Notta762 started following Skoda Octavia Mk3 (2013 - 2020)
Notta762 joined the community
How-to Guide to Upgrade MIB2 to MIB2.5
I wrote a guide for connecting by UART should anyone need it in future.
UART connection to MIB2
Having had to do this recently to try to recover a bricked MHI2, I found the info to be a bit all over the place so thought I would gather it into one guide. You may well need the guidance of an expert such as @pab567 once connected to the MIB for the next steps in recovery/programming, but this set up will allow them to remote access to you to do so. I take no responsibility for any effect connecting in this way has and am in no way an expert on this process! Parts required: TTL to USB adaptor. There’s lots about on Ali or Amazon. Look for CH340 chip and you need to make sure it supports 3.3v. This is the one I used https://amzn.eu/d/03Rt3b1k Quad lock extension cable. Not completely essential but this is an easy way of connecting to the right pins and also allows you to connect cleanly and reversibly to the existing wiring whilst maintaining all the other connections to the car for testing purposes. https://amzn.eu/d/086O3DlR Connectors, such as crimp terminals or WAGO connectors. Laptop First step is to make up the cables following this guide https://www.scribd.com/document/849387823/Connecting-TTL-adapter-to-UART-on-quadlock-VAG-MIB2 find the correct wires in the quad lock extension cable and then cut them and crimp/connect on the UART connection wires so they connect to the lever plug end of the extension. I added some labels so I could ensure I connected them to the USB adaptor correctly. You may need RCC or MMX connection so I added in the wires for both and then just connected the right ones to the USB adaptor as needed. Next, prepare the laptop. Download and install PuTTY https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html Plug in the USB and find the correct com port associated with it in device manager. Then set up the connection as per the scribd article linked above. Save this as a profile for easy connection next time. Find the correct password required to login to the MIB based on brand and software version as per this article https://www.scribd.com/document/464567838/Audi-Mib2-solution And put it into a txt file so it’s ready to copy and paste. Now connect to the car. It is essential that the car battery is in a good state of charge. Connect a good quality battery charger during this process. I would highly recommend charging the battery for a few hours prior to starting this process to ensure it’s in a good state. You can take the MiB unit out of the glove box but I chose to drop down the whole glove box and rest it on a bucket as it allowed access to the fuses and keeps all other wires connected to the MiB. Remove the 20a fuse (position 12) from the fuse box to power down the MIB unit. Remove the quad lock from the back of the MIB unit and add in the modified extension you have just made by connecting it to the back of the MiB. And the other end to the quad lock of the car that you’ve just removed from the MiB. Ensure the correct wires are connected to the usb adaptor in the right way and that it is set to 3.3v. Plug usb in to laptop. My wires were quite short so I had to balance the laptop on the passenger seat. You can extend the wires when making the adaptor but they should not be extended more than a metre. Open putty and load the profile you set up. You should see a blank black screen. Now copy the password from the txt file. Insert the fuse for the MiB unit. You should see the screen now being populated with text and code as the client logs the activity of the MiB. Press enter and type root, then enter then right click on the black background. (This will paste the password you copied) and press enter. If the login is successful you should see “Audi MIB” in ascii characters as per the picture above. You are now logged in to the MiB. If you are being supported remotely ensure you have an appropriate remote access tool installed to allow your support to control your laptop to enter commands. Using certain command codes it’s possible to backup to an SD card as well as various things such as remove component protection or update fec codes/ program the eeprom etc. I have no information on how to do this! There is a high chance of bricking your unit so do not proceed unless guided by an expert or you are confident in what you are doing!
Binx1310 started following UART connection to MIB2
the truth about electric cars
Rolls Royce engineer. Think he prefers trains to cars.
Advice on an Octavia I'm on the edge of going for
The Octavia is a great family car IMO. VAG cars do like pampering though and servicing can't be skimped on without risk. They're very good so long as you anticipate known issues and head them off. Some have high oil consumption, some have issues with silica bags in the coolant that can split and gum up your heater matrix. The more you learn about your car, the better you'll be able to prevent things going wrong with it. (I've no idea what the dealers are like these days as I ducked out of the dealer network as soon as my warranty was up.)
- Austin Mini GT-Four 'Project Binky' Build, Youtube Video Series.
Soarific joined the community
That's on my viewing list this weekend as well. I have to say that I'm impressed with Francis Bourgeois; having known that he was a very excitable train buff, I never expected him to be so knowledgeable about cars.
Ash load in DPF
I predict that you will find that the DFGA needs topping up with oil between services.
