Past hour
Haldex versions
Rebuilding. Don’t know the cost but he’s not greedy.
I use the obd11. My battery charge status on average hovers between 68-73%. It never or rarely hits 80%. I’m not sure them readings are entirely accurate because i have seen it jump from 66% to 76% after only a very short drive. Also the percentage rapidly drops if you walk by the car a few times when the key is in your pocket. If your battery drops to 60% the start stop deactivates. Battery resistance has significantly increased. When new it was 3-4 millohms. These days it averages between 5-6 milliohms. Battery usable charge averages between 36-45ah depending on the battery’s mood and temperature. At the moment battery aging charging and battery aging performance is at 68% . That number varies too. Yesterday it dropped to 61%.
- Fabia 2024 SE comfort mpi fault
sonay joined the community
Haldex versions
No joy as yet 🤷🏻♂️ A couple of ideas to try but they are longshots. Is your guy in Wales rebuilding yours or replacing it? Without meaning to sound rude, how much is he charging?
There does seem to be always something else to a thread as I'm discovering. My suspicion has been that the turbo version ,at least, doesn't take kindly to lots of very short runs. After our service the wife drove to the dentist which isn't far as a crow flies but is always a slow crawl in practice. When she got back she mentioned that the crazy tips as to which gear to choose were back. A longish run has fixed it but getting over 50mph is getting harder and harder with ever increasing traffic congestion. I've just come across an assessment of the Fabia 4 TSI saying that for drivers doing lots of short journeys and wanting an automatic gearchange the cars are not recommended. Ours is a manual version but journeys are nearly all very short in congested road conditions. I've tried to attach the body of the article and have given the link too, but I'm not great with posting stuff.. Hopefully, reputable sellers of the Fabi mk 4 will assess whether the Fabia 4 is a suitable purchase by asking the customer about their driving needs.. Skoda Fabia Mk4 1.docx
Have you got VCDS or similar?, if so, can you record readings like these: Battery charge status (85 %) Battery internal resistance (8.0 mOhm) Usable battery charge (31 Ah) Battery voltage at rest (12.6 V) Battery internal resistance (8.0 mOhm)
Skoda Rapid front left ABS sensor wiring replacement
Reckon best option as pete says is to join it. I did one a few years back. Soldered wires together then insulating tape on each joint and heat shrink each one plus another heatshrink over whole cable plus self amalgamating insulation tape on top. Lasted as long as the car did. Alasdair
Alasdair1 started following Skoda Rapid front left ABS sensor wiring replacement
The wires go direct to the ABS module connector, brown to pin 35, black to pin 36 of the 38-way connector.
Today
MarcoMa joined the community
Incorrectly Identified NSL Speed Limits
ok thanks, I will post again if I get any results worthy of comment.
I noticed my car records the minimum cranking voltage drop in the gateway module. Most mornings it reads 7.90-8v. I have seen it drop to 7.5v. Not sure how accurate that is I left my car in for ceramic coating and when i picked it up the next morning it dropped to 6,6v and a **** load of low voltage codes.( i’m sure they were opening and closing doors while cleaning)The lowest i have seen on a battery tester cranking test was 7.9v.
Bridging it will be much easier than replacement.
Hi all. How difficult is it to replace the whole harness, cable, wiring for the front left ABS sensor? I stupidly bought the sensor only to discover something cut my wire. Around an inch is missing. Bridging it seems a bit tedious and risky. See attached image. Thanks Kris
Krisiacik started following Skoda Rapid front left ABS sensor wiring replacement
turbomikee joined the community
Battery issue or?
Surprised the battery wasn't dropping below 10 volts if it's faulty. Check with them that the replacement is correctly adapted (coded) to the BCM.
Battery issue or?
Even if you don't use SS, the alternator charging algorithm stays the same - which can mean the battery SOC never gets above 75%, particularly if relatively short trips are common.
sandspider started following 2017 Octavia vRS 2.0 TSI 245 - non-runner
- Play in between outer and inner track rod end
Battery issue or?
UPDATE: this morning the engine wouldn’t turn over at first and then it started normally on the second go. Drove the car normally during the day but decided to visit the dealership. They ran diagnostics and the battery came back as faulty. Putting in a brand new one at this moment. I’m just a bit surprised that an original battery only lasted two years and one month, I don’t even live in an area that experiences extreme low temperatures and I’m wary of stuff such as start/stop system and such.
