but… flush door handles aren’t EV specific, so I don’t see how this relates to “the truth about EVs”. I also have to go back again to the fire blanket and point out you are moving the goalposts again, a long term tactic used by every conspiracy theorist for centuries - “EVs are serious fire hazard” “They don’t combust anymore frequently than ICE cars which are also a serious fire hazard” “That’s different, EVs are worse when they do combust” “That’s fair, but heres a product being developed we can use to potentially help counter the risk when they do combust” “Ahh but that’s only been shown in ideal circumstances so that doesn’t count and there’s no procedure in place for in the real world” “But it’s just a concept demonstration, of course it’s ideal, like any other concept demonstration” “Still different because reasons, they claim they don’t need to be serviced” Etc etc Everything has issues that don’t come to light until available and in use en masse. Then issues get resolved. But neigh sayers will always just move the focus to another point.
Throttle Body issue
Hi and thanks for reply! I have tried several different reset options around battery disconnect and then key on for 30 seconds and off for 30 seconds (also longer periods and also letting it idle) but it seems pretty stuck in the EPC limp mode. Interestingly one time when I was trying reset it seemed to be working and revving normally etc but immediately when I took foot off brake it freaked out and went back into limp mode which seemed very weird and should be unrelated. I have verified ok hoses connected and nothing else was disturbed in process. I am wondering if I messed up the insides opening it manually to clean (pushing valve open) How is the VCDS set? I assume that needs to be at a shop? Thanks, DDW
Throttle Body issue
Think it may need re calibrating using vcds etc but did read on another forum you could try turning on ignition but dont start car or touch any pedals. Leave for 3mins exactly. Turn off and wait for 10-15secs and start car. Leave idling for a few mins. If the above doesnt work try disconnecting battery for 30mins and reconnect. Turn on ignition without starting car for 1 min then start car and leave to idle for 10 mins. Hope it helps Alasdair
Alasdair1 started following Throttle Body issue
New regulations were coming in anyway that Vehicles had to have manual door handles. Discussed on here previously.
O3 - 2015 - 1.2 TSI - Replacing splash guards at rear brake disks, how much trouble to expect?
Not sure on the MK3 but if the bolts go through the wheel bearing hub from front the may protrude on the inside. If so make sure the exposed threads of bolts are clean. Just done my daughters volvo front bearing and used a wire brush on drill to clean up exposed threads. If you try and remove bolts with corrosion/dirt on exposed threads they can seize/break or damage hub carrier. Alasdair
Which Octavia Scout would you choose?
Am late to this but my opinion would be the PD140 Scout I've had a PD140 Octavia Estate (non scout) and I currently have a facelift mk3 Octavia Scout 184/dsg. For what you mention (forestry work) I'd avoid the DPF/complicated EGR and DSG where possible. The PD140 is easier to remove/block clean the EGR, you've no issues with the DPF blocking and personally if it was me I'd be less precious about the mk2 octavia in the forest, I can't comment on the capability of the mk2 scout but we did tow a caravan and horse box and in fields it was quite good and find the mk3 scout very capable (when moving, getting going isn't as good as expected due to the gearbox being so snappy). My PD140 was slightly modified but also used for towing, apart from a turbo issue around 85k miles it was faultless. I like the 'auto' driving from the DSG but find it when trying to manouver slowly a bit on/off so lacks the clutch control which isn't such a good thing on lose/muddy/gravel tracks (ask me how I know!!) I currently live in the Peak District and all our cars have had to tow caravans/horse boxes in fields but we're currently in the process of moving to Dumfries & Galloway to a smallholding hence choosing a Scout, no surfaced entrance to our property and quite remote so the ground clearance/haldex will be getting tested properly soon
No they weren't. Musk's Tesla were about 100 years late to the party.
China is recalling almost 3,000,000 Teslas over the flush-hidden door handles and concerns about their safety in an emergency, such as after a crash. I wonder how many other manufacturers will be doing the same. This type of handle seems to be everywhere these days. Nearly three million Teslas recalled in China over hidden door handles - BBC News Tesla recalls nearly 3m vehicles in China over door handle safety risks | Tesla | The Guardian Tesla Recalls 3 Million EVs in China Over Door Handle Safety Tesla’s Door Handles Lead to Its Biggest Recall Yet | WIRED Tesla and others begin record vehicle recall in China | Reuters Drive magazine indicates that they are not alone, other Chinese cars also recalled for the same issue. Tesla leads 4.3 million cars recalled for door handle safety fears
Here in Norway, they seem to be rather strict with these things, I therefore expect they would not accept the ones fitted at the rear of my car. I agree with your experience from the front brakes. When I replaced mine, there were small torx-screws which did not cause much trouble. The hexhead bolts I think I remember from the rear brakes of my car might well fasten a "hubcarrier" meaning the part to which the bearing gets fixed. In that case, breaking these bolts, damaging the threads is a scary thought....
2nd year service coming up, what should I look out for? Not driven it much
http://briskoda.net/forums/topic/540669-costof-kamiq-service-year-2 http://briskoda.net/forums/topic/540809-first-service-cost
lilRED joined the community
1.5 Petrol Sportline - that's what i'm thinking, seeing as it's only done 5500 miles - it doesn't need the major service right?
What engine has it? It should be much the same as the 1st Service but with a Pollen Filter extra. Oil & Inspection Service. Unless you are having the Brake Fluid Changed, or the AC serviced. But a dealership might try ripping you off. But the spark plugs are not getting changed or the air filter.
robinrottier started following Accelerate problem
Unfortunately I don’t have an active subscription right now.. I though about it but I wasn’t sure it will work.
what should this cost me?
UPDATE - CASE SOLVED. Hi everyone, I'd like to update you guys on the case. I just came back from my Europe trip. While being in Poland I got in touch with a guy who was familiar with this issues and already cracked the case. Using ODIS he turned "predictive route data" off in 4B module and after reseting few things(I'm not familiar with ODIS) headlights on motorway are acting exactly as on A or B road... I'm still not going to use full beam on busy motorway but when driving on motorway with low traffic it's actually working well. I cancelled my appointment with Skoda because obviously my modification in system would cause them to charge me for diagnostic and knowing they approach it was not certain that I would get anywhere with this case. So there is a solution but ODIS is the best option, apparently its possible with VCDS but its more complicated. Apart from couple of people, no one really responded to my post which is a bit disappointing, but I just wanted you to know that there is a solution! Many thanks 👍
