- CarPlay crackling issue, software update fix?
jpokorny started following CarPlay crackling issue, software update fix?
jpokorny joined the community
Timing stuck at 38
Hope it cures it. Cant be as bad as my sons Fabia mk1 console bolts. Thought an hour a side maybe two turned into a day and a half a side!! but managed it with a lot of patience and releasol. As said hope it helps and cured prob Alasdair
What is the difference between a 40 kw and 50kw Skoda 1.3 mpi engine?
Some maybe by mistake give it 9.7:1 https://www.autoparts-24.com/engine/code/136m/15047/ (Note: While some technical databases occasionally round this figure up to 10.0:1 for late-model variations, the official standard for the Škoda 781.136M high-output block is 9.7:1) Although https://www.ultimatespecs.com/car-specs/Skoda/5623/Skoda-Felicia-13-MPI-68.html https://www.scribd.com/document/956290892/Skoda-1300-Manual Compression Ratio 10:1
It's 10:1, it's literally written in the pic which is official material from Skoda. Anyway, I forgot to write translation of non-obvious terms in the picture, relevant to the valve timing: Saní otevírá před HÚ - Inlet valve closes before TDC (top dead centre) Sáni uzavírá po DÚ - inlet valve closes after BDC (bottom dead centre) Výfuk otevírá před DÚ - exhaust valve opens before BDC Výfuk zavírá po HÚ - exhaust valve closes after TDC
RogueFabia started following Fuel smell - 2 days into ownership
Got my superb estate 2 days ago Filled up with £50 on weds Came home could smell fuel Same again yesterday Got home from a trip and could smell fuel Noticed a wet patch on my fuel tank Went to the garage today They inspected it and said there is no active leaks They had it in a garage with the doors shut and running and couldn’t smell anything But when I’ve had it back this evening Absolutely stinks Soon as you open the fuel flap it’s as if you have your head in the tank It’s so strong Did a few searches and there’s tons of info online One think I don’t know Is There seems to be a gap between the plastic and the fuel filler neck Is this normal? Also just pushed the rubber boot back down, would this cause the fuel smell? Or can it be pushed up with tank pressure? Possibly from a faulty evap or n80?
1.5 TSi - engine mods - intake / exhaust etc
I assume the Octavia vrs one will fit unless pipe is different diameter overall. But they make them in house so I’m sure they could make one at a price.
Scala Monte Carlo Edition Options?
Hi there, Love the Monte Carlo and wish I still had mine rather than the Karoq I replaced it with. Great choice of extras but personally I wouldnt bother with the headlight washers. I would also probably go with the assisted drive plus and the winter premium packages and consider the safety pack. I'm also considering another and possibly go Meteor Grey,[ last one was Race Blue]
minsy started following Scala Monte Carlo Edition Options?
I had a look on the website and they have 1.5 versions on there (obvs badged up for anything but a Skoda) but oddly no anti-drone version which seems nuts. Why would you not want it?! Anyway, they might do one if requested.
Venzi joined the community
Wing mirror adjuster stuck/broken
Hi all, Recently bought a 2010 MK2 after having to put my old, and first, car out of its misery. Few little gremlins I've seen but a rather unhelpful one is a stuck driver side mirror adjuster. Pushing the glass into place doesn't seem to solve the issue as it slides back to where it was. Not really possible to move the adjuster either and any movement puts the glass in an evening worse position facing into the car. Wondering if anyone is able to advice on a possible fix/cause? Strapped for cash so praying it is something I could realistically fix myself as someone trying to learn how to work on cars themselves. Cheers!
riotingspud joined the community
retro fitting oil level sensor in the samp?
03C 103 603 S Miss typed the serial number
Adaptive grille ahutter
Thanks for checking - it SHOULD be obvious whether or not a Fabia Mk4 has the cooling-shutter unit. Interesting that your 2026 Monte Carlo has the shutter-unit, but @Alvin600 's car evidently does not. I believe your car and @Alvin600's have the same 1.5litre engine and DSG transmission, so one might (perhaps!) expect them both to have a shutter-unit, or neither to have a shutter-unit.
Timing stuck at 38
I'll be changing the fuel temp sensor hopefully Monday. I hope it's not worrying, 5 minutes totems into 5 hours.....
Jack Point
Interested to know more. My mk2 octavia has already sill damage from previous owner/garage lifting it probably slightly wrong place. I too am not happy lifting on pinch welds either. Older cars I have had had a definite block in chassis that you put jack under. Lifting car with sill may be fine for changing a wheel but not if working on it. I generally try at front to get under console or at rear under control arm where it meets chassis. Then as a safety point put axle stand under pinch weld. Alasdair
Alasdair1 started following Jack Point
keshet33 started following retro fitting oil level sensor in the samp?
