AC coolant level/ system function indicator?
So, which of the very many live data parameters (or, is it not in live data) gave information about AC system pressure? thanks,
Ball joint to control arm joint torque spec - wildly different for pressed vs cast steel arms?
Ok then. Let's hope the studs are made of some pretty amazing steel to take that torque without snapping.
Kodiaq towing speed warnings
Hi I am a new Kodiaq owner and when towing on a dual carriageway and several motorways, I am getting a towing speed limit of 50 mph when the actual speed limit is 60 mph. Is this a known issue and is there a fix to this? The tow bar, electrics and towing display seem to work correctly in all other respects. The tow bar and electrics are Skoda supplied and fitted.
Erewash100 started following Kodiaq towing speed warnings
Thanks @Breezy_Pete , yeah, guessed that; now, is there any way to get out of the system when that happened? We know that the system had been low (I had it recharged, and the amount of gas extracted was almost 50% low; I took these recordings after the recharge); my OBD11 never reported any faults in this system 🙄
vRS Owners, cars with a VAQ front diff, a question on the servicing and what you are being told at Skoda Main Dealerships?
Bump for @CC300ZX
Garciasfinger joined the community
JD52 started following Third brake light removal estate mk3.5 VRS
hello from me
Hi from me as a new member. Looking forward to seeing what goes on.
Erewash100 started following hello from me
Hiya all My third brake light has decided to crack and I'd like to replace it, however I'm struggling to find any youtube videos that show how it all comes out. Has anyone done one before or does anyone know of any videos that they have links to? Might be worth mentioning ive got a Combi/Estate VRS so ive got the spoiler above it aswell. Many thanks Kyle
KyleHa started following Third brake light removal estate mk3.5 VRS
Erewash100 joined the community
Hi all: Is anyone able to do a VAG Service history report for me please (Skoda Superb 3)?
This is really brilliant help. Thank you so much 😄
Thank you so much. You Guys are the best. PM Sent. Many, Many thanks. 😊
The reported shutoff due to low pressure event would be a clue pointing you toward lack of refrigerant, I expect.
You will not find any data for 'AC clutch' as the Mk3 A/C system doesn't have one - the compressor is permanently driven via a sacrificial shear plate.
Warrior193 started following AC coolant level/ system function indicator?
AlistairR joined the community
OCTAVIA 3 PARTS
Maxton design Honeycomb grill for facelift VRS, never fitted, £65 posted. Racing line intake kit, Gen3 888, airfilter, grill rear blanking plate, Turbo inlet elbow, silicon hose, never fitted, £145 posted. kit to convert bonnet to strut opening, never fitted, £15 posted. Powerflex Dogbone mount and new bolt, rear anti roll bar bush, £20 posted. These were bought for 2019 VRS 245, never fitted as I changed car.
MikeTheThinker started following OCTAVIA 3 FL
OCTAVIA 3 FL
LED Lighting. puddle lights, dynamic indicators, boot light, interior lights, never fitted, from Kopacek. £30 posted. Footrest for RHD manual models, not sure if it fits DSG, Never fitted, £15 posted. OEM cargo nets red/black, these have been fitted, £25 posted. OEM mudflaps, never fitted, were bought for facelift VRS hatch, £30 posted. Team Heko wind deflectors for hatchback, £20 posted.
For factory options / build codes I got mine from ebay. A guy in Italy emails it to you in a couple of days or so. Then print iff. Cost about £3 or less (via ebay uk). Just search for “vin decoder VW/Skoda”. Seller has a name like “ glavaneski”. Edit: ( got the original info of the source from earlier posts on this forum)
Final Drive Service?
Hi, thanks for the reply and very helpful. I'll get the final drive done asap then and keep on top of it now I'm the owner. Appreciate your help 👍🏻
I can get brief VAG service history. Just PM me the Reg number. Thanks. AG Falco
Battery Problem?
BCM replaced, all ok. I didn't tell them what the other garage diagnosed, wanted to see what their diagnosis was.
agarici20 joined the community
Pete's Rescue Roomster
The roof doesn't open, only the blinds do. So no drains.
Mence changed their profile photo
I’m on my phone so I will be brief. They are NOT the same thing. In VAG documentation, the VAQ LSD service is referred to as “final drive oil”. The recommended service interval is every 30,000 miles or 3 years, with some sources saying that the MQB Evo cars (2020 ono) want this done every 20,000 miles or 2 years. At this service, you need to replace the oil, and clean the pump screen/gauze. It’s the same principle as the Haldex AWD system (most VAQs are made of Haldex bits, although newer ones are… Borg Warner… @Cairus?) Perhaps @Evolution13 can find the thread from a few months ago where there was a big fight about updated intervals on the Mk4. The DQ381 service is advised to be done every 80,000 miles. This involves new fluid and a replacement filter. That said, every DSG box has an interval at 40k, aside from the 381 (80k) and 200 (sealed…). Most don’t trust this and, myself included, choose to get it done sooner. I have recently done mine at 40k, and will be doing it again when it hits 80k.
