  2. He failed. Was he watching Robocop when he designed it? 6000 SUX
  3. Agree with Warrior. At this point it doesn’t seem clear whether you’ve spun a shell and are about to explode a big end and kill your crank, or if you have a failing lesser component, or maybe a blocked oil pick up. Certainly damage has been done, but if your bottom end is sound, i’d say all is not yet lost - unless you know otherwise. If I were a car dismantler, i’d also think £1400 was a good risk, possibly a good flip if it’s a non major repair. Gaz
  4. As that is probably not the original battery, it is possible that it was not correctly adapted (coded) when it was fitted (possibly 2022?) It's quite possible that it is failing - failing battery can cause multiple issues even though it still appears to start the engine normally. I'd strongly suggest having the battery properly tested first.
  5. DuckPaulo joined the community
  6. Bluesnake joined the community
  7. Hello, I am writing to urgently request your specialized engineering guidance regarding a highly unusual and critically severe mechanical seizure on a 2009 Škoda Fabia Combi Mk2 (1.6L Gasoline BTS Engine, 6-Speed Automatic Tiptronic Transmission - Aisin 09G). • Component in Question: Right-Side (Long) Inner CV Joint Cup (Transmission Side) The Problem: While attempting to replace the right front drive shaft, the inner CV joint separated, leaving the inner CV joint cup (stub axle portion) completely seized inside the differential housing. The internal circlip (snap ring) appears to have experienced a severe mechanical binding/jamming or deformation inside the differential splines, creating a total mechanical lock. Chronology of Failed Removal Attempts: We have strictly followed all standard automotive repair protocols, followed by heavy-duty industrial extraction methods, but the cup remains completely immovable. The following attempts have been made: 1. Standard & Specialized Pry Bars: We used dual pry bars and dedicated CV axle popper forks to apply balanced, opposing outward leverage. The cup did not budge. 2. Heavy-Duty Slide Hammer & Vice Grips: A professional slide hammer was securely locked onto the cup's ridge. Repeated high-impact blows failed to release the circlip. 3. Opposite Side Punching (Attempted): We completely removed the left-side (short) healthy axle to drive the seized cup out from the inside. However, this specific differential design features a center pin/plug (blind differential) preventing a straight punch from passing through to the back of the right cup. 4. Drilling & Pin Insertion: We successfully drilled two opposing holes through the heavy metal walls of the cup, inserted a thick, high-tensile steel bolt through it, and attached heavy-duty locking pliers linked to a slide hammer. The impact shattered the pliers, but the cup did not move. 5. Arc/CO2 Welding & Industrial Chain Pulling: We welded a massive high-tensile bolt directly into the inner cavity of the cup to achieve structural integration. We hooked it to an industrial iron chain and applied extreme hydraulic/mechanical pulling force. The force was so immense that the heavy-duty iron chain snapped completely, yet the CV cup did not move even a millimeter. Current Dilemma: The inner CV cup and the differential splines are now acting as a single, permanently welded mechanical unit due to the internal circlip jam. We have stopped applying further external pulling force to prevent cracking the aluminum transmission casing or destroying the internal differential bearings. We also want to avoid dropping the entire transmission if an on-car engineering solution exists. Given your deep manufacturing and engineering expertise with the Aisin 09G / VAG differential assembly, could you please provide us with: 1. The official factory service protocol for a totally seized internal circlip on this specific transmission. 2. Any specialized VAG dealer tool designed for this exact type of catastrophic seizure. 3. Your technical recommendation on whether splitting the cup longitudinally (on-car) is safe, or if dropping the gearbox is now mandatory to dismantle the differential. Thank you for your prompt attention to this highly challenging technical issue. I look forward to your expert guidance.
  8. Me and my wife loved our 2011 Skoda Karoq estate. So when we decided to replace it with an SUV in 2023 it was natural for us to buy a Skoda SUV. We bought a 2022 Karoq 1.5 SE Technology. We have always loved the car, but when the clutch went without warning at around 30,000 miles, we were shocked and disappointed. Although my wife (whose main car it is) admits to riding on the clutch at times, she has not changed her driving style over the years. We sold the Octavia at 118,000 miles with no sign of a clutch problem.
