the truth about electric cars
Here is a rather interesting theory on the rise of the EV throughout history, and it asks the question: are we making the correct decision now even, or will history prove that we are making things worse or better?
Marinho77 joined the community
TMC traffic events no longer being received...firmware update required?
Yes they pulled the plug for good but we did get three more extra years by swapping over from Traffic Master to Inrix. It was useful like yesterday long queues at road works in a rural area. Inrix would have told you and marked up the area.
The end of the service was determined back in 2011 https://assets.publishing.service.gov.uk/media/5a7b576a40f0b64646935832/Traffic_and_Travel_Report_1_.pdf
Replace all four tyres?
If only everyone was so proactive. If everyone checked tyre pressures or looked at treads or the inside wall of tyres before TPMS warnings or MOT failures.
Exactly!
thetudor joined the community
i've got same here. Was working with old maps and INRIX, but no longer :-(
2015 VRS TDI - Coolant loss from expansion tank
Doesnt take much to leak especially exhaust into coolant. Hopefully pressure test comes back good and a new gasket cures it. Alasdair
- Misfire clears up after garage inspection and then comes back with different lights weeks later minus idle misfire!
meianitell joined the community
LIMP MODE ISSUE
Could be an ABS wheel speed sensor! when problematic the car goes in to limp mode!
Dillers started following Random locking / Unlocking
Hi all. I have a 2023 Octavia VRS Phev and have had the usual software bugs and gremlins over the years. Something I have only started to notice recently however is that I’ll often find that the car is unlocked, sometimes having been so all night. And yet at other times, when I want it to remain unlocked (while I am washing it for example) it will keep on locking itself, despite me repeatedly unlocking it again. I know all about the key not being kept too close to the car etc etc, and I know for fact that I am not forgetting to lock it when I walk away. I have been driving for more than 25 years now and locking a car is just something you do without even thinking about it. Does anyone else have this issue at all, or shall I just chalk it up to being another one of my cars quirks?
Head is off, no obvious cracks (which is goodish), will be dropping it off on Friday for pressure testing. I do think there are some areas where it could have been leaking combustion gasses, thats the spots on 2 and 3 there it its got dark soot, not 100% sure but more evidence.
Skoda Felicia 1.6 fuel pump problem
Here's the diagram. The R5/J17 relay on the top. J362 is the ECU The "a" connection then continues to S4 fuse, which also powers injectors. Makes me think if someone connected it right to the 15 lead to bypass the immobiliser (not sure if it disconnects just the fuel pump relay or disables injector outputs, too on the 1.6)
...But that's the whole point of tyre rotation - reposition them before the wear pattern get too set.
Warrior193 started following Replace all four tyres?
Kamiq navigation
But this is just a restart without reseting to factory settings...
Citigo E IV won't charge
My wife has a used 2020 model that has just started refusing to charge using our domestic 13A supply. Symptoms are; Flashes orange led for 30 secs then acts as if charge completed. Same result with a different cable that shows initially 0.4 A then 0 Car seems to be sending the wrong signals to charge cable. This is the early model with no Bluetooth so we cant connect an App. The only way I can get charge in now is to leave the Ignition on and press the Chsrge button on the centre console but that is not ideal as the cae then cant be locked! Any ideas what to check? The 12v battery went a bit low but has since been recharged and id ok.
andrewclark55 started following Citigo E IV won't charge
Fabia Mk4 130.
What size and make of tyres are you planning to fit to the 17"-diameter wheels? The 18"-diameter wheels fitted as standard to the Fabia 130 carry 215/40 R18 tyres, whereas the tyres fitted when a Fabia Mk4 has 17"-diameter wheels are 215/45 R17. I wouldn't have thought that dropping the wheel diameter from 18" to 17" and fitting tyres that have the same width but a 45 'height' (rather than a 40 'height') would offer a worthwhile increase in pothole protection. For that you'd need to go to something like 215/60 R17, but that would look odd and there might be under-wheel-arch clearance problems with the 130 model.
Battery running down over a few days despite replacement
Connector was removed at the aerial. 5v measured on the coax. DTC aeriial fault wtill coming up after clearing it. So not being caused by the sharkfin. I ha ve therefore put it all back together for now,
Where do the rear panoramic sunroof drains end?
I also recall them from installing a towbar, but I can't remember if they were behind the bumper or behind the inner wheel arch liner, and I don't know where to start ;)
I can't hear the relay clicking, but there is a relay in the fuse box, and I tested it externally and it's good, so I've concluded that I either need to take it from the ECU cable or from under the steering wheel.
Thank You for answer, i'll do that
Maybe he connected legs of relay. Can you hear pump relay disconnecting after couple of seconds? Or maybe there is no relay just jumper.
kokosal started following Skoda Felicia 1.6 fuel pump problem
LeadDiplomat replied to codepass's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanOk so the car works, but that is not a relay issue in my opinion(i know only basic electrics so take this with a grain of salt) what he probably did is that he spliced a triger wire from the ecu to ignition 12 volts, prob becouse of ecu issue. What u can do is try and find where he spliced in(def a dashboard out job) and add a basic switch so u can manualy control the priming of the fuelpump(race car style 😉), or rewire the trigger wire back to the ecu and chase the accual issue. As for the manuals have u checked malualslib or scribid?
Kamiq navigation
Start the car (or turn on the ignition). Hold down the radio on/off button (volume control) for approximately 10 to 15 seconds. The screen will go completely blank, the Škoda logo will appear in the middle and the system will completely restart. After starting, check if the navigation has appeared.
Joco776 started following Kamiq navigation
- Infotainment Firmware Upgrade - 2021 Skoda Karoq
Belt pulley/alternator noise?
Showed this to a mechanic friend of mine and he diagnosed it as the OAP (overrunning alternator pulley) bought a replacement pulley for £60, a Sealyey pulley removal tool for £30 and had it off and replaced in about an hour. Would've probably been quicker if it hadn't been so hot! Also had to use a longer Torx bit than the one in the kit as the original (now discontinued) pulley was significantly longer than the replacement. Easy enough to do except maybe a bit of a hassle getting enough leverage with the alternator in situ but, frankly, couldn't be a**sed taking it off! Done about 300 miles since with absolutely no issues and engine sounds sweet. Thanks for the replies and advice 🙂
