  2. if it was me , i would have kept the superb and bought the electric car that always comes top for reliability as a 2nd car you can get a 2 year old nissan leaf with next to no miles for around £11k, dirt cheap to run especially with solar
  3. twin dials, left dial shows drive in centre , right dial shows speed in centre, centre screen shows consumption, this is the screen that shows when I go into 2 cylinder mode. Hope that helps
  4. Today
  5. My 18th Skoda will be collected on Wednesday and is a Enyaq Coupe VRS in olive green. My first EV so lots to learn.
  6. I have plans to change boath front and rear. If I take the rear coils from M to P (up 2 levels) would it be the same in front?
  7. Would a failing oil pump produce swarf like that though?
  8. Hi Guys, New to the forum My name is Ash and was a member of this forum a long time ago! Just bought a nice mk1 fabia vrs that im looking to get a bit nicer as a daily hack....they are hoofing little cars! Got a few other cars on the drive/in the garage but love these little things! Anyway, hopefully meet a few of you in the future!
  9. Growing up loving Gerry Anderson shows, Thunder Birds etc, I can see Lady Penelope driving one. There are about 4 jobs in tier 1,2 etc suppliers for everyone at JLR so I hope JLR do well and glad they have embraced electrification. For Somerset's Tata $4B battery factory side as well.
  10. cossieash joined the community
  11. Thanks. I'll leave the other one up and close this one.
  12. @Lee01 this is a duplicate post
  13. Not that I’ve heard of! I reckon one failed and someone replaced it with a gas strut as it was cheaper. I’m surprised there’s no faults unless some coding has been done on it somehow.
  14. I set it up on both Google Maps and Apple Maps, and it works.
  15. This error appears right in the first step, A5.
  16. MarioHP joined the community
  17. Those bolts are in 10.9 class. Tensile strenght 1000 N/mm² which is high strenght, to get it to plastic deformation, much more torque needed than aluminum block can endure. I dont think i need new bolts. Not for aluminium mount. Old ones are good enough. It that place, when changing timing set belt, you have to change 50 bolts which is insane.
  18. I use a Ross Tech , so will continue until it is dead!micro can piece, long obselete but it continues to work
  19. From memory bolts may be stretch so should be replaced at same time. Did my sons fabia gearbox and reused bolts and no problems after 2 years though. Alasdair
  20. I am also sure it is dead. New LEMFÖRDER 39779 01 is 85€. Can change it by myself https://aftermarket.zf.com/en/catalog/products/39779%2B01?country=EN
  21. Check the other mounts as well as if one fails it puts more stress on them including the gearbox dogbone mount. Alasdair
  22. downloaded from the internet and translated into Czech
  23. Error Log? Which Manual you use?
  24. Cairus started following lane assist
  25. Check the auxiliary belt for wear on its sides. It may be a pulley or tensioner thats failed. Also check undertray is secure etc. Have a weird scuffing noise on my octavia that I think is brake pads rubbing but doesnt happen very often. waiting for it to get worse so I can diagnose it. Worse when cornering and then disappears. Alasdair
  26. My only experiences with JLR came via the LR bit. They have some very nice showrooms but In always got the feeling they weren’t interested in anyone who wasn’t paying 6 figures. As for the new Jag i feel i should slag it off but if I’m really honest growing on me. But not in silver it looks bloody awful in silver. Why do they keep showing the silver one. Have i mentioned it look REALLY BAD IN SILVER. Just a hint there JLR. CarWow were showing off a red one and it looked so much better. Not sure about the back at all though.
  27. Welcome to the forums. My Sept-2020 registered 1.5TSi SEL First Edition (now at 80k miles) is absolutely fine, and has been for three or four years. Can't remember when I last had a software glitch. Assuming the VRS you're waiting for has had ALL the s/ware updates due then it should be OK too. Hope you enjoy it as much as I do mine.
