Mk2 Octavia underside maintenance
As long as the engine / mechanicals last or are replaceable / repairable, hard to predict, so I would just protect against corrosion, do all services and replace all fluids including PS, brake and gearbox oil change (plus Haldex oil on 4WD) and afterwards enjoy driving the car, replacing worn out parts on occasion. Once corrossion is taken care of / prevented, there's still mechanical wear and tear including interior, but you can replace worn bushes, fans etc. Bear in mind your satnav will run out of updates at some point, if it has not already. My Mk1 Superb has had a visible drop in parts availability about 10 years from end of manufacturing, but I guess Octavia was made in so high numbers that there will be spare parts made for a long time. Mk1 and Mk2 Skodas in general were of better quality than later ones, including better noise reduction and better interior durability. I can certainly see it comparing the wear of our 14 year old "cheap car" Roomster to a 10 year old "family car" Mk3 Octavia vRS. In a way, it is also a curse, as due to crazy Skoda model line-up policies (no manual diesels except in basic Octavia, no varioflex seats anymore in Karoq) now would be a time to replace the Roomster or even both cars with a 3-5 year old Karoq, but I just cannot bring myself to replace a car with superior quality interior, versatility, space and range with something that admittedly looks marginally better on the outside and is a little bit faster on autobahn, but otherwise nowhere near as good value for money nor as reliable / durable / maintainable. Not to mention Mk1/Mk2 headlamps, at least projector ones, being vastly better for travel abroad at night (true flat beam, not dipped z-beam).
Superb 3V3 tailgate struts - Beware Autodoc
I have had no problems ... but I never trust their search patterns, for NO dealer/reseller, even those reliable and established ones like Rimmer Bros for my LR. Always double-check! Yes, is a small hassle yes, but it compensates by doing your own purchases and not paying extra % to a third party .... It is a classic that lots of parts are grouped/piled up by approximation, and particularly VAG is a nightmare for parts' codification. So always beware ... and don't trust the photos, unless they exactly reflect the item description and codes! I use this for checking part numbers, so far I have been satisfied: https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851
Doing own service!
I've not used, but seen Ridex parts and they are average aftermarket. The claim is that is an "autodoc" brand, so is similar in concept to ... for example a supermarket branding its "own" milk or dairy products. Nothing wrong per se but you have no idea of who is behind that ... not for me thanks. The established brands all have similar prices, but after years of experimentation, if I can, I buy genuine. I've started to notice this first years ago with air filters for my RRP38, the genuine item would be noticeable different than even a OEM like Mann or Mahle - thicker and lightly oiled paper elements, more supple rubber edges, and so on. Must make a difference, eh? For Skoda consumables (say for example Skoda-parts) the price difference in minimal, doesn't justify in my opinion to 'save a few quid' on parts that work on equipment which costs substantially more!
skywalker070369 started following Fumes in car
Replace rear parking sensor Octavia mk3 combi
- Offered an OTA update today
I'm likewise 302 but so far had zero offers of the 0334 update and continued daily minor updates that fail.ItayIlojes started following Volume keeps turning up??- 1.0 Tsi misfire on cyl 3, p303
- 2011 Superb VR6 Starts then dies, Fuel Issue??
quick one, but would a torn PCV diaphram cause this stalling issue? I am about to pull the PCV assembly out of the valve cover & see if its intact. I cant seem to find replacement diaphrams only online but cheap enough to order the whole thing. I'll update on tis in 20 mins or soItayIlojes joined the community- Wheel spacers?
