Valerii joined the community
the truth about electric cars
EV,s highly unlikely to be given their own NSL,s in the UK while ICE vehicles have different speed limits. Same thing as far as Electric HGV,s.
karolp1993 joined the community
Excellent alloys with near new tyres to fit Karoq and others
Now REDUCED ... £325 ono
Visually etc. My car of the day -today
The Games Manufacturers Play
@Guest_ was me.
CD PLAYER
On my Amundsen 2 you can use either SD port, currently I have the maps in port 2 and music in port 1.
Whilst cars are wonderful items they are much slower than trains in mhst countries. Cars will be abke to get much faster in the next few years by electronically tailgating each other to form, in effect, car trains. By talking to each other at 80, 90, 100, my EVs only can do 95 mph as motor spinning at max 12k revs. They can benefit from drafting, the cars at 2nd 3rd etc in the chain will break at the same time as the front car maintaining the car. Either a further adaption of adaptive cruise control and perhaps best to wirk without a driver. Obviously with different tyres etc they there would need to be margins. On the subject of tyres I was pleasantly surprised at the results of my service last week that my tyres have only worn 1.5 mm on the front and 1mm on the back in 16k miles. Therefore I should see over 30k miles on the front and 45k miles in the back m. They are Michelins and EV spec so only came with about 6mm ! Also incident ongoing at RAF Fairford involving explosives !!!
Changing Cars
Great car I hear. Enjoy.
Ash load in DPF
Again, you might be chasing ghosts, at least on CAYC one will for sure end up with ash mass measurement exceeding limit after enough mileage and regens even if the DPF is empty of ash altogether, it is just a calculation in the ECU that does not take into account DPF pressure measurements at all. Or in other words, if you make a 300 regens and drive 100k km, the calc could be e.g. num regens x 0.1g + num kkm * 0.3g (I pulled numbers out of thin air, just like the calc in your car's ECU) resulting in 60g ash mass "measurement" even if in reality there would be only 15g-20g ash in the DPF at that point. Conversely, if you use poor quality, ash generating oil or if the engine burns a lot of oil, you may find clogged DPF while the ECU's "ash mass measurement" shows 20g or less, as in fact quite a few people have experienced. May I ask why you are chasing after this number? Are there any other issues with the engine to even be looking at ash mass?
Experiences in retrofitting Superb mk3.5 steering wheel to Octavia mk3.5?
Hello everyone, first post, but long time reader! I love my Octavia mk3 facelift, yet find myself yearning for the steering wheel that's in the Superb mk3 facelift. The buttons and feel of scrollers are so much better. Coincidentally, I saw some posts on instragram recently of various versions of this. I wonder if anyone here have experience doing this retrofit? I have a heated steering wheel and don't need any paddle shifters, so I think its "just" the button mapping? I've seen posts swapping between old and new superb steering wheel, but couldn't find any for a superb --> octavia swap. Ideally I would hand this work off to someone who knows what they're doing 😂, but I am not sure where to look. I live in Norway, but could do a trip to Sweden possibly if some shop could do such a conversion. Any norwegians or swedes got some suggestions of where to start looking?
Suspension upgrade installed
@travs mine feels like new car now. In the end i went back to original bottom arms but also replaced my droplinks on the front. I went for 034 Motorsport dynamic+. Not cheap at £225 for pair, but the built quality and feel of the car is totally worth it 😊
2010 Skoda Superb electrical fault
Many thanks. I will get the garage to look into that. Strangely enough, the heated seat stopped working about a month before the power drain started
Ash load in DPF
I managed to obtain data from two 2.0-litre engines. 181000km - 55g and 130000km - 47g. The CXXB is now the main suspect.
OTSRK joined the community
Ash load in DPF
Not sure what the exact calc for ash loading is, but it involves both number of regens and mileage. What's the mileage on each car/engine? In any case, if there are no signs of restriction in the exhaust (power loss, increased fuel consumption, regen completion issues etc.), the large amount of "accumulated ash mass" is just imaginary, there is far less ash in the DPF in reality. It is just a number / counter in the ECU which by the way can be adapted to a smaller value with VCDS, at least on earlier engines like CAYC. I honestly think that ash number was just put there to cover backside in case of clogged DPFs over the car's life, and also to force replacing DPFs latest at a certain mileage / after certain number of regens or both. The correct way to evaluate amount of ash would be to measure and average pressure loss after completion of each regen and indicate that DPF pressure loss post regen is getting on the high side, but my guess is that given varying temperatures and gas flow, the exhaust sensors used for it are either not accurate or not reliable enough, especially after many years of use / high mileage.
Constant app updates
We don't use our Karoq much between trips to the continent. Last time we went in June/July we got the update message virtually every day. There ws never a message to say updated complete. The only odd thing I found was that at some time the settings for the cruise control were changed, causing me some concern, but that was soon corrected. We have just returned from another trip when again we get the message virtually every day, someimes more than once a day. Always accepted but nothing else. Having reset the headlight aim in the Channel Tunnel train, and gone back into settings to ensure the change was actually set, when I came home and tried to set back for UK, it was already on left side running. Whether the 'updates'had reset something in both cases, who knows. We had l Iittle need of headlights apart from tunnels, but I did do two or three ~10 mile trips in the dark and nobody flashed me! I would like to ask my agent but while away I received an email saying that, as of 30th September, ie Wednesday, they are no longer Skoda agents and service is being transferred to a local VW agent. Great! So what to do next? Had an MOT booked but doesn't look like that will be happening!
Routemaster1461 started following Constant app updates
GroovyHedgehog9 joined the community
- Fabia MK2 RS Owner Australia
@Evolution13 that's a spammer, see link inserted into quoted text. Reported.
^^^ 4 years later.
Evolution13 started following The Games Manufacturers Play
samirajl joined the community
Door loom fix wiring
Bumping old topic but this video extremely useful in having an idea on best way to get door apart and give maximum length of loom to work with. Not a job for the faint of heart or unsure with electrical.
BloodWorm started following Door loom fix wiring
Moving over
Hi, I've been on Briskoda for just over 4 years but on the Superb forum. Tomorrow I am getting my 2026 Karoq 1.5 TSI SE L Edition delivered. 3 Months old ex demo, so will be on this forum now a lot, to learn about it, and perhaps contribute a bit.
Changing Cars
Best of luck with it!
Changing Cars
Well, been on here for over 4 years now, contributed some, and learnt a lot more. But time to say goodbye. But not to Briskoda, just this forum. I am getting a 2026 Skoda Karoq delivered tomorrow, so will be migrating over to that forum. Thanks for all advice given here, it's helped a lot.
Ash load in DPF
Could this 60g be a natural occurrence? The worst-case scenario is that oil gets into the DPF. If the 60 g is a value calculated from the regenerations, it could not have accumulated from the normal regeneration cycles. It is currently regenerating every 350 km.
- Superb 3V3 tailgate struts - Beware Autodoc
01276 ABS Pump
Why? If valves are not stuck all four ways it is easy. I did not do laptop magic. Just gravity. Blocking pedal in down position is important. I would check if cable allows to connect another pump or look for extension on ali. Maybe brushes in motor are dirty, worn. Probabbly circuit sensing too much resistance or intermittent power supply.
kokosal started following 01276 ABS Pump
Amundsen MIB2 Firmware Update
I have the Solution and dont need help