  9. Martin1969 started following Clutch Failure
  10. Why noir stay oem? It would cost you the same price. Otherwise look at Alpine ou Kenwood. AFAIK they are the only ones with full implementation
  11. I'd have thought quite likely - I'd suggest it would pay to have an analysis of the swarf done and test the oil pressure.
  12. GeorgeAdel joined the community
  13. Martin1969 joined the community
  14. @Kojne Welcome to the forum. What country are you in? Does the car you are getting have a comprehensive service history? How many km has it done? Has the DSG had an oil and filter change? Has the VAQ diff been serviced, maybe twice by now?
  15. Hello, I don't think it's the accessory belt. Its intensity and frequency are constant and do not vary with engine speed. It cannot be heard when the vehicle is stationary, whether the engine is idling or being revved. Thank you.
  16. Today
  17. Probably your navigation FeCs if you are trying to load maps into that which dont tally with the country it was meant for. The give away is in your text. Mib3 is locked down from tinkering. A good retrofitter with vag equipment would be able to do it. Some can do this stuff remotely if you buy the box. It was all put on a legitimate level for legitimate use. Audi / VW police it. East Yorkshire Retrofit is such a company in the Uk. Abroad other companies exist. Turkey is another country where retrofitter unlock the infotainment unit for map updating. Vehicles which are exported secondhand from Europe are candidates. American services personal bringing their Vag cars are another. So yes it all changed with mib3. No toolboxes due to better encyption and backdoors bolted which had been left open in mib2. Changing firmware also runs risks irrespective of maps since these units are now locked down so if there is an issue you can't dig yourself out. The firmware may only work with specific other updates elsewhere in the car to the control systems.
  18. Rij joined the community
  19. If the software is up to date - and the battery in good health - both of which you can check easily without the dealer having to do anything - then you'll be fine. I'm on 1941, which has been fine for about 4 years. They're decent cars!
  20. Hi. I believe there are two different makers of the original cooling system that these cars left the factory, Valeo or Denso. Other makers can of course make parts to these systems according to the specs, but i believe that you cant mix Valeo and Denso system parts together. You should go to skoda-parts.com and make an account where you can enter your own cars VIN-number to check which parts are the correct ones for your car. I am using this method for sourcing spareparts for my mk3 Octavia and it works great.
  21. Hi, I’ve been struggling with the update for quite some time—tried various USB drives and an independent shop using ODIS—but I’m still stuck on version 24.12. I have two options: sending the unit out for repair or flashing a US-to-EU conversion via the service menu. Does anyone happen to have the conversion package, but with a version newer than 24.12? I’m even willing to pay for it.
  22. Tyneluta joined the community
  23. Thank you for your reply. I'm just a little old lady with a Superb I love to drive 😉. Here are the Pcodes P06DA00 Engine Oil Pressure Control Circuit/Open static P064C00 Glow Plug Control Module static There are also these Bcodes B10AF04 air con B122D29 central locking driver, passenger and rear left doors B122B12 as above B122B11 as above B105413 GPS antenna Be good to know where I go from here, possibly not in my Superb 🤣. All advice is very gratefully received.
  24. If you cant figure out how to use OBD11, you can download Car scanner or OBDTorqueLite. They are not as nice looking or user friendly but they can diffinately read the DTCs in each is the modules
  25. If you have OBD11 you need to figure out how to use it and read the DTCs... It says there are 6 control modules with faults which means there are at least 6 Pcodes available. It's pointless guessing what the fault might by based on an icon in an app. The engine light can be related to lots of different faults from sensors to actuators, battery to communication. Gabbo
  26. Gabbo started following Exhaust warning light
  27. The nice thing about using VCDS for this is that it often tells you likely login codes that usually work. Perhaps you could find someone with VCDS near you who could do the coding for you?
  28. Depends on what you want. I have a ROON rock server for the home and this does all my zones (rooms) and plays local content and integrates with streaming services like Qobuz and Tidal. Worth exploring if you’re into your music at audiophile levels. Especially with their RAAT service.
  29. Got an Edition 100 that I got on 94k a couple years back in the PD130 variant. Lovely spec and excellent on fuel despite being heavier. Don’t see many on the road now.
  30. Please do. As you can buy an oem plug in kit by a 3rd party and get it installed. Also, double check the wiring isn’t hidden down the back of the dash.
  31. Dean replied to cossieash's topic in Hellos and Goodbyes
    Welcome back to the community!