Hi everyone. My fabia mk2 1.6L 77kw 105Hp engine sump/oil pan got a crack in it because I overtightened it (stupid i know). I have bought the correct oil sump but when it arrived i noticed it has an oil level sensor precut in it. After a further look i noticed that My one has the precut plated shut. I thought that if i already got a new one I might as well retro fit the sensor if its not too hard of a job. Does anyone has/had any experience with retro fitting oil sensor of fabia mk 16L 16v? Uploaded photos of my old oil pan. Also here is the part seriel number number 02C 103 603 S Thanks for the help
Jack Point
These Powerflex ones look like a good idea, I am never that comfortable using the pinch welds. Are these a fit a forget solution and where exactly do they fit?
I believe @tombee fitted and RPM res delete to his 220 and the local powerflow branch did the fitting.
Binx1310 started following 1.5 TSi - engine mods - intake / exhaust etc
Brakes sticking on
Time to find a new garage I think 🤔 He was able to reproduce the problem which I guess is the only bit of good news. His view is that for some reason the master cylinder is not releasing pressure when the pedal is released. Yep, don't need to be a genius to work that out. When he changed the master cylinder he wasn't able to source an original so used a pattern part. He said previously he's only ever used original parts when changing master cylinders. His thought is that the new master cylinder is slightly out of tolerance and is not releasing pressure. His advice is that I should try to source a second hand original part and he will fit it. Don't want to do this as the second hand part could quite easily be no better than the original one that was on the car. Quite disappointed with his attitude as have used his garage for a number of years. Anyway, have got the car back home and booked into a local Skoda specialist. I explained what had happened and they were quite happy to have a look. Perhaps they'll have a new customer in the future.
Superb Mk2 2008 Keyfob Part Number
Much appreciate your help with this, Pete 🙂 I've looked for the Skoda Part number on Aliexpress but no luck. Looks like there's no cheapo solution to the keyfob problem. Thanks for the info anyway.
Translation in english (NOT mine) Main Specifications & Key Data Engine Type 135 (Production: 09.94 ➔ | Displacement: 1.3 l | Power: 42 or 43 kW | Torque: 94 Nm | Compression Ratio: 8.8 | Fuel System: Carburetor JIKOV 28-30 LEKR) Engine Type 135B (Production: 09.94–08.96 | Displacement: 1.3 l | Power: 40 kW | Torque: 94 Nm | Compression Ratio: 8.8 | Fuel System: Mono-Motronic) Engine Type 136B (Production: 09.94–08.96 | Displacement: 1.3 l | Power: 50 kW | Torque: 100 Nm | Compression Ratio: 9.7 | Fuel System: Mono-Motronic) Engine Type 135M (Production: 08.96 ➔ | Displacement: 1.3 l | Power: 40 kW | Torque: 99 Nm | Compression Ratio: 9.5 | Fuel System: Simos 2P) Engine Type 136M (Production: 08.96 ➔ | Displacement: 1.3 l | Power: 50 kW | Torque: 106 Nm | Compression Ratio: 10 | Fuel System: Simos 2P) Common Characteristics (Κοινά χαρακτηριστικά) Bore: 75.5 mm Stroke: 72 mm Firing Order: 1-3-4-2 Ignition Type: Contactless _______________________________________ As for the 136M Compression Ratio, i think is 9.9:1
Amundsen MIB2 Firmware Update
Hi I have the apparently common 00:00 glitch on the head unit of my Amundsen 2 head unit. I believe I need to upgrade its firmware to 255T, and that you can help with this? I'd be very grateful! Thank you in advance.
PhilipS1958 started following Amundsen MIB2 Firmware Update
Kodiaq steering wheel vibration
Great news!!! Please dont forget about me!!! Hope that it will work also in my car!
PhilipS1958 joined the community
Hello friend i cant writer prive because is not allow for fresh users. You Can find me on PL forum kodiaq The same nick. In accordance to this problem i solved it. I will describe it Heare when i ll find morę time.
Found chart from the workshop manual that shows difference in CR and camshaft timing between different engines. Though it may be useful.
Hello, this is my first post here. I'm thinking of buying a new Scala Monte Carlo and have been looking at the list of options, I would appreciate members views on what are deemed 'Essential' options and what are not worth having. These are the options I'm considering; Skoda Sound System which comes with space saver spare wheel. Headlamp Washers. Variable Boot Floor. Assisted Drive package, The package integrates driver-assistance systems to enhance driving comfort. Predictive adaptive cruise control and adaptive lane assist keep the vehicle in lane and maintains speed and distance from the vehicle ahead. Convenience plus package with park assist, This pack adds park assist to the convenience plus package. Park assist is an automated system for pulling into and out of parking space - the system detects a suitable space for both parrallel and bay parking and assists with the manoeuvre, the Plus package also brings electrically operated boot with a virtual pedal to allow you to open and close the boot lid with ease. I would also like Underseat Storage Bins but cannot find them mentioned on Skoda site, but I'm sure I've seen them mentioned somewhere? Please comment with your thoughts on the above options and any others you may deem worthy of having. Thanks. Regards Walone.
Walone started following Scala Monte Carlo Edition Options?
Mood lighting, good but not good enough
Oh sorry. Yes, on rereading your original post I can now understand what you meant. Best wishes.