NEVER EVER use standard bolts with spacers!! always get longer bolts, to compensate for the spacer thickness. also, make sure u get hub-centric spacers if ur going to get spacers.- Yesterday
- Newby Hi 👋
Tbh I’m with Willie 94 Rather bemused with how to say HI “Go to section you’re interested in” That’s say hi? I dunno New to this social media vibe I guess- Newby Hi 👋
- Gear changing started making sounds
Sorry for late reply. My car was at dealer's service at the beginning of the year. However, the issue still exists. In the service I was first driving a mechanic with me. I don't know if he totally understood the sound and the feeling I'm experiencing. He explained something that when the gear stick is in the middle and you change gears 3rd and 4th the cables are a bit looser and there is not that much tension than when using 1st and 2nd or 5th and 6th. He also wondered if cold wheather has anything to do with the sound. But it doesn't. I asked him to drive and test, but he didn't want to. However, he agreed to take the car for inspection. I went home and later they called and said there was nothing loose or wrong and that maybe (!) the sound is a feature. They argued that the mechanic had driven two other cars and they made the same sound. Before buying I had test driven a few year old Scala with over 70k km in it and the gear change was not like mine. It was similar to my old Leon and I was not having any problems with that. So it still makes sound that changes all the time. Also changing to 3rd is still not smooth and many times something resists when moving the stick. Also 2nd and 4th are not that smooth. 5th and 6th are fine. Basicaly you can't say in advance how it sounds or feels in every gear change. In one change it can be quiet and feel like you are moving it to soft rubber or so. Then on other changes it can make many kind of sounds. The different sounds are like "click", "clank", "click-click", "trrr". And they can be relatively loud. Also the feeling changes. In the spring I felt many times that it feels like something is spinning and it needs to settle in order for the gear to slot in. Now this doesn't feel anymore, but there's still something in 3rd many times which stops the stick movement and you have to use more force to push through. Sometimes this feels through the stick like you are pushing through tight metals that rub against each other. Sometimes the stick rattles or feels like jumping when moving. Is this something to do with synchros? I have also tested to change down to 3rd when slowing all the time and keep the stick at the point when something resists it to go further. When the speed drops to under 20 km/h or even 15 km/h then the stick shuddenly goes forward almost by itself to the end of the movement without a problem. This gear behaviour annoys me quite a lot. It's not nice to drive when the changing is not smooth and also the sound. @nmsilva96 Are you experiencing all these same issues or just some of them? What year model is your Scala?Blues joined the community- Rear parking break fault
What faults are shown when a diagnostic tablet / VCDS is plugged into your car?Lindsayt started following Rear parking break fault- Changing the Superb 18' Service Interval value
Bringing this thread back, as I've done quite a bit of experimenting with the car's coding. It turns out that changing only the SIA max value for the oil service and the FIX max value for the inspection with poor quality oil set did the trick and allowed me to set the service interval to 10,000 km. Everything else is set to 15k.- Hatchback chrome trim across lights. How is it attached?
gav_is_con started following Hatchback chrome trim across lights. How is it attached?- Bootloop media player
Arturz started following Bootloop media player- 1.0 Tsi misfire on cyl 3, p303
- Wheel bearing?
Warrior193 started following Wheel bearing?Arturz joined the community- Chrome trim How much!!!!!!!
I tried silicone and it didn’t last. Some have said tiger seal. I cleaned up the groove and made sure the trim was shaped well and not out of line and it seems to have stayed on its own. Time will tell.Binx1310 started following Chrome trim How much!!!!!!!- Rear parking break fault
Brake 😊- Replace rear parking sensor Octavia mk3 combi
Had to open the picture in a new window to do that - but it did work. As I thought, it refers to removal of bumper in a different part of the manual - so still doesn't answer my question.- Rear parking break fault
Hi All, I have a superb Mk3 Estate 2018 and for the last couple of days while driving I get a fault come up saying rear parking break fault, but once i stop the car and turn it off and restart the car it clears the fault. and the operates ok again. I've had both rear wheels off and checked wires and cant see any loose connections, wondering if anyone has had this type of fault or what was required to solve the problem.Robbo12 started following Rear parking break fault- Replace rear parking sensor Octavia mk3 combi
You can click/tap on the picture and then zoom in to see the text closer.- What engine for a Skoda fabia estate?
With the 1.4 TDI 90 with a remap to 115bhp. Sit at 65-70mph on the motor way and expect around 70mpg. A road 55-60mph expect 72mpg. Aggressive mixed driving and 75-85mph on the motorway expect around 60-65mpg. That’s with the DSG and my observation over 100000 miles.- Tire size conundrum
As "settings" i mean the gauges cluster module using long coding over OBD interface. Just as the OBDEleven threads for Octavia Mk.4 before FL, and for Golf mk 7 and 7.5 are stating. Or is the ASC doing it in a different way?Paulaner joined the community- SkodaParts.com review: Our Crystal winter rims have arrived!
No problem. I've used them a few times recently and am starting to view them as my favourite supplier for genuine or 'safe bet' pattern parts. Delivery surprisingly swift from Czech too. - Offered an OTA update today