Chusan joined the community
Ash load in DPF
The cxxb doesn’t use up the oil; as for the dfga, I’m not sure. I haven’t used the dfga much yet.
1.9 TDi Timing belt kits
I've just messaged the supplier as Google says it should be an ina tensioner pulley, not a gates
Ash load in DPF
Hello, The 1.6-litre engine has a lower ash content.
CD PLAYER
Yes, music goes into the non-GPS SD port - can't remember, but I think that's port 2.
Ash load in DPF
Does the DFGA engine use/burn more oil than the CXXB?
Ash load in DPF
Which engine has the lower ash count - the 2.0 litre Adblu one? I'd think 60g is fairly high, but I guess it depends on how long it will take to add the remaining 20g.
Soaked passenger footwells front and rear
@Nexus21 How did the door seal check go?
Skoda Octavia MK3 Greenline III (1.6 TDI) - cambelt interval
Not due yet if it was last replaced at 90K in 2020 - Skoda removed the 5-year cambelt replacement advice about 2 years ago so that their advice aligned with the rest of VAG world group, I believe present advice is around 120 to 140K without any time limit. You will find plenty regarding this subject on this and other VAG forums.
Kei, kei-jidōsha, light automobile. Good episode on Grand Tour driving 3 Kei cars a few hundred miles in US and then up Pikes Peak ie up to 14k feet. The non turbo one took nearly half an hour and was gasping at the end. Not a problem with electric cars which get quicker with the less air !
Fuel Leak!
Unfortunately, DVSA were not interested in investigating or escalating the issue when I reported this fault to them last year! Their written response was "We do not consider this incident to constitute a fire risk as there was no ignition source present" I had substantial quantities of petrol running down the front of the engine and over the alternator!
There is nit really a choice but to super accelerate the transition from fossil fuel to electric. I cannot think of anyway we can get cheap oil again unless the Middle East Gulf full open until then the UK may have to pay a £1 a litre abd then choose what taxes to levy. The Excise Duty of 52.95 p per litre and VAT at 20% Ad Valorem will be under review. With UK debt approaching £3T the UK had difficult choices. Lots of us who decided to abandon use of hydrocarbons years ago would not want to see precious government money allocated to tax relief on what we see as polluting fuel and the government will be aware actions could tip bielection voting which coukd lead to the loss of the ex PMs constituency to the Greens. I di reckon we will see Excise duty cut for a period of months, maybe 5,8 or 10p a litre but we have to watch thatvtge oil companies don't taje the milk again abd trouser the Excise cut. Hopefully we can get more electric vehicles into all areas. Recipts from fuel already down by about a fifth in the past few years and it will fall away to relatively little in the next decade. We may need to consider rationing of diesel to keep back supply fir farmers, fire engines etc I reckon. Some countries limiting purchases to 20 litres a visit. Maybe we will see speed limits cut to 55 mph as in the oil crisis of '73 ?
like a Japanese K car
urban3k joined the community
Yes brick like but only aimed at city travel really, standard battery is 15 kwh i gather, bigger battery option a massive 20 KWh. Should be good round town. 15 KW motor so top speed only 90 kph, not allowed on motorways, classed as quadricycle. Expected to be £10k or less.
^ Looks very elegant and aerodynamic. 😆
fdani started following Ash load in DPF
Ash load in DPF
Hello, I would like to ask for your help. I have two different engine. DFGA and CXXB. 2.0 liter with adblue and 1.6 liter without adblue. The oil ash mass quantity is: DFGA - 60g CXXB - 11g The ash mass limit is 80g. Both cars have the same mileage and are used in the same way. Why is there such a big difference between the two numbers? Is 60g a lot? How effective is DPF cleaning? I'm not talking about regeneration. Thank you!
Fuel Leak!
I'd think that the only way to get anything from VW Group at some time in the future, will be to report this failure via the DVSA website - doing that might, just might, eventually get UK Gov to point a gun at VW Group over this issue!
infotainment system upgrade
@Eric_DK Skoda MIB2 (MST2) unit. · Software train version: MST2_EU_SK_ZR_P0359T · Installed SW MU version: 0359 · Part number: 5Q0035820B · Software version: H28.28.133_STD2_EU · Hardware: H30 · Media Codec: 3141.0.0.1 Fabia 2017
Digital Cockpit Display Error
Your automotive controller is no longer synchronizing with the graphics controller, which indicates a timeout issue. Updating or reflashing the same firmware might help. Otherwise, buy a used unit and find someone who can perform a full backup of the automotive controller, transfer the data to the replacement unit, and adjust the mileage.