OccyVRS started following Final Drive Service?
Stage 1 remap
Where are you looking to get it done? Is it a 230, 245 or TDI? I’m not sure what tips are £1100 - do you mean the backboxes? The modes will remain the same, albeit with more performance at each setting. You are able to tweak some stuff (like having full power in RS, stock power in Eco, etc), but I’m not sure how straightforward that is. Perhaps @Cairus might have some idea?
- Rim protection 18" Gemini vrs alloys
Using indicators occasionally causes windscreen wipers to activate, any ideas ?
There’s a YouTube video that provides one possible explanation. Basically there is too much grease in the stalk mechanism that can conduct a current causing the wipers to operate even when switched off. I suppose it’s possible that using the indicators could displace some grease and also complete a circuit to allow the wipers to operate. The occasional ranfkm operation when left in Auto mode I think could be caused the camera that senses rain being fooled by dust particles and random water droplets from a passing cars screen washers.
Benny93 joined the community
headlights overheating warnings "Low beam light bulb" "Overheating temperature active"
So, I re-scanned today, and I've gotten a couple more of these - both left and right low-beam lights, on July 28 (I was driving up from Barcelona through a wide open, sunny valley, to the mountains; I don't recall exactly, but I assume the outside air temperature was in the low 30s°C). Should I be worried about a LED headlight over-temperature warning? thanks,
Roof bars and or Roof box.
You need to get roof bars specifically for the Scala, as they have little pegs that locate into the recesses you refer to. I've got Summit bars for my Monte Carlo, which work well and have these location pegs and detailed specific instructions for the Scala. Not too expensive, either, and an Autocad magazine best buy.
I finally had time to drive out a few minutes and find a place to stop the car (from Barcelona city you'd be surprised how difficult that can be). My OBDeleven original-generation dongle and app don't consistently show "live data", or maybe it's really live and the car computer only reports certain fields at specific moment? .. but it was very difficult to capture readings for a bunch of the possible data points. e.g. "A/C clutch": "Function cancelled, marginal conditions have not been met", and "Lots of different data fields, at least intermittently": "Not available" (but then, many fields, would intermittently show some data, then switch back to "Not available"). Is this a glitch, or just a known functional limitation, of OBD11/ an older OBD-II Bluetooth dongle? That said, I got some fields: "Coolant temperature": 88°C (although that seems to be more likely the engine than something specific to the A/C?) Blower voltage, actual value: 6.1 V Blower current, 4.50 A Compressor current, actual value: 0.810 A Compressor current, specified value: 0.820 A Rear temperature flap, actual value: 20, 0.0% Rear temperature flap, specified value: 20 Compressor shut-off requirement, penultimate event: Low pressure event (gotta love the word choice!) Compressor shut-off requirement, antepenultimate: Shut-off from Engine Control Module via CAN Outside air temperature: 38.5°C Outside air temperature, calculated internally: 31.0°C Left front vent temperature: 10.0°C Right front vent temperature: 9.0°C Footwell vent temperature: 16.3°C Temperature after evaporator: 4.3°C Interior Temperature: 30.9°C Sun intensity left: 750 W/m2 Sun intensity right: 690 W/m2 Blower status: active Actual value for fresh air/ recirculation air flow flap: 60, 12.5% Specified value for fresh air/ recirc air flow flap: 58 (Something obscured by a pop-up at that moment on my phone screen) "...stop for fresh air/ ...tion air flow flap": 210 Recirculated air stop for fresh air/ recirc air flow flap: 38 Left temperature flap, actual value: 28, 0.0% Left temperature flap, specified value: 27 Left temperature flap, cold stop: 32 Left temperature flap, warm stop: 233 Right temperature flap, actual value: 25, 0.0% Right temperature flap, specified value: 24 Right temperature flap, cold stop: 29 Right temperature flap, warm stop: 228 Front air distribution flap, actual value: 23, 0.0% Front air distribution flap, specified value: 20 Front air distribution flap, air outlet stop: 234 Front air distribution flap, footwell air outlet stop: 25 Defroster valve, actual value: 243, 100.0% Defroster flap, specified value: 244 Defroster flap, stop open: 239 Defroster flap, stop closed: 19 So. Yeah. There's that. Um. What does any of it mean? (And, I didn't seem to have successfully captured anything about pressure :-/ ) thanks!