@stepred I suspect we're stuck with it unless they manage to accidentally fix it in the same way that they accidentally broke it. What has become abundantly clear through this journey is that neither Skoda UK nor Skoda Connect have the faintest idea about the software running on the vehicles. And for good measure, neither give the proverbial flying **** that it's broken. If you want to pursue it with Skoda Connect, my original case number was 00410339, which then changed to 00473621. But they started ignoring my emails in August...
Battery issue or?
Cold start this morning, measured at the power outlet socket in the car. Initially 12.2, then 10.3 when cranking. Battery 14 months old, fully charged by external charge yesterday.
- Wheel nut torque
Attached the erWin rundown if anyone wants to check spec. erWin Online _ Škoda Auto _ Vehicle-specific information.pdf
Tazdaz started following 2017 Octavia vRS 2.0 TSI 245 - non-runner
Make & Model: Skoda Octavia vRS 2.0 TSI 245 6spd manual Colour: Meteor Grey (Primer) Mileage: ~74,600 Price: £4200ono - testing if anyone wants a project car before chopping it in at a scrappy Description: 2017 67 plate. One of the early 245 editions with memory heated front seats, heated mirrors etc. 19" Xtreme alloys have been powder coated gunmetal, now showing some signs of wear but still very presentable. Alcantara suede type seats in good condition, needs a valet but no tears or damage. Everything on the car was working as expected until a low oil pressure warning and subsequent garage visit. 2x sets of keys and V5 present. I'm the second or third keeper (log book in the car so can confirm shortly). Spent quite a bit on it this year so decided to cut my loses and move on (probably to a newer vRS). If you need any further details please let me know. Needs to be collected by Monday 30th November ideally. Non-runner - ea888 crank walk/thrust washer issue and some swarf in sump. Garage suggesting easier to replace whole engine rather than tear down and inspect/flush. Condition: Non-runner - otherwise in good used condition. No crash damage. Service History/Receipts/Recent Service work: Full service history through an extended warranty period (first 5 years). Home serviced since warranty expired, but has not wanted for anything. Oil and filters and other consumables all changed every 12 months or sooner. Bilstein B4 shocks and OEM springs all corners fitted in February 2026 (by VAG specialist - receipts available) Sachs Performance Clutch and LUK DMF flywheel fitted in February 2026 (by VAG specialist - receipts available) VAQ serviced twice in my ownership, last in February 2026 when clutch being installed. Rear callipers and hoses replaced August 2026 Brembo pads and discs all round January 2026 Water pump/housing replaced by Skoda in 2021 Extras: None that I'm aware of. It's the special early 245 that has heated front memory seats but don't think they are technically an extra. Mods: <OEM+ Stage 1, Sach Performance Clutch (organic). Wheels powdercoated gunmetal gloss.> Shipping: Collection only - central belt Scotland (Denny). Non-runner so needs a flatbed. Collection: <Collection only - central belt Scotland (Denny). Non-runner so need a flatbed. > Pictures: Some early pictures in my profile posts. It's broadly same condition, but needs a good valet inside and out as wasn't expecting to sell! >
1.4 TDi Spluttering and Loss of Power When Up to Temp
Hi all, Not strictly a Skoda but a VW with the same engine. My wife's Polo suffers from kagaroo-ing and loss of power when up to temp, but is perfectly fine when not to temp. No fault codes stored. 1.4 TDi BMS 2007. Starts and idles fine. Pulls well. All seems fine until the engine is at operating temp. Then the problems begin. Seems to take ages to warm up too but with this cooler weather I'm not sure it is a problem. However Gauge shows around 50-70 most of the time. Called AA when it first happened. Couldn't find a fault and recovered it to the VW Garage we use. Garage had it over 2 days and couldn't find a fault. Things I'm going to do this weekend. Change Thermostat Change Engine Temp Sender Remove and clean out EGR valve Replace rubber vacuum hoses with new silicone ones. Anything else I should be looking at?? TIA Nic.
2006 1.2 drivers door switch location?
Will fix it if I have to remove door card etc again. Will check wiring at pillar just in case but as fob works and everything else reckon its probably switch. Thanks again Alasdair
Yeah, not worth fixing if he's not bothered.
Wheel nut torque
it really doesnt mater, if thread is M14x1,5, all should have similar moment in Nm, on smaller cars M12x1.5 i used 110 Nm, on Karoq 125Nm. it depends massively of which material wheels are, steel wheels can be torqued much more, aluminium less. it really dont mind 120 or 140 Nm wont loose bolt in any way.
