Ash load in DPF
Which engine has the lower ash count - the 2.0 litre Adblu one? I'd think 60g is fairly high, but I guess it depends on how long it will take to add the remaining 20g.
Warrior193 started following Fuel Leak! , Ash load in DPF and Skoda Octavia MK3 Greenline III (1.6 TDI) - cambelt interval
Soaked passenger footwells front and rear
@Nexus21 How did the door seal check go?
Not due yet if it was last replaced at 90K in 2020 - Skoda removed the 5-year cambelt replacement advice about 2 years ago so that their advice aligned with the rest of VAG world group, I believe present advice is around 120 to 140K without any time limit. You will find plenty regarding this subject on this and other VAG forums.
the truth about electric cars
Kei, kei-jidōsha, light automobile. Good episode on Grand Tour driving 3 Kei cars a few hundred miles in US and then up Pikes Peak ie up to 14k feet. The non turbo one took nearly half an hour and was gasping at the end. Not a problem with electric cars which get quicker with the less air !
Fuel Leak!
Unfortunately, DVSA were not interested in investigating or escalating the issue when I reported this fault to them last year! Their written response was "We do not consider this incident to constitute a fire risk as there was no ignition source present" I had substantial quantities of petrol running down the front of the engine and over the alternator!
There is nit really a choice but to super accelerate the transition from fossil fuel to electric. I cannot think of anyway we can get cheap oil again unless the Middle East Gulf full open until then the UK may have to pay a £1 a litre abd then choose what taxes to levy. The Excise Duty of 52.95 p per litre and VAT at 20% Ad Valorem will be under review. With UK debt approaching £3T the UK had difficult choices. Lots of us who decided to abandon use of hydrocarbons years ago would not want to see precious government money allocated to tax relief on what we see as polluting fuel and the government will be aware actions could tip bielection voting which coukd lead to the loss of the ex PMs constituency to the Greens. I di reckon we will see Excise duty cut for a period of months, maybe 5,8 or 10p a litre but we have to watch thatvtge oil companies don't taje the milk again abd trouser the Excise cut. Hopefully we can get more electric vehicles into all areas. Recipts from fuel already down by about a fifth in the past few years and it will fall away to relatively little in the next decade. We may need to consider rationing of diesel to keep back supply fir farmers, fire engines etc I reckon. Some countries limiting purchases to 20 litres a visit. Maybe we will see speed limits cut to 55 mph as in the oil crisis of '73 ?
like a Japanese K car
urban3k joined the community
Yes brick like but only aimed at city travel really, standard battery is 15 kwh i gather, bigger battery option a massive 20 KWh. Should be good round town. 15 KW motor so top speed only 90 kph, not allowed on motorways, classed as quadricycle. Expected to be £10k or less.
^ Looks very elegant and aerodynamic. 😆
fdani started following Ash load in DPF
Ash load in DPF
Hello, I would like to ask for your help. I have two different engine. DFGA and CXXB. 2.0 liter with adblue and 1.6 liter without adblue. The oil ash mass quantity is: DFGA - 60g CXXB - 11g The ash mass limit is 80g. Both cars have the same mileage and are used in the same way. Why is there such a big difference between the two numbers? Is 60g a lot? How effective is DPF cleaning? I'm not talking about regeneration. Thank you!
Fuel Leak!
I'd think that the only way to get anything from VW Group at some time in the future, will be to report this failure via the DVSA website - doing that might, just might, eventually get UK Gov to point a gun at VW Group over this issue!
infotainment system upgrade
@Eric_DK Skoda MIB2 (MST2) unit. · Software train version: MST2_EU_SK_ZR_P0359T · Installed SW MU version: 0359 · Part number: 5Q0035820B · Software version: H28.28.133_STD2_EU · Hardware: H30 · Media Codec: 3141.0.0.1 Fabia 2017
Digital Cockpit Display Error
Your automotive controller is no longer synchronizing with the graphics controller, which indicates a timeout issue. Updating or reflashing the same firmware might help. Otherwise, buy a used unit and find someone who can perform a full backup of the automotive controller, transfer the data to the replacement unit, and adjust the mileage.
Cairus started following Digital Cockpit Display Error
You might want to tell which infotainment system is installed in your car. Perhaps you could also say which model year your Fabia is from?
Eric_DK started following infotainment system upgrade
GevaarlijkeGek joined the community
Change octavia 2024 g-tec standard skin for vrs skin vcds 25.3
Thanks for listening, My octavia 2025 g-tec is not facelift version due to the headlights (I think facelift has SFD2) and I would like my digital cockpit to show the gas range. I tried change skins with vcds 25.3.1 but I couldn't find the vRS skin, I think i need unlock SFD due to VCDID code, see image attached. When going to 17 Instruments > Adaptation and typing "view" into the filter, I activated several views -such as 4, 7, 8, and 9- but I was only able to see a new skin by activating "view 8." I tried typing "Display depiction" into the filter, but whenever I attempt to activate any variant (Variant 1, Variant 2, etc.), it asks for a security code. Do you think this security code implies that I need to purchase an SFD token or is possible unlock security code writing a code in 17 Instruments > 16 Security Access ? Do you know how can I get the vRS skin in my CNG 2024 Octavia?
tton started following Change octavia 2024 g-tec standard skin for vrs skin vcds 25.3
danidani joined the community
Hi all, Just wondering what the cambelt interval on a 1.6 Greenline III is. I’m seeing conflicting information online. I’ve just bought my old Octavia back and the belt was done before I originally bought it in 2020 at 90,000ish miles. The car has now done 140,000 miles so I’m guessing it’s overdue? It’s been owned by a family member so I know the car hasn’t had the belt done during their ownership. Looking to get it booked in if it is actually due, but just wanted to make sure it definitely is before I shell out. Also what’s the going rate for a cambelt & water pump change at an indie currently?
Toby7243 started following Skoda Octavia MK3 Greenline III (1.6 TDI) - cambelt interval
Amundsen MIB2 Firmware Update
Hello, I feel I am late to the party and haven't updated my firmware since 2017. I believe I am after MST2_EU_SK_ZR_P0480T - (currently on P0468T). Can someone help point me to where I might find it? Thank you.
Rocketeer125 started following Amundsen MIB2 Firmware Update
CD PLAYER
Does the SD card fit in the extra slot in the glovebox unit? I'm a bit of a Luddite when it comes to electronickery, give me an engine to work on any day! Thanks, that looks the very dab.
CD PLAYER
Something like this means you can rip your CDs easily. https://amzn.eu/d/0iICC1YP
- Engine cover
thelee79 joined the community
- 38 mph in 5th gear ?
Skoda News
https://www.skoda-storyboard.com/en/skoda-world/what-was-racing-like-half-a-century-ago-skoda-120-s-rallye-delights-a-champion/
Engine cover
Top Cowling 1.2HTP Škoda 03E103929A ? Need VIN to check properly, but that's what comes up for 2012 CGPA engine. Maybe it had something non-original on it before, if that doesn't look like what you expect. I will message you to ask for VIN. Dirt on the outside of the engine doesn't matter, clean oil inside is much more important
- Engine cover
