Karoq VCDS coding
Oh, IT IS correct IT IS now a FeC, Patch Unit
1.5 Tsi Power Cutting Out
Everyone who is seeing this problem should report it to the DVSA https://www.gov.uk/vehicle-recalls-and-faults/report-a-serious-safety-defect That way , there's at least a chance that VAG will be forced to admit there's a problem
Karoq VCDS coding
That’s what I heard too, but 4x4 cars have it! I believe I should coding something more, like simulating the presence of a 4x4 traction, changing parameters of abs, traction control etc. too risky imho
Phil439 started following Has my right steering wheel roller stopped working?
Ajhskoda joined the community
How to: Travel Assist and Heated Steering Wheel Retrofit
hi i found 5Q1953549F wich was taken from 5Q1953507GF octavia mk4 but is from LHD , automatic gearbox but my car is RHD, manual gearbox can this difference cause errors?thx
milloo24 started following How to: Travel Assist and Heated Steering Wheel Retrofit
Karoq led matrix headlights
And you know this how?
Tell them that knock sensors and the ECU hardware and software that interacts with them react in fractions of a second, so their argument is utter tosh.
Reported to the dealer that it was still stopping on E5 and their reaction is that 350 miles is not enough time/ distance for the engine to relearn and it would need 3-3500 miles. If it relearns and the result of that is the behaviour goes away then what happens when I switch back to E10…… does it relearn again and the behaviour reappears? The price difference is too much to continue to use E5 and the car should run on E10 (as stated in the filler cap) the latest communication reinforces the view that we get rid and move away from Skoda/VAG altogether. Daughter has a manual A3 with an earlier version (68 reg) and it has never done it.
- Searching for the correct coding for 5F: Information Electronics after changing the sound settings with Car Scanner
Phil439 joined the community
Noisy car ...
Try Blackrod Service (or MOT) Station. Have used them in the past for MOTs and service/repair work. Have always been fine to deal with.
Retro Side Assistent
I'm from Austria... the parts were way too expensive. 5Q0 is rubbish, just upgrade to 2Q0. Much better.
Skoda Finance Redemption
Yes you have to 'withdraw' from the finance agreement within the first 14 days, not cancel it. My interest payment was £9.48 for 3 days. All straightforward enough.
aggagaa244 joined the community
Just to mention that I bought the 5Q0 radars on ebay from Austria which were from a similar Skoda Octavia mk3 2017 and both units cost me 252€. The original used mirrors with dimming from ebay cost me 136€ (one was chipped), the cables I bought from aliexpress for around 50-60€, the radar mounting brackets I bought from skoda-parts.com for 24€/both, also needed to buy a couple of cables, pins and connectors from aliexpress for around 10-20€ max. So everything cost me around 500€
Diff shaft
Reckon if its still there its either worn splines or worn cv joint. Get someone to hold shaft and try turning wheel by hand if its still there it would I think rule out Gbox and inner cv. Alasdair
That's an excellent project and thanks for providing so much valuable info, I didn't know the mirrors from mk4 could be installed on the mounting bracket of the mk3! I also love that the LEDs will be integrated in the mirror casing instead of mirror elements since they are incredibly expensive and can easily be stolen I also heard that the 2Q0 radars are better than the 5Q0 ones because their range is bigger. I have just finished installing BSD/RTA myself this week on my Skoda Octavia mk3 1.4 TSI 2017 using the 5Q0 radars and original mirror elements with BSD LEDs and dimming and I am happy how the system works: I will follow your topic @Cairus to see how your work evolves! Good luck!
Diff shaft
Or maybe not 🤔
Karoq VCDS coding
Dont Work anymore What i know Can check with my 3 devices
- Karoq VCDS coding
the truth about electric cars
Maybe, but still true nonetheless: all demos are always done in as near-perfect conditions as possible, never reflecting real-life situations and therefore spreading misinformation and false hopes.
- Changing Tyre Sizes on Fabia Estate 1.4 petrol VRS 2013
hubrad started following Changing Tyre Sizes on Fabia Estate 1.4 petrol VRS 2013
Aktualizacja softu w Skodzie Scali 2021 r.
Hello. I'm having a problem with my 2021 Scala 1.5 petrol. There's a display issue and an SOS message appears. I've read that a system update might be necessary. I'm currently running firmware version 1800. Has anyone done the update themselves? Is there any instructions available?
Pietia215 started following Aktualizacja softu w Skodzie Scali 2021 r.
I use https://tiresize.com/comparison/ if you go for 205/45 at 60mph its actually 62mph and 205/50 its actually 64mph according to their site. As previously said as long as all tyres are the same size ABS etc wont be affected. Had 225/40/18 on a people carrier but the weight rating was too low so went for 225/45/18 and didnt really notice. On it the larger size just cleared the bottom of front strut. Make sure you have enough room. Alasdair
Alasdair1 started following Changing Tyre Sizes on Fabia Estate 1.4 petrol VRS 2013
- Powitanie.
Powitanie.
"Hello everyone. I own a 2021 Skoda Scala 1.5 petrol. Thank you for accepting me into the forum." Hi and welcome to Briskoda. Please note the default language is English. We understand it's not everyones first language but there are translation tools available. Cześć i witaj na forum Briskoda. Pamiętaj, że domyślnym językiem jest angielski. Rozumiemy, że nie dla każdego jest to język ojczysty, ale dostępne są narzędzia do tłumaczenia.
